Question about Yamaha RX-V2700 Receiver
Firmware Upgrade installed firmware upgrade and as a result lost 2 channel stereo as well as volume levels to get audio (7 channel only) have to be set very high.
  • 3 Answers
Where did you get the firmware upgrade? Please provide link.
Posted on Apr 16, 2008
Upgrade firmware for Nikon D80
Confirming the firmware version:
  1. Turn on the D80
  2. Press the MENU button and select Firmware Version from the setup menu. The camera's firmware version will be displayed.
  3. Turn off the D80
Basic Upgrade instructions: for detailed instructions, see pdf files below.
  1. Download and expand the firmware files
  2. Format an approved SD (Secure Digital) memory card in the camera
  3. Connect Camera to computer (in MSC USB mode) or use a SD Card Reader
  4. Copy to the top level of the card the downloaded "A firmware" file
  5. Disconnect camera from computer
  6. Update the firmware from the "Setup" menu
  7. Follow the camera's on-screen menus
  8. Repeat steps 2 through 7 using the "B Firmware"
  9. Re-format Card
D80 1 11 firmware upgrade Nikon Knowledgebase
Apr 03, 2014 | Nikon Cameras
How 2 upgrade
It depends what firmware you are trying to upgrade to. If you want to install custom firmware on your PSP, check this YouTube channel:
http://www.youtube.com/user/ubeenstryked
If you want to install official firmware, you can find a list of downloads here: http://downloads.exophase.com/category/psp-official-firmware/
When you select the firmware you want to install, download it. You will get a .zip file with a file inside called EBOOT.PBP. Follow these steps to update:
1.) Connect your PSP to your PC. 2.) Open the PSP folder and then the GAME folder. 3.) Right click INSIDE the GAME folder, and click New Folder 4.) Name the new folder UPDATE 5.) Place the EBOOT.PBP file you downloaded into the UPDATE folder. 6.) Disconnect your PSP from your computer, and select the MEMORY STICK ICON in the GAME section. 7.) Find the PSP Update Version.. and run it, complete the on screen steps to install the new firmware.
May 16, 2011 | Sony PlayStation Portable Slim Black...
I am trying to upgrade firmware on a hitachi 42hds69, using a 2 sd card, I formatted the new card before uploading the file, I did unzip the file on my desktop. The tv won't do the upgrade. any Ideas
I had an issue (OTA no audio in channel 2-1 and 11-1) on my Hitachi 42HDS69 so I tried to upgrade the firmware. The manual as well as the instructions on TV all state to use a MMC card. Someone on an internet forum also stated that a 7-pin MMC is needed. I tried exactly that but it did not work. Finally I tried a 128MB SD card and it worked like a charm. The firmware upgrade fixed my OTA audio issue. I went from V0108 to V0125.
All you need to do is to extract out the .F02 file and place it in the root directory of the SD card.
BTW, I did call Hitachi customer support. They refused to help due to the TV is too old (about 10 years old).
I guess it all depends on who you speak to at Hitachi?!
Feb 09, 2011 | Hitachi 42HDS69 42 in. Plasma Television
Toshiba 26LV610u TV with no sound on one channel
If you have lost sound on only one station and are using cable or an antenna directly to the TV. Look in the audio settings as most likely the SAP mode is turned on. If the TV detects a SAP signal even if there is no audio this is what you will end up with.
Nov 05, 2009 | Toshiba 26LV610U LCD TV
Firmware upgrade and lost all channels
How are you getting your channels,cable,dish,air? Your best bet is to go in and rescan your channels.
Nov 01, 2009 | Syntax OleviaL 527V 27 in. LCD Television
M Mp3 doesn't turn on
Recovery Mode for Philips' GoGear
Open the Philips Device Manager (Start à All Programs à Philips Digital Audio Player à SAXXX à Philips Device Manager) and click on the “Repair” tab. Then click on the “Repair” button to start the repair process. Most of the time, when your player is in that state, the Device Manager will not recognize that your GoGear is plugged in. If this is the case: Disconnect the player from the PC, and make sure the mp3 player is turned off. Hold in the volume + button on the mp3 player, and reconnect the player to your pc while holding in the volume + button. Continue holding the volume + for 10-15 seconds until a "Found New Hardware Wizard" pops up. It should recover your device if there isn't anything internally wrong with the player. Warning: this procedure will result in your songs being erased off the player, so they will have to be reloaded.
-Tha Mp3 Doctor
Philips GoGear Firmware Upgrade
You need to get the latest firmware upgrade from the Philips website:
1. Go to www.philips.com/support
2. Enter your country/language
3. Enter your model # SA6045 or whatever
4. Click on the link for your exact model # (the one w/o the "B" in it)
5. Click on "Software & Drivers"
6. Download the updated "Device/Firmware Manager"
7. Once installed, open the Philips Device Manager
8. Click on the "Update" tab, then the "Update" button (with your mp3 player connected to the computer, of course)
9. Your Mp3 players firmware will update automatically
If you do not have the latest version of the Philips Device Manager installed (the latest is the version from the Philips website), then clicking the "Update" button will give you a false positive saying "The firmware on your device is already up to date."
-Tha Mp3 Doctor
Sep 27, 2008 | Philips Audio Players & Recorders
My Phillps mp3 wont turn on or let meh download more songs. Wuts wrong with it? Plz help.
-Tha Mp3 Doctor
Sep 19, 2008 | Philips SA4020 MP3 Player
Mp3
This is a coincidence. Reset the player, and then upgrade the firmware: Recovery Mode for Philips' GoGear
-Tha Mp3 Doctor
Apr 09, 2008 | Philips GoGear SA3125/37 MP3 Player
I do not feel comfortable performing the installation the Optional Enhancement Upgrade for DiMAGE 7, can I have the camera upgraded professionally?
If customers do not feel comfortable upgrading the DiMAGE 7 firmware themselves, they can send the camera in to the NJ repair facility with a note stating "Please Upgrade Firmware". Their camera will be upgraded, and they will be charged $49.95 (plus tax and shipping). They will receive back their upgraded camera, and a DiMAGE Viewer Ver 1.2 Upgrade CD-Rom*. (They will not receive the firmware upgrade on CD-Rom or the new DiMAGE Viewer) There is a 2-3 week turn around time once payment has been authorized. * images captured with an upgraded camera cannot be opened using previous versions of the DiMAGE Image Viewer Utility 1.11 or earlier. A DiMAGE Viewer Ver 1.2 upgrade CD-rom has been bundled with the DiMAGE 7 Optional Enhancement UPGRADE Firmware. The previous version of DiMAGE Image Viewer Utility must be installed before the DiMAGE Viewer (Ver 1.2) update can be loaded. If customers do not feel comfortable upgrading the DiMAGE 7 firmware themselves, but they want the DiMAGE 7 Optional Enhancement UPGRADE and the New DiMAGE Viewer 2.0, they should purchase the kit through our on-line store, then send the camera in to the NJ repair facility with the Firmware UPGRADE CD-Rom that they purchased. As long as the firmware CD-Rom is sent with the camera, and the camera does not show damage that may void the warranty or cause the firmware to not install properly, there will be no charge for the camera to be upgraded. There is a 2-3 week turn around time once the camera has be received. If customers attempt to install the firmware upgrade on their camera and experience a problem, or the upgrade does not complete, they should send the camera in to our NJ repair facility with the Firmware UPGRADE CD-Rom and a description of the problem. As long as the firmware CD-Rom is sent with the camera, and the camera does not show damage that may void the warranty or cause the firmware to not install properly, there will be no charge for the camera to be upgraded. There is a 2-3 week turn around time once the camera has be received.
Sep 15, 2005 | Konica Minolta DiMAGE 7 Digital Camera
Yamaha RX-V2700 Receiver Logo
3,644 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
