Question about JVC TH-S3 System
Missing lead where can i get a lead to connect my subwoofer to my system from speaker is sppwm303 system is JVC THS3
  • 298 Answers
You can find the cable you are looking for below.
TH-S3 Subwoofer Signal Cable
Posted on Mar 05, 2008
  • 61 Answers
Typically i would say connect it in parallel to the right or left channel..assuming your system dosent have a sub woofer output and your subwoofer is powered
I am thinking about purchasing the Pyle Home PCB3BK bookshelf speakers. Before I purchase, I need to know how they are connected? I have a JVC CD player that I want to connect the speakers to.
Any search engine will lead you to details about the speakers.
http://www.pyleaudio.com/itemdetail.asp?model=PCB3BK
They're passive mini cube speakers. Unless your unidentified CD player has amplifiers and connections for speakers you are missing the crucial middle piece. What were you going to do about bass?
Aug 11, 2011 | Pyle PCB3BK Speaker
My JVC THC30 subwoofer won't power on therefore no sound since all the speakers run through it. How can I fix this or is there a way to replace just the subwoofer?
If you're saying you have a defective subwoofer that keeps the system from coming up you might find one on eBay. many owners of HTIB's sell off the remaining bits as parts die off.
Or maybe your subwoofer comment is not related to your power problem.
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Apr 18, 2011 | JVC THC3 Home Theater System System
No sound out of subwoofer
Connection from receiver subwoofer output jack RCA plug male go into your powered subwoofer low level input with other end of cable, then you need to select Subwoofer YES/NO on the JVC receiver speaker setup menu option, select YES if this is a powered subwoofer you are using, should power up the subwoofer, may have to adjust a test tone balance for multi speaker output also, try trimming up on the subwoofer channel to initiate the signal on if the sub has an auto-on feature.
Feb 07, 2009 | JVC RX-5020VBK Receiver
I need a connector lead to be able to fit a jvc cd player into my ford fiesta and cant seem to find one anywhere!help!i only passed test 4 wks and want some music!!
Hello, if you do not have the lead that connects into the jvc radio you will need to go to a car radio shop but if you have that lead but not the one that connects to the car leads then you will need a ford to iso adaptor lead which you could also pick up at your local car radio shop or maplins
Apr 24, 2008 | Car Audio & Video
JVC TH M505 Subwoofer not working
i need to find the wire that connects from the subwoofer it has like little spikes inside the medal part and the spikes broke off
Jan 12, 2008 | JVC TH-M505 System
JVC THM303 - No Sound
Its your wire connection problem. Plz check that all the wires are connected to specific location. If wiares are ok then it might be internal circuit error! that should be repaired at authorised service stations.
Dec 07, 2007 | Audio Players & Recorders
Subwoofer???
You should double check the wiring.
Sep 08, 2007 | JVC HX-D77 Shelf System
JVC THP7
you need an optical lead, connect the optical lead from the back of the ps3 and connect it into the dvd players optical in.
I am looking at this one too but dont know whether it has an optical in, could you let me know on, mathewsellar@hotmail.com
thanks bud
May 04, 2007 | JVC SX-XD33 Speaker
Subwoofer JVC TH-M606
What system are you using it with, how do you have it connected, when you say the system does not work as a result, does it mean that the system does not power up, or no sound?
May 19, 2006 | JVC TH-M606 System
JVC TH-S3 System Logo
107 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
