Question about Sennheiser 604B Professional Microphone
E604 how do i get inside to check the wires
  • Anonymous Mar 31, 2008
    Same problem here, the mic went dead and I want to pop er open to have a look...
  • Anonymous Feb 13, 2009
    All I managed to do so far is remove the front grille. Looks like one could push out the entire innards somehow
Ok all you have to do is remove the front grille. Then, with a small screwdriver carefully go around the inside of the casing to remove the glue and the you can push the innards out!
Posted on Feb 13, 2009
I have the same problem. I have had a go at getting inside but it definately looks completely sealed. I know it is still under warranty but I recon it is just a dry solder - I am considering busting the outer case to have a look...
Posted on May 29, 2008
I have canon ir400 machine... it displayed error codes e604 and e315... what i do? plz help me...
E604 The image memory has a fault.
The RAM has a fault.
The expansion memory is not mounted properly.
E315 The image data coding mechanism has an error.
The coding chip has an error.
The image memory has an error.
If you have installed expansion memory I would turn off your Canon, uninstall the memory and turn on the Canon.
If the error is gone, try to print something.
If you are able to print without error then try re-installing the RAM and make sure it's in correctly.
Then see if the error is gone and try to print.
Sep 24, 2015 | Canon Office Equipment & Supplies
Wiring diagram electric hob
www.electroluxappliances.com/Owner-Support
Aug 14, 2013 | Electrolux E604-220V50HZ Model E604 Floor...
Electrolux e604 polisher
Jun 27, 2013 | Floor Polishers & Buffers
Switch main power off and on e604
The error code E604 means that your hard drive is failing or it has failed. You will have to replace the hard drive and have it flashed with the software to run the copier.
Dec 07, 2012 | Canon imageRUNNER 400S Copier
My Canon copier, Model IR 400s, Shows the error code : E 604. What is the problem ? How can I Solve it ?
Problem :
E604 Error Code. You followed all the troubleshooting steps in the service manual and still have an E604 code.
Solution :
Check the Image Server Memory or the Image Processor PCB. The recommended Image Sever Memory should be Kingston 32MB, 144 pin EDO Module, 64 Bit, 60 nanoseconds, No Parity.
Jul 13, 2012 | Canon imageRUNNER 400S Copier
I have canon ir400 machine... it displayed error codes e604 and e315... what i do? plz help me....
Sir i have recently purchased IR 400 canon photcopier my problem is the machine is giving error 604as soon the machine is started problem . plz solve my problem
Jan 06, 2011 | Canon imageRUNNER 400S Copier
My Canon copier, model IR 400s, Shows the error code : E604. What is the problem? How can I solve it ?
Sep 25, 2010 | Canon imageRUNNER 400S Copier
E355 0001 E604 0000 E020 4b00
You should really be more detailed than that.
E020 is a drum code, magenta if i am correct. Replace that and that should take care of that one.
E604 i believe is the finisher (going from memory). Haven't seen a E355.
If you are having this many error codes, call a canon technician. it could be something that connects the 3.
Nov 15, 2009 | Canon imageRUNNER C3200 Copier
Juan martinez
Hello pastor015,
Wow, copiers and networking them have been the way I have fed myself for 20 + years. And I come to this site to be helpful as I enjoy helping others. But I have to admit that I have been presented with so little i
getfile.asp?rid=1258 July 17, 2002 getfile.asp?rid=3215 Product : imageRunner 330 / 400
Title : E604 Error Code Problem :
Solution :
Canon USA, Inc. Systems & Technical Support Division 1-800-528-2830 nformation. One word and a code. Ok.
Apr 26, 2008 | Canon imageRUNNER 400S Copier
Sennheiser 604B Professional Microphone Logo
117 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Vito Vacirca Jr.
Rob Beech
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
