Question about Medion MD-40954 Notebook
Updates not installing
Mim2120 medion laptop
  • mawia Mar 29, 2008
    thanks i will try that mawia x
    Sergeant:
  • 313 Answers
I have found, depending on the update, that downloading them manually to your desktop, then installing them from there usally does the trick. Just write down the KB number of the update and go to http://www.microsoft.com/downloads/Search.aspx and download.
Posted on Mar 28, 2008
Removed hardrive put it back now have a black screen
On startup press F2 or F12 or whatever key your CMOS recommends to get to SETUP. Is your Hard Drive recognized? Is the HD in SetUp the same model as the HD you installed?
Jan 02, 2014 | Medion MIM2120 COMPATIBLE LAPTOP LCD...
Red light flahes even when power adaptor is connented
Most likely this is due to a faulty battery. This indicates that the battery is unable to hold a charge despite being plugged in with the power adapter.
Feb 28, 2011 | Medion MIM2120 COMPATIBLE LAPTOP LCD...
Battery wont charge and laptop wont start using
Check the pin inside the connection (end of the cord) which you put into your machine, or check if the power connection on the circuitboard is damaged (you are able to wiggle it a little bit around)
Dell computer use the pin inside the connection from the adapter to recognise if the adapter you are using is a dell adapter or not. If the pin is damaged, or you are using an adapter from another brand. You will not be able to charge, but only power your pc.
Jan 04, 2010 | Medion Computers & Internet
How do I fit wireless card into medion mim2120 laptop?
I assume you mean "wi-fi" wireless access. The easy solution if wireless networking wasn't built in is to use a USB wireless adapter that simply plugs in to any USB connector on the laptop. These adaptors are available at retailers where you can buy computers as well as from many online sources. The adapter will come with any software and installation instructions you need.
Please take a moment to give this solution a fixya rating if it has been what you needed, and thanks for asking here!
Mar 05, 2009 | PIONEERPOS M55E25R30P PC Notebook
Medion laptop screen goes dark?
Shure 'nuff. Sounds like either the inverter or backlight. I would go for the inverter as that seems to be the more common item to fail, it usually is cheaper than the backlight, and easier to replace.
If you need to directed to an online maint manual, let me know.
Ron
Dec 10, 2008 | IBM ThinkPad 770 Notebook
Medion mim2120 Wireless Problems
I had similar problem with Medion WIN 2140. The harddrive crashed, I bought a new drive and had to reinstall Windows from scratch since I had neither a backup or burned the reinstallation CD's. First I installed Windows7 and every driver/application/BIOS available from Medion's download site. At first my WIFI worked OK but somtime during the process og BIOS/driverupdate my WIFI antenna turned off. The antenna can be turned on/off with a easy access button (touchpad to the right of powerbutton) but WIFI button dows not work.
Medion's danish supporters told me that Windows7 is unsupported. So I had to reinstall using Vista. Still not able to turn on WIFI. I'm pretty sure that BIOS prior to version 1.0K (dated 06.01.2010) had a "ON" possibility but is now limited to "OFF" og "LAST STATE".
Medion support wouldn't og couldn't provide me a previous version of the BIOS. In fact Medion DK's support doesn't seem to know anything about their products.
However I have found the solution myself. Launch Manager application is needed for Easy Access buttons to work. Current version 1.5.0.5 of the application is faulty. In registry i found that pressed keys call the file fn.exe, this file is not a part of the OS, Launch Manager or any other Medion driver/application.
I googled for and found the prevoius version 1.4.9 of Launch Manager. This version works without any problems on both Vista and Windows7.
http://www1.medion.de/downloads/?op=search&lang=au&type=TEXT&Param=
I wrote to Medion support to replace the faulty application on their support site. But with my current Medion experience i daught they will do anything about it. So instead I post this reply to help others.
Oct 15, 2008 | Computers & Internet
Laptop keyboard not working medion mim2120 notebook pc
this and my mouse have also stopped working, idk the problem but i fixed it once and whenever i wanted to turn it off i just put it into sleep and it worked fine when i started it up. i came to a situation where i had to restart the computer and it didnt work again and now i cant fix it.
Aug 18, 2008 | Computers & Internet
Keyboard on my Medion MD 40812 PC Notebook will not work
the keyboard needs to be check to see if it is not clip in propery or if the keyboard need to be replaced.
Aug 18, 2008 | Medion MD-40954 Notebook
Medion MIM2120 Laptop
Remove the large panel (7 screws) on the base of the machine.
The memory is situated under a black flexible plastic cover about 75 x 30 mm - amost directly below the earphone and mousepad area.
Memory is held in position by clips at each side - press them outwards and memory card will pop-up.
A second card can be fitted below and slightly higher than the first.
I have just fitted IGb and will probably put in another (max 2GB), - cost about £15.
Hope this is of use.
Feb 23, 2008 | HP Pavilion dv6000z Notebook
Medion MIM2120 laptop
press the blue button botton left of the keyboard that says Fn (function)
at the same time press F1 this will enable the laptops wireless connection, this should be shown by the light 2nd from the right
Dec 04, 2007 | Medion md40298 Notebook
Medion MD-40954 Notebook Logo
91 people viewed this question
Top Medion Computers & Internet Experts
John Anderson
John Anderson
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
