Question about Panasonic PT-43LC14 43" Rear Projection HDTV
New bulb replacement
How long do you suppose to hold volume button on tv and split screenbotton on remote until lamp resets.thanks
  • r_pennino Aug 12, 2008
    I tried this procedure on my tv which is also PT-43LC14, the red light goes out but when the pitcure comes on it tells me to replace the light and timer.
  • 47 Answers
About 5 to 10 seconds. If you're having issues there are a few things to check and try:
-make sure it's the right remote.
-make sure the remote is in TV mode (it's a universal remote)
-make sure you're aiming the remote at the IR sensor on the set (easiest if it's in your left hand).
If you've checked all of the above, there are a couple of other things you can try if pressing and holding the buttons together do not work:
-Try pressing and holding the VOL- button first then a split second later hit the SPLIT button on the remote, then hold them both together for the specified time. also try the opposite.
Posted on Mar 09, 2008
I replaced the bulb in my tv. pt44lcx65. everytime i turn on the tv it says i need to reset the bulb timer? how is this done? thank you.
Instructions should be with new lamp. Press and hold volume down on TV front while pressing PLAY, or SPLIT, or PIP on PAN TV remote aimed at little window on TV front near front panel buttons for 5 seconds. Message will appear on screen saying lamptime reset. Press end to exit.
May 02, 2010 | Panasonic PT-44LCX65 Television
How do i reset the hour meter on my panisonic
RESETTING LAMP HOURS
Consult Your owners Manual but this works for most Panasonics
Turn on Power
Press and hold the "vol-" button on the front of unit and the "split" key on the remote together for over 5sec.
Screen should say " Lamp time was reset to 0"
Nov 23, 2009 | Panasonic Televison & Video
Unable to reset Lamp Hour Meter on Panasonic PT-50LC14
Try this, using the Panasonic remote, wait until the notice about your lamp goes AWAY (it wont work with the message still up).
Hold the volume down on your tv while holding the split/play button on the remote.
You will get a notice about 4-5 seconds later that it was reset.
May 29, 2009 | Panasonic PT-50LC14 Television
I was wondering if you could tell me how to reset the timer after I have installed a new lamp. Can you help me? tv is a panasonic pt-56dlx25 Thanks, dave
Plug the power cord back into the properly grounded wall outlet. Then press the POWER button on the projection display or the remote control to turn the power on.
2. While pressing the VOL- button on the projection display, hold down the PIP or SPLIT button on the remote control simultaneosly for more than 5 seconds.
3. Whe the lamp time reset procedure is complete, the screen will display "LAMP TIME WAS RESET TO 0." When the lamp time is reset, the LAMP indicator will go out
Dec 30, 2008 | Panasonic PT-56DLX25 56" HDTV
Reseting the lamp meter on tv
1) Press the POWER button to turn your TV on. Make sure you are set to Cable/TV reception. If the "replace lamp. Reset Lamp timer" notice appears, press "EXIT" on your remote.
2) Press and hold the VOLUME DOWN BUTTON on the TV set (not the remote, the actual TV set)
3) Continue to press and hold the VOLUME DOWN button and press and hold the PIP (Picture in Picture) or SPLIT/PLAY button on your REMOTE control (your are pressing and holding BOTH of these buttons at the same time now).
4) After 5 or 10 seconds (be patient), the lamp serice menu will appear and say your lamp counter has been rest to '0' (zero). That's it, you are all done.
Now, I continue to have the power shut off after a few minutes of play. I think it is a problem with the cooling fan. Damn it all anyway.
Dec 21, 2008 | Panasonic PT-43LC14 43" Rear Projection...
Panasonic PT-61LCX65 Bulb Reset
hold the volume button down on the t.v. & the split button on the remote at the same time for about 8 to 10 seconds.The t.v. tech. did this with my panasonic 61lcx65. Also I had 2 fairly large red / orange & 1 blue spots on the screen which I thought were a result of the bulb being bad , but the tech. attached a device he called an eeprom jig & it reset the chip ? Now the picture is like new again.
Sep 17, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
PT61LCX65 lamp timer
Hold the volume down button on the tv until the volume is at min. then continue to depress the volume down button on the TV. While depressing the volume down button the tv hold the pip or split button on your remote for approx 5 sec. You will see a box pop up that says lamp timer reset and gives instruction on how to exit.
Jun 02, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Lamp Hour Meter
This proceedure should work for your model to reset the lamp meter.
Lamp Time Reset Procedure:
Be sure to reset the Lamp time to "0" after replacing the new
Lamp.
1. Plug in the AC Cord, and turn on the power by pressing the
POWER button.
2. Press and hold the VOLUME DOWN button on the unit and
the SPLIT key on the remote together for over 5 seconds
in power on condition.
When the reset is finished, the display will indicate that the lamp hrs have been reset to 0 and the LAMP LED goes out.
Mar 29, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Resetting bulb tyla1000
Most modes can be reset by holding the volume down button on the tv until the volume is all the way down. Continue to hold the volume down button on the tv and while depressing the volume down button on the tv press and hold the pip button on the remote until the reset message appears on the screen. Some models are different and while depressing the volume down button on tv press and hold the split key on the remote. Most times these instruction come inside the lamp box you purchased.
Mar 28, 2008 | Televison & Video
Lamp meter on Panasonic PT-40LC12 ?
I just had my picture go out two weeks ago. I took it to a local tv repair shop. They replaced the thermal fuse. I also had a spare lamp so they also replaced that. I'm not sure if they reset the lamp meter but this is what I found surfing around...try at your own risk. I'm going to try this when I go home tonight.
Good Luck...
Press the power button to turn the unit on.
While pressing the Vol-(volume down) button on the projection display,
hold down the PIP button on the remote control at the same time for more
than 5 seconds. When the reset procedure is complete the following message
will appear on the screen. "Lamp time was reset to 0".
Mar 16, 2008 | Panasonic PT-40LC12 40" Rear Projection...
Panasonic PT-43LC14 43" Rear Projection HDTV Logo
47 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
