Washing machine water coming out of powder drawer
  • lindenbear Jan 16, 2009
    water leaking out of the soap pwder drawer
  • 156 Answers
Remove drawer and clean out the spot going down inside dryer with some thing like a long skinney brush cut back on the amont soap u use that will fix it
Posted on Mar 06, 2008
Water leaks out of the washing powder compartment
it might from closing the powder drawer not completely and correctly
or having crack in the drawer
or having the high water pressure in the Water pipeline network
check all above , if not , call service center
thank you
Nov 05, 2014 | Beko Wm & Wma Models Washing Machine Motor...
My washing machine won't use soap from the drawer
are you useing the right draw for main wash try putting on a wash and open the draw there should not be any water leaking if you do this and look in the compartment that you put the powder in and see if the water is going into the compartment that you use and see which compartment is filling thats the one to put the powder in
Nov 14, 2011 | Washing Machines
Washer doesn't dispense fabric softener
This can be either one of the solenoids in the dispenser has failed, the timer is not sending the signal to let the softener in, or the water is not circulating through the dispenser to flush it through. The water hose to the dispenser will occasionally plug up. Check the hose first, it's the cheapest to unplug it. ;-) Oh, I have seen the wires to the solenoids just simply come unplugged too.
Jan 02, 2010 | Frigidaire ATF6000ES Front Load Washer
Intello washer leaking water from detergent drawer. model no. WM10402F would like to know if a part needs to be replaced or would anew machine be better. the water only leaks when water comes into the...
Are you sure it is coming from the detergent drawer? It could be from your inlet water valves. They are very easy to see. Two screws on the rear of the machine will let you slide the top back and expose the componets.
Dec 29, 2009 | LG WM-2277HW Front Load Washer
Excel 1200 water coming out of power drawer
try cleaning the filter located at the bottom of the machine in a small access door
Mar 01, 2009 | Washing Machines
Powder drawer wont open
Grasp the drawer firmly, and pull out until it reaches its stop, then press the plastic lever down in the middle of the drawer at the rear, and pull the drawer out.
Please rate my fixya solution.
Thanks.
Feb 09, 2009 | Hotpoint Aquarius WD640 Front Load...
Water gush in power drawer
You have a seal that is not working right for one. and 2 you have a water pump that is not working. because it is not limiting the water supply.
Aug 26, 2008 | Hotpoint Aquarius WD640 Front Load...
Hoover Nextra washing machine - water backing up
If this is a front loader see that u use only washing powder for FRONT LOADING MACHINES. Also possible your detergent drawer is clogged with old dry detergent. Pull out the drawer and clean with tooth brush. Things shd be fine.
Oct 07, 2007 | Washing Machines
Washing Machines Logo
143 people viewed this question
Top Washing Machines Experts
