DVDs won't play or record; "Unknown Disk" message. VCR plays fine; audio CD plays fine with file list on screen. Unit is DVD/VCR recorder/player.
  • 3 more comments
  • s0miller Mar 06, 2008
    I'm trying to play commercial DVDs that I have successfully played many times before. I have tried several with the same results.
    I am also using the same blank media (from the same spindle) that I have used successfully before. So I don't believe media is the problem.
    Also, in case the cause was dirt, I have used a Kensington CD drive cleaner after the problem occurred, with no change in the results.
    Region code (and other setup information) has not been changed since a week ago when everything worked.
    Model is GOVideo DVD Recorder & VCR VR3840.
    Region code (and other setup information) has not been changed (set at US) since a week ago when everything worked.
  • s0miller Mar 08, 2008
    Not the problem. See my earlier reply.
    President:
  • 778 Answers
Hello s0miller,
Make sure the DVD media you are using is compatible with your Burner/Player, such as DVD-R and not DVD+R or RW. You may also want to note the Brand of media as I have experienced compatibility/readability issues related to specific Brands of Disk (Quality in manufacturing can cause problems with certain Burners/Players).
Some feedback on Brand and type of media you are having issue with, make and model of your machine, and prior successes also, would help?
Good luck,
TampaNative
Posted on Mar 05, 2008
  • 689 Answers
Have you checked if region code matches?
Also please let me know the exact model of your DVD Player
I've got VW Passat b6 2006. Rosen-VW0710-H11 is installed in it. When I try to play DVD (no matter audio or video) system displays message: "Password Fail". What can be the reason of this...
I would recommend resetting the Rosen unit. This is done by entering the "Menu" and pressing "Settings". From this screen, you select "Keypad" in the top right corner of the screen and then enter "7-5-2-3" and press "Enter". This should erase any code for Parental Control (levels 0 - 8). Also, the Rosen product states to only use "Store bought media" for CD's and DVD's meaning that it won't play all 'burned' discs. Hope this helps.- Elliot
Sep 29, 2011 | Car Audio & Video
I own the LG DVD Recorder/Video Cassette Recorder (model LGXBR446). The problem I am encountering is, it plays some DVDs but on others I keep getting "Unknown disk, please, check disk again"...
Hello ethiosoft,
Welcome, and thank you for using FixYa!
I would start with a DVD cleaner kit for the player. Chances are, if the drive worked before, then it will again; after being cleaned.
If the issue persists, then the DVD drive is failing. Chances are at that point, it would be cheaper to replace the entire unit then just the DVD drive.
Have a great day!
Sep 11, 2011 | LG XBR446 DVD Recorder/VCR
Dvd drive dose not recognise any dvds i put in it keeps saying unknown disc
If your unit is older the optical pick up lens may be dirty or has gone bad. Most Philips units are exchange items only, meaning they replace it under warranty instead of fixing it, if its out of warranty there usually are no parts or service information on them. Philips was bought be Funai and is not the company it used to be. Check if the unit will play a audio CD, if it does the pickup assembly is bad, some will play a CD but not a DVD. You may be able to clean the p/u lens with alcohol and a Q-tip. The lens is under the clamp that holds the disc while spinning.
May 26, 2009 | Philips DVDR3320 DVD Recorder/VCR
GoVideo DVD combo
Hi - I can record a dvd from the tv and can play it back but when I try to play a store purchased dvd it ejects the dvd and on the tv screen it says unknown disk, please, check disk again.
Aug 19, 2008 | GoVideo Go Video DVD/VCR Combo
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
My DVD recorder won't play my CDs
Recently purchased a unit... You can imagine the joy when I found in Manual: Audio discs can only play if in .mpg or .wma formats! Yes, all the bells and whistles except the most basic of functions such as all common audio formats. Other portable $99 dvd player works with them.
Dec 07, 2007 | LG RH1999H DVD Recorder/HDD Recorder
Unknown disc error
In my dvdr630vr plays only audio cd`s. Same problem?
Oct 28, 2007 | Philips DVDR630VR DVD Recorder/VCR
DVD Recorder/Player won't accept DVDs
I think your Laser Lens or drive needs to be cleaned
Sep 18, 2007 | GoVideo Go Video VR3840 DVD Recorder/VCR
Televison & Video Logo
142 people viewed this question
Top Televison & Video Experts
