Question about Canon PIXMA MP530 All-In-One InkJet Printer
Receiving fax...... We just had distinctive ring set up..........how do we receive a fax? Thank you.
    Genius:
  • 3,587 Answers
You can do it on auto or manual mode..that's in settings..do you have the print manager for this?
you might find it here
Posted on Mar 09, 2008
Fax receiving problem
press the set up button or the tool button the printer . then use the right arrow or left arrow button scroll to basic fax set up ,and advance fax set up. u will find the distinctive ring pattern under advance fax setup. also check if u are using any telephone answering machine if using check the rings to answer in ur printer should be 2 rings higher than the rings to answer in the telephone answering machine.also turn off the error correction mode.turn the auto answer on.try this steps
Sep 11, 2009 | Office Equipment & Supplies
Phone ring is not coming through on my phone for the fax machine
Fax machines are ANALOG devices and will not work reliably on DIGITAL phone lines. you cannot set a fax machine to digital.
Jan 28, 2009 | Panasonic Panafax UF-595 Plain Paper Laser...
Faxes office Jet K60
You have to have either a dedicated phone line just for the fax --or-- pay your phone company approximately $2 a month for a service called Distinctive Ringtone. This service will ring a certain way when you have an incoming fax. You will then configure your fax machine to pick up when this distinctive rington is heard. The ringtone is usually two or three quick rings. Your fax machine's settings will have this setting.
Unfortunately, you can't just plug your fax machine into your phone line and start sending/receiving faxes. Look through your fax machine's manual regarding the distinctive ring service. Good luck!!
Oct 01, 2008 | HP OfficeJet k60 All-In-One InkJet Printer
HP640 not receiving with Distinctive Ring Option
You need a dedicated ANALOG phone line.
A DSL filter screens out ANALOG signals to a DSL device.not the other way around. There are no DIGITAL fax machines.
Aug 10, 2008 | HP 640 Inkjet Fax Machine
Receiving Faxes
You will have to ask yourself the question "What has changed?" If you changed nothing, then something else has that is beyond your control. Now, you have to decide whether you are using a single telephone line for faxes and telephone, or whether you have "distinctive ring" also called "smart ring" by some companies. It is not a smart thing to use both. You can print a list of settings to see what the machine is set to do. Now if you want to use distinctive ring, set the ring pattern to the one you have chosen with the tel company. If you have chosen a double ring, and you have set your panasonic telephone to receive on 4 rings, then it will count all the rings and pick up after only 2 sequences. To see if this is the problem just remove the telephone base station from the system and then try to receive a fax.
Jun 08, 2008 | Brother IntelliFAX 2800 Laser Fax
Set up to receive fax
To select or change your Receive Mode
If it is not illuminated in green, press (Fax).
2 Press Menu/Set, 0, 1.
3 Press ▲ or ▼ to select Fax Only,
Fax/Tel, External TAD or
Manual.
Press Menu/Set.
4 Press Stop/Exit.
Setting the Ring Delay
The Ring Delay sets the number of times the MFC rings before it
answers in Fax Only or Fax/Tel mode. If you have extension
phones on the same line as the MFC or subscribe to the telephone
company’s Distinctive Ring service, keep the Ring Delay setting of 4.
(See Operation from extension telephones on page A-7 and Easy
Receive
on page 4-4.)
1 If it is not illuminated in green, press (Fax).
2 Press Menu/Set, 2, 1, 1.
3 Press ▲ or ▼ to select how many
times the line rings before the MFC
answers (00, 01, 02, 03 or 04).
Press Menu/Set.
(If you select 00, the line won’t ring at all.)
4 Press Stop/Exit.
Initial Setup
1.Receive Mode
Current Receive Mode
Fax : Fax Only
F/T : Fax/Tel
TAD : External TAD
Mnl : Manual
Setup Receive
1.Ring Delay
Apr 02, 2008 | Samsung CLX 3160fn All-In-One Printer
To recieve fax on brother
Press the 'RECEIVE MODE' button on the right side of the control panel, its next to the large 'FAX START' button. Here are your options :
Select Receive Mode
MANUAL
—You must answer all calls yourself. If you hear fax tones, press
Fax Start
to begin receiving the fax, then hang up. You can use this mode with
Distinctive Ringing. (See
Distinctive Ring
, page 8-1.)
FAX ONLY
—The fax machine automatically answers every call as a fax call. You
cannot receive a voice call, but you can dial out and make a voice call.
FAX/TEL
—The fax machine automatically answers every call. If the call is a fax, it
prints the fax. If the call is not a fax, it signals you with a double-ring (ring-ring),
different from the phone company ringing, to alert you to pick up the call. If you select
this setting, you’ll need to set the Ring Delay and F/T Ring Time features (on the
following pages). If you have extension phones on the same line as the fax machine,
set Ring Delay to 4. (See
For FAX/TEL Mode Only
, page 5-5.)
TAD:ANSWER MACH.
—This is the only setting in which you can use an external
answering machine. Your telephone answering device is connected to your fax
machine, and answers every call. Once the TAD answers, the fax machine listens for
fax tones. If it detects fax tones, it prints the fax.
The TAD setting works
only
with an external telephone answering device (TAD); it
does not work with telephone company Voice Mail. Ring Delay and F/T Ring Time
do
not
work in this setting.
Nov 27, 2007 | Brother IntelliFAX 775 Plain Paper Thermal...
Receiving a fax when using the phone
you can not use the phone simultaneously while sending or receiving a fax. You do not need a separate line. especially if you do not do a lot of faxing. You just can not do both at the same time. You can set your machine to automatically receive faxes when you are not present. The machine will detect the sending tones of the senders fax and automatically receive your fax. You may want to order a users manual from brother to help you set up your fax for your specific needs. Their number is 1-800-284-4357. Another option is you can order the distinctive ring option from your phone company. This will allow you to give out a seperate phone number for your fax while only having one line. The machine can be programed to distinguish the distinctive ring and automatically pick up with out you wondering if it is a fax or phone call. But again you can not talk and fax at the same time. Good luck and let me know if I can be of further help! John
Sep 07, 2007 | Brother FAX-1960C
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
53 people viewed this question
old marine
old marine
