Question about Meade 8" LX90 LNT Schmidt Cassegrain Telescope with SmartFinder w/ FREE UPS
Meade LX 90 AutoStar problem
When I switch on the AutoStar and press 0 for Automatic Alignment it sends me to Alt/Az alignment and then gives instructions for a different telescope even after I've checked the right model on SetUp.
  • 3 Answers
One thing you can do is to completely reset the controller and reinput everything back into it.
If that doesn't work then you need a new hand controller.
It would be nice if you can take it to a local telescope shop and have them try your controller on one of theirs.
Tom Net
Posted on Apr 10, 2008
Procedure to set up a meade 12" LX200R on
It's pretty much all spelled out in the manual. Here:
http://www.meade.com/manuals/TelescopeManuals/LXseries/LX200-ACF_manual.pdf
You should train the drives, and purchase a separate 12 volt power pack with the correct cigarette lighter style power cable. Calibrate motors BEFORE you train the drives with the same power source you will use outside at night.
If this is a GPS model-- and new--- I would execute a RESET on the hand controller-- calibrate motors and train the drives and take the scope outside and get a Satellite link and do a two star automatic alignment.
Make SURE you are centering the correct alignment stars. By the way TRAINING must be done in alt az mode before you put the scope on a wedge-- it cannot be done in polar mode.
Sep 18, 2011 | Meade 12 Inch LX200R f/10 Advanced...
I have an older, let's say "classic" LX-90. My
You can try Three things:
1. Do you have fully charged batteries-- or a good power supply.
2. Sometimes the cable to the hand controller needs to be replaced
3. Execute a RESET on the hand controller and reload the firmware--
If these do not fix it, the hand controller is defective and must be replaced. You can find a used 497 controller for about $80 on AstroMart.com
and Meade can also sell you a new one.
Mar 07, 2011 | Meade LX90 8 (500 x 203mm) Telescope
Used autostar recently making a 2 star alignment. It worked fine, finding what I told it to. Then put it in "Sleep" mode for the night. Next session with it i was way off in finding the moon. Any ideas...
Putting it in sleep mode (or what we call PARKING the scope) only works if the scope is permanently mounted or can be setup on it's tripod EXACTLY as it was in the previous session.
For portable scopes that you move in and out of the house this will not work. Just do a two star alignment and normal setup each time you take it outside.
Oct 25, 2010 | Meade Autostar Suite Autostar Suite...
Meade LX200GPS 16" out of calibration?
Before you panic I would update the firmware/software on the telescope. With an LX200 interface cable you can upgrade the software in your telescope from your PC by going to Meade's web site at www.meade.com
Download Meade's ASU (Autostar Update Utility) and the latest software for your Autostar II absolutely free. You can also use the ASU to add Comets, Asteroids, Satellites, and User Objects to your Autostar II with a few simple clicks of the mouse.
I believe you can get the manual here.
Jun 04, 2010 | Meade LX200GPS Telescope
Inability for the telescope align
Replace the battery for the GPS.
Start from scratch.
Reset the hand controller, calibrate motors, train drives, calibrate sensors.
Make sure you have either fresh batteries, or better a seperate 12 volt power pack. The above will eleiminate everything except an actual BROKEN electronic part (such as a bad gps board).
If it still will not align using the gps, time to send it back to Meade for repairs. Make sure you have the latest firmware in the hand controller which is 43Eg. You can download the firmware using the UPDATER free software here:
http://www.meade.com/support/downloads.html
May 08, 2010 | Meade 8" LX90 Schmidt-Cassegrain Telescope...
When i turn my LX-90 8" telescope the GPS is not working.
After you RESET the telescope-- it returns to factory default settings--
1. Calibrate Motors
2. Train Drives
3. Set Time, Date, Site, and Daylight Savings Time to NO right now in USA
4. Calibrate Sensors on Polaris
5. Do an Automatic Alignment--
Here are all of Meade's manuals on line--
http://www.meade.com/manuals/index.html
Dec 30, 2008 | Meade 8" LX90 Schmidt-Cassegrain Telescope...
GOTO ERRORS MEADE LX200 10" CLASSIC
Most problems tend to be mechanical. Have you 'trained' the drive and set the backlash values? Those 2 can have dramatic effects on pointing accuracy. Also, if the optical tube is not in alignment with the mount, then nothing will work correctly. To check that, have the telescope in Alt-Az configuration, inside the house, loosen the RA lock, and shine a laser pointer on the corrector plate. as the telescope is rotated about the RA, the reflected spot should be steady. Adjust the DEC to minimize the diameter of the circle that is drawn. What is left, is the out-of-true on the DEC axis. That can be adjusted with the tube cradle alignment bolts.
Oct 17, 2008 | Meade Optics
Autostar 497 freezes
When warm and indoors (!) connect Autostar to scope and by serial lead to a PC, allow Meade Autostar suite to update the Autostar Firmware to the latest version (2009!!)
Frome www.meade.com/support/auto.html :
How To Upgrade Your Handbox
To upgrade your Autostar first click on the link below to download the Autostar Update (ASU) Client Application for Windows. If your web browser allows you to open the installation file, you may choose that option when prompted. Otherwise, just save the install file to your local hard disk drive. When downloading is complete, double click on the saved file to start the installation. Follow the instructions provided to install Autostar Update (ASU) on your machine. When installation is complete, start ASU by selecting "Start Menu" -> "Programs" -> "Meade Inst" -> "ASU". If you have an active Internet connection and your telescope with Autostar is connected using the appropriate cable as listed above, ASU will detect and install the correct Autostar code directly from Meade's web site via the "Upgrade Autostar Software Now" button.
Autostar Update
Autostar Update is an application that functions to transfer the event files and software updates from your computer, through the serial port, USB or Connector Cable Set depending on your telescope model. The Autostar Update application is available as a stand-alone client application for Windows. The most recent versions of AutoStar Update automatically check for the newest versions of the AutoStar Updater and download it if necessary. It is critical that you use the most recent AutoStar Updater to ensure that you get the proper software updates for your system.
06/02/09 Autostar Update (ASU) Client Application for Windows, Version 5.6 (1,654 KB). This is the latest Autostar Update. Rev. 5.6 is compatible with the ETX-LS and #497EP Hand Controllers. This version is compatible with all versions of AutoStar II and #497 AutoStar computer controllers. This installation will automatically update the Update Client Application in AutoStar Suite™ Software. If you have previously installed the Autostar Update (ASU) Client Application for Windows, Uninstall the old version before installing this new version. 07/27/09 #497 AutoStar hand controller software update. Version 5BE2 (1,039 KB).
General update. Fixes many known bugs. Real time clock corrections. LXD75 polar alignment. Various LX90 pointing and tracking fixes. Adds new magnetic/true north alignment.
REQUIRES VERSION 5.6 AUTOSTAR UPDATER.
Jan 17, 2008 | Meade Autostar Suite Autostar Suite...
Meade 8" LX90 LNT Schmidt Cassegrain Telescope with SmartFinder w/ FREE UPS Logo
133 people viewed this question
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Experi
Level 1 Expert
Greg Cann
Greg Cann
Are you a Meade Optic Expert? Answer questions, earn points and help others
