Press and hold the green button on your printer and turn the printer on. You will see that the lights flash for a moment and then turn off. After a few seconds, the attention light will turn on followed by ready light and the green light. Keep pressing the green button. In a few seconds, the attention light and the ready light will turn off.
Push the toner rotate button while you continue pressing the green button. As you briefly push the toner button, you will see the light flashing. Release both the toner button and the green button.
Repeatedly push the red button (cancel button). Now all the working lights on the printer will turn off.
Open and close the lid of HP printer once. The light will start blinking.
Press the green button. Your HP toner cartridge chip will be reset.
Yes, reset chips really work on laser printer cartridges, if you have a know good source for the chips and if you know what your doing, you can't put a new chip on an old cartridge, the chip is what registeres how may prints you will get out of the cartridge if you put a new chip on an old or 1/2 empty cartridge of course it will say it's full but then try and print.It will register as a full cartridge but it can only print with the amount of toner that is actually left in the cartridge, be careful there are alot of remanufactures out there that don't put new chips on or that do but don't fill the cartridge full, or replace all the wipers and drums, they just dump some toner in and say here you go, Only buy your remanufactured cartridges from a reputable company, do your research on them first or you'll be sorry
Open the "Devices and Printer" dialog, select "Printer Properties" from the context menu and go to the "Ports" tab. It seems that somehow your printer doesn't always get assigned to the same port. Try checking the correct port and your printer will be online again.
No need to drill holes. If you turn the cartridge with the drum facing away from you, on the left hand side, you should see a small block elliptical cover with a couple of divider on it. That is the cover for filling the cartridge. The problem is there is no available reset chip yet for clp-315.
