Question about Toshiba 50HDX82 50" Rear Projection Television
Tashiba 50 hdx82
My tv has sound but no pitcure. do u think it a fuse in the back or somtinhg else
  • 2 more comments
  • fourty Mar 05, 2008
    hello. thank you for responding. my husband originally asked this question and I have a few more questions. What exactly do you mean by "CHK hori out put NTE2973 also 1200uf 2kv cap feeds off hori." is the two the same thing, and do you know where this blue piece is in the tv so i can get to it?? What is hori? Where can i get a new capiactor? THNAK YOU for all of your help and i have to appologize in advance for my illiteratacy in tv repair. lol
  • drft Apr 26, 2008
    the tv has sound, even when changing channels. The menu works, all the colors in the menu are fine, but no picture for ant. or video inputs. Just black.
  • aanemesiss May 04, 2008
    my 50HDX82 toshiba picture went black. When I turn it on sometimes the led power light does a double click powers off quickly and then comes back on again ...still with no picture. i can hear the channel that is on , (but that may be going through my cable box which is hooked up to my reciever). I can't bring up menu or anything. tried unplugging with no luck. any ideas???
  • coops mom Sep 09, 2008
    I am having a similar problem, but was told that it was the signal board. The warranty people say they don't have them anymore to replace it. Found a parts store that has an assay signal board. Does that sound like what I need??
  • Toshiba Master
  • 5,138 Answers
If you only had a blowed fuse you would not have sound, CHK hori out put NTE2973 also 1200uf 2kv cap feeds off hori. this is your problem.Small blue capiactor.
Posted on Mar 05, 2008
WHERE IS FUSE LOCATED ON BIG SCREEN TV, REPLACED LAMP , STILL NO PITCURE BUT I HAVE A SOUND, STAYS ON A LITTLE WHILE AND KICKS BACK OFF
You must follow instructions very carefully when replacing the lamp. Chances are the door did not get shut tightly allowing an open circuit to the door switch and the fan. If the fan is not running you must go back and make sure the lamp installation is right. also, if you did not purchase an exact replacement lamp it may be defective. If the fan is running then the chance is for a bad lamp. Hope this helps.
Feb 10, 2015 | Mitsubishi WD Televison & Video
50'' hp no picture just color lines
Likely to be main board issue which is the most expensive board in set and also not likely to be a do it yourself repair.
May 20, 2012 | HP PL5060N 50 in. Plasma HDTV
Loud whine in volume on 42 inch tashiba lcd Turned offf set for 3 minutes then back on and was alright. What do think?
I have heard this problem in a few LCD Flat Screens. And the problem was bad capacitors. This may be true in your particular TV. Thanks for asking and show a few hands of support!
Nov 04, 2010 | Toshiba Televison & Video
Tashiba cinema series. Do not have sound nor picture . Clicks when turned on blinking power button mpatty1@avenuebroadband.com
needs convergence chips, stk392-110, may also have open resistors and/or fuses, you probably need a tv repairman.
Sep 15, 2009 | Televison & Video
TV has sound but no picture...
This is a pitcure tube problem, either you buy another picture tube and change it on your TV or if this is under warranty better to send it back to the manufacturer and have this one repair.
Jul 14, 2009 | Sharp LC-19SB25U 19 in. LCD HDTV
Power light comes on but no pitcure or sound.
it sounds like you may have a bad flyback thats keeping the tv from coming on
Feb 16, 2009 | Philips Magnavox 9P6034C 60" Rear...
My 60" philips tv
sounds like the LSB board, which is a common fault with your model. You can get a new DPTV 300 series LSB at the following link.
http://servicemanuals.vstore.ca/
Sep 27, 2008 | Philips 60PP9202 60" Rear Projection...
1998 50" Rear Projection Hitachi Model #50SBX70B--NO picture
can you see the g2 from crt sound like you list your g2 from
the flyback.i need m# plz
Mar 30, 2008 | Hitachi 57SWX20B 57" Rear Projection...
Toshiba 50HDX82 50" Rear Projection Television Logo
73 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
