No printing When I conect machine on my computer with USB conection and instal drivers for printer and scanner, I set all formats to A4 and send pago on printing, the machine start blinking and can not printing anything. What is my fault?
  • Nenad  Nedeljkovic
    Nenad Nedeljkovic Mar 07, 2008
    Thank you for help dear Jxxx, but I have already done both settings. I am working at service for copier,printing and fax machines brand RICOH, in Serbia. Last days we have a problem with Ricoh copier MP 1600L as never before. Today I have successfuly made this machine to work like scanner, but it`s no printing yet. This machine are coming with no software, only drivers. If you have any software for that machine it could be helpfull to me, I would really appreciate it.
  • Anonymous Mar 15, 2009
    where is located the imput for the printer
  • 33 Answers
Has your copier been set up with pin numbers or department counters, if so you will need to enter a valid pin no. in printer driver properties. Also go into printer properties and check printing preferences aswell as properties for any paper size/tray issues and remeber to apply any changes.
Posted on Mar 06, 2008
Can I connect canoscan 4400f using ethernet cable
i believe is not possible to connect to a router. printers ar designed to be connected to computers via ethernet cables and bluetooth when both devices are bluetooth enabled.(must have a wifi bluetooth ethernet card installed or usb bluetooth installed via usb). is you want to have the printer to be used bye more than one computer at home or office. you must set up each computer to the printer as well.. in control panel look for printers.then set up the conections.if computer 1 is printing a document. computer 2 will have to wait. when done. then will print work for computer 2.
Dec 18, 2012 | Canon CanoScan 4400f MultiFunction Color...
Hii i have richo c2530 printer and i change my pc now when i conect the printer with lan port it gives yelow colouer in network even i conecet usb prot and when i print somthing it gives me eroor info...
Hello!
If you change the conections to the machine you need to change the port of the driver.
For exemple: If your machine is conected by TCP/IP you need to put the correct port in the driver properties.
If you conect to USB you need to chenge the port in the driver properties to the USB option.
If you have any doubt reply to me. I will be glad to help you
See you!
Sep 24, 2011 | Ricoh Aficio 2035 Copier
How to conect printer and i have only one lan conection it is not ossible to use at time net or printer
connect the printer to your computer through parallel cable or usb cable. install the printer on that computer and share it with the network. to share it, right click on the printer and select share. add drivers for other operating systems as needed. To set that printer up on other computers on you lan that might be wireless, just search for the computer its connected to through the network and connect to the printer. The computer that the printer is connected to must stay on so other computers can print.
Jan 14, 2011 | Office Equipment & Supplies
My Samsung printer is conected on other computer,and not printing
try to reinstall printer driver.
Be sure printer IP adres is correct.
Good Luck!
Jun 21, 2010 | Samsung ML-2251NP Laser Printer
I can't get my print server LPV2-USB-TX1 to work with my lap top. The print server is conected to my wireless router. Do I need to intall driver on my laptop? My operting system is windows vita
Are you able to print from any other computer in the network ?
If you are able to print from any other computer that means your print server is set up properly.
On your laptop you will need to add port for the printer.
make sure that the printer drivers are installed.
Click Here for More info
Oct 06, 2009 | Buffalo Technology LPV2-USB-TX1 Print...
Scanner does not work It keeps telling me "no conncetion to computer" but the printer is conected . I can copy from the computer. Wher can I find an instruction manual for Officejet Pro L7590 My last HP...
The Driver of the scanner and driver of the printer, this two miscellaneouses of the driver, in addition is fixed. Attentively install both drivers with mounting disk. Else use the cable USB from kit of the supply, scanner can not work since long шур USB.
Sep 25, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Need cd to install lexmark 4200 fax, scanner and printer
try this link..
http://driverscollection.com/?H=4200%20Series&By=Lexmark
OR
http://www.soft32.com/Download/Free/Lexmark_4200_Series/4-176522-1.html
this web page has a Lexmark downloadable driver scanner.
will search your computer for missing drivers - turn fax/printer on first (and have it conected to computer)
Jul 05, 2009 | HP DeskJet 932c InkJet Printer
Printer keeps saying usb not conected
Can you print from it? It sounds like you just need to install the software that came with it, it has all the drivers you need or go to hp website and download the newest drivers. Update your drivers and then it will recognize it.
Jan 08, 2009 | HP Photosmart C4280 Aio Printer
Ricoh 1018d not print with lan conection
Hi Usama,
I had the same proplem as you when i installed pcl6 driver on my ricoh 1085
I solved but by uninstalling pcl6 driver and installing pcl5e
for your 1018d try this driver for windows XP D O W N L O A D H E R E
BTW.
about using 1085 as a scanner ,
I don't know what is "scanner interface drive board" ?
more help please.
Oct 23, 2008 | Ricoh Aficio 1085 Laser Printer
Scanner doe not work,fax and print are ok
first re-install product driver properly then try.
Jun 03, 2008 | HP OfficeJet 6210 All-In-One InkJet...
123 people viewed this question
jasbo
jasbo
