Question about HP Photosmart C3180 All-In-One InkJet Printer
Printer i have installed my printer but it is not printing it takes the paper through but comes out blank
  • 1 more comment
  • pumpskin Mar 05, 2008
    yes the printer acts as it is printing i have a new laptop it is installed ok on my old laptop it is only 3 month old i have lost my disc but have instaled with a friend disc from the same printer and yes i did removed the protective tape i printed only two weeks ago but with old laptop
  • asibp Apr 01, 2008
    I have installed hardware using the disc that was supplied. The printer does not react when the print icon is selected.
    It stared out skipping or passing two blanks sheets for everyone that was printed and now it want print at all. new printer.
    I have followed the steps provided.
  • Tygh Duval
    Tygh Duval May 11, 2010
    • Does the printer act like it's printing (i.e. print head goes back and forth)?
    • Is this a brand new printer?
    • If it is not brand new, how long has it been since the last time you printed anything?
    • If it is brand new, did you remove the protective tape from the ink cartridges?
    Sergeant:
  • 300 Answers
Solved
Posted on Mar 28, 2008
    Guru:
  • 731 Answers
I suspect that the Printer spool service is not communicating efficiently with the Drivers.Just follow the steps below.The problem will be resolved.
1.Right click on MY computer ->Properties->Hardware->Device manager.
2.You will get Device manager window popping out.
3.Scroll down to "Universal Serial BUS controllers".Click on the (+) sign.
4.Check for the "USB Composite Device" and right click on it, click Uninstall.(IMPORTANT NOTE:WE HAVE TO UNINSTALL THE PRINTER'S USB COMPOSITE DEVICE, TO KNOW WHETHER IS THE PRINTER'S USB COMPOSITE DEVICE, RIGHT CLICK ON USB COMPOSITE DEVICE AND PROPERTIES,look for wat location says, Eg -LOCATION : HP PHOTOSMART C3100)
5.Disconnect the USB and reboot the PC.
6.Connect the USB after reboot, you will get popup "Found new hardware".Then the Drivers will be installed Automatically.
Cheers
RIZ
Posted on Mar 06, 2008
PAPER FEEDS INTO PRINTER BUT COMES OUT BLANK
HP DeskJet f4280 Spitting Out Blank Paper. - HP Support ...
h30434.www3.hp.com > Printers & All-In-Ones > Print Issues
Solved: I can hear it printing, but the paper is blank when it's finished. ... Mark as New; Bookmark; Subscribe; Subscribe to RSS Feed · Highlight · Print · Report ... green checks say every thing is good to go, but the test print comes out blank,. ... Reinstall the cartridges into the product, and then gently close the cartridge door.
my printer is printing blank pages, and i just changed ink
Nov 18, 2015 | Office Equipment & Supplies
No print only a blank page comes out
Wrong printer drivers for your computer or else they did not install properly. Also blank page may mean you are out of ink/toner.
Aug 19, 2014 | Office Equipment & Supplies
Reading no paper paper tray is full
Instructions
  1. Check the display for an error message. If the display reads "Clearing paper from printer," the engine has detected a jam and is attempting to eject the jammed pages automatically. These pages will often be blank.
  2. Check the display for "Performing PRINT/STOP TEST" or "Performing SERVICE TEST." Either of these messages indicates that the printer is going through a test procedure that may eject blank pages.
  3. Reduce the amount of paper in the input tray if the printer is feeding multiple blank sheets at a time. The printer will pull extra pages through if the input tray is overfilled.
  4. Replace the paper in the input tray with the correct size if needed. If the 4600 printer detects the paper as an incorrect size for the print job, it may eject the paper without printing anything on it.
  5. Replace the ink cartridges if certain colors are blank on the page. Replace the black cartridge if printing a black text document that is coming out blank. The printer may attempt to print even if the ink level is low or empty, but will unable to print anything on the page, causing it to come out blank.
  6. Remove the sealing tape from newly installed cartridges. The tape covers the print heads and should be removed before installing the cartridges. If the tape is left on, it will prevent ink from getting on the pages as they print.
  7. Press the "Check mark" button on the control panel to enter the printer menu. Run a diagnostic so the printer can attempt to determine the cause of the blank pages printing. Press the up or down arrow to select "Diagnostics." Press the "Check mark" button. Press the "Down" arrow to highlight "PQ Troubleshooting." Press the "Check mark" button. The printer runs a diagnostic and returns to a ready state when done.
Jan 08, 2011 | HP LaserJet 4600 Printer
Printer keeps printing blank pages non stop going
drop kick unit across room:)))) sorry just kidding I had the same problem with mine. If the computer is continually printing that means the printer is receiving print orders from your computer. Best thing is just disconnect the printer from the computer and turn the computer off and wait 30 seconds then turn on . This should clear the print cache then reconnect the printer. Make sure to only request one print at at a time.
if the printer continues to print blank pages check to see if you have the latest software driver for the printer installed on your computer. You can do this by going to the manufactures website and download the software its easy to do just follow the prompts and install! Hope this helpful!!!
Jul 24, 2010 | Epson Stylus C84 InkJet Printer
I can not get it to print anything but blank psges
hi
if your printer taking papers it mean your printer is working fine chack your cartrege
clean your cartgerges
Jun 03, 2010 | Brother MFC-5890CN All-In-One InkJet...
Printing but blank pages coming out .
Take the ink cartridge out of the printer. On the bottom of the cartridge, there's a copper/gold surface with bumps and holes. Take a napkin or peice of paper and rub it on this surface. This serves two purposes - if there's any dried ink or blockage, it will help clean it, and it's a test to see if there's any ink left in the cartridge. On a normal ink cartridge, rubbing paper on the bottom would cause some ink to smear onto the paper. If nothing wet comes out, the ink cartridge is dried out or empty. You'll need to replace it.
May 19, 2009 | ASUS Intel 810E Chipset CUWE-RM...
CX3810 printer will not print
Take out the cartridges from the printer, put them back.
Remove the printer completely from your computer. Reboot. Re-install the printer.
Try to print again.
It sounds like your print heads are shot.
Nov 21, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Printing problem
download the drivers and install it
Apr 11, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Printer problem
This may sound silly, but I've seen it done many times. When you installed the new ink cartridges, did you take the little piece of tape off the printhead? It's put there to prevent leaks, but it also prevents printing if it's not removed.
Aug 27, 2007 | Xerox DocuPrint M750 InkJet Printer
Printer Problems, please help me now!
Un install the software. Reboot the computer Come off line Disable the A/V software Reinstall the software and take not shortcuts - do exactly what the install programs wants. Reboot the computer Now try
Apr 12, 2007 | Canon Pixma MP500 All-In-One InkJet...
HP Photosmart C3180 All-In-One InkJet Printer Logo
93 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
