Question about HP DeskJet 3320 InkJet Printer
Print error Message is displayed "Page can not be printed due to system error" when print command is given. Problem is not solved by restarting window or by uninstalling and reinstalling printer sofware again.Please help on this issue
  • Sunil Gusain Apr 04, 2008
    I have same problem.
  • Anonymous Mar 16, 2014
    error no. 0024 displayed when print command is given
    Sergeant:
  • 458 Answers
Check the ink and anything else that you can. A piece of paper could be stuck somewhere. Your ink might need reseated.
I can't fix this for you, but if I helped you get it fixed, please rate it as a fixya not a helpful rating. These ratings let me be allowed to help you and others in the future. If you need more help, feel free to keep asking, but keep the original information so I can see it.
Make sure that it is set as the default printer and it is set as online.
Posted on Jun 06, 2008
  • T&N Family Electronics Dean and Sherrie Terrell
    Did you solve your problem? Let me know if you are still having problems so I can help you more.
    Are you still having this problem? Did my answer solve your problem?
    Rate this as a Fixya if it is fixed.
After giving the print to immage runner 400s copier the print sends to the copier. The data button blinks once. but print out automatically cancels. why?
Windows Server 2003/Thin N Computing thin client L300 Printer Epson FX2175 installed with thin client when dos base print command is given 1st page is printed but when 2nd print command is given printer gets offline either switch off printer before giving comman or print from printer properties. Again third page print command is taken by printer (For alternate pages print command printer gets offline automatically)
Aug 29, 2012 | Canon imageRUNNER 400S Copier
Tip
HOW TO CHECK AND FIX PRINT SPOOLER SERVICE THAT CAUSES UNABLE TO PRINT FILE...
Print spooler service is a computer service that loads the print jobs into the printer memory for later printing and it acts as intermediary between a computer and a printer. When the print spooler service is stopped or malfunction, printing is not possible.
Here are the possible reasons :
1. Virus or Malware infection.
2. Spooler service was stop by accident or turn off to manual/disable mode.
3.Faulty installed printer driver that contains error or incompatible with previous printer drivers installed in your computer or system.
4. Print jobs and drawing jobs were corrupted by accident which caused print que lock and resulting print spooler service to crash.
5. Your printer had printing problem issue with pdf files.
To fix this problem, you have to check if the print spooler service had stop.
Here's how to check and fix the print spooler service.
Go to START
Choose RUN
Type SERVICES.MSC
Click on PRINT SPOOLER and check if the STATUS IS STARTED
If not, on the upper left side, click on STOP to stop the spooler service
Then click on RESTART to restart the spooler
Restart your printer and your computer
Then try to print again and it will surely solve your printing problem.
Another procedure :
Go to START
Right click on DOS command prompt and run as administrator
You should be in this command directory before you
Type CMD and be sure you are in this directory C:Windows\System32
And if not, type this to change the directory, CHDIR C:Windows\System32
Type NET STOP SPOOLER and message will appear like this
Exit and go to C: DRIVE
Choose WINDOWS and click show content if not view all the folder files
Choose SYSTEM32
Choose SPOOL
Choose printer and delete printing jobs if any
Again right click on Command prompts and run as administrator
Type NET START SPOOLER
Exit and restart your printer and your computer
I will works fine right now.
NOTE : You can bypass the C:Drive procedure and just type NET STOP SPOOLER AND NET START SPOOLER in the DOS COMMAND PROMPT if you believe that there are no printing jobs pending.
Another procedure is to download this troubleshooting software and follows the troubleshooter wizard and it will fix your print spooler service automatically and some common problems as well.
Click here to start downloading.
I hope it helps you solving your print spooler problem. Regards to all readers.
on Mar 24, 2011 | Office Equipment & Supplies
Printing not possible . message " print spooler service not ready"
As most people run Windows on their computer, I will describe how the printing setup works on that operating system. The *nix and Mac operating systems differ slightly in the details but verall are set up similar.
There are two parts to the print dialog box on Windows. The first of these is part of the Windows API (Application Programming Interface). The API is a set of common code pieces that are held in the various DLL (Dynamic Link Library) files that are part of the Windows operating system. Any Windows program can (and should) call the API to perform common functions such as displaying the Print Dialog box so that it will work the same way in all programs and not have different options in different places the way the print option did back in DOS program days. The Print Dialog API also provides a common interface allowing all programs access to the same set of printer drivers rather than printer manufacturers having to create driver software for their printer for each individual program that wanted to use it.
The printer drivers are the other half of the print dialog. There are several different languages that different printers understand that they use to control how the page prints (eg. PCL5 and Postscript). The printer driver instructs the Print API as to how to translate the standard internal print format that the operating system understands into the custom markup language that the specific printer understands. It also adjusts the options that the Print dialog displays to reflect the options offered by the specific printer.
An individual computer may have no printers installed, it may have one local printer, it may have access to several printers over a network, it may even be set up to print to PDF or preformatted print file. Where more than one "printer" is defined one of them is designated the default printer which means that it is the one that displays its details in the print dialog when it first appears.
The operating system keeps track of the default printer and identifies that printer to the various programs on the computer. This allows the programs to pass an extra parameter to the print API telling it to print directly to the default printer without displaying the print dialog first. Many programs have two different print options - a menu entry that displays the print dialog and a toolbar fast print button that sends direct to the default printer.okay another one is
A print spooler is software that temporarily stores print jobs on the computer hard disk or in memory until the printer is ready to print them. If you've been waiting an unusually long time for a document to print, or if you see an error message about the print spooler, spooler subsystem, or spooler resources, you might need to change and then restart the Print Spooler service on your computer.
To do this, we recommend that you save your work, and then restart the computer to restart the Print Spooler service. If you don't want to restart the computer, try these steps instead.
To change or restart the Print Spooler service
You must be logged on as an administrator to perform these steps.
  1. Open Administrative Tools by clicking the Start button , clicking Control Panel, clicking System and Maintenance, and then clicking Administrative Tools.
  2. Double-click Services. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. Right-click the Print Spooler service, and then click Properties.
Dec 19, 2010 | Office Equipment & Supplies
My canon has an error b200 and it doesn't print or do anything I command.
Well every advice is the same except a little altered (use a warm cotton swab to clean inside machine and on print head channels) but then it says if possible replace print head but honestly this has become a primitive Machine for turning humans into corpses - buy a new one.
Nov 02, 2010 | Canon PIXMA MP620 All-In-One InkJet...
Bad ESC Seq
The ‘Bad Esc Seq’ message on the MT645 indicates the printer is not recognizing some of the commands it receives in the data from the host computer system. These commends are sent in the format of Escape Commands Sequences hence the ‘Bad Esc Seg’ error message displayed on the printer.
There can be a number of reasons for the printer displaying the ‘Bad Esc Seq’ error.
The first thing that it may be worth doing would be to power the printer off then disconnect the printer from the computer system. Once the printer has been disconnected from the computer system power the printer back on again. If the ‘Bad Esc’ Seq’ message is seen when the printer is disconnected from the computer system this would tend to indicate there is a fault with the printer.
If the printer powers on OK and does not display any errors when it is disconnected from the computer system it is possible that one of two things is happening.
The first thing is that a print job has been sent to the printer using the wrong printer driver on the computer system, this will send data to the printer that it does not recognize. If this is the case the print job on the computer system would need to be cancelled and resent using a printer driver suitable for the MT645.
The other thing that may have happened is that the Emulation setting on the printer may have for some reason changed so the printer not longer matches the set up on the computer system. You may need to change the emulation setting on the MT661 so it matches the host computer system set up. The printer may need to be set to either Epson or IBM emulation depending on the computer system set up.
The Current emulation setting on the printer can be found by printing a configuration page, this can be done in the following way;
Put the printer OFFLINE
Press the MODE button
Press the DOWN ARROW until HELP is displayed
Press ENTER
The printer will print out a configuration page showing the current settings, this will include the Emulation setting. This can be checked to ensure it matches the computer system set up, or change to ensure the emulation is correct for your application.
If you are printing from Windows try printing using the Generic Text only printer driver, this will not send escape commands to the printer, so should print correctly. If you still see the Bad Esc Seq message I would recommend having a look into the connectivity between he printer and the computer system.
May 22, 2009 | Tally MT645 Printer
Hp 3325 printer printing test page and not printing other pages
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
Apr 06, 2009 | HP DeskJet 3325 InkJet Printer
My canon mp210 is not responding to printing requests. we have replaced both colour cartridges. note: printer will photocopy a page, but again, it will not respond to request to print a word document, for...
Is there any blinking of light when the print command given. Any error message at printer display or Computer Screen ?
There is some problem in printing options. Please check and make default setting in the Printer properties. Go to Control Panel --> Select the printer --> Open printer window --> properties --> make them defauls --
During print command check whether the spooling in printer window goes completely or not (if it stop in middle )
Let me know in brief to solve this problem before going to reinstall printer drivers and do not vote till you recieve a good solution for this problem.
Nov 08, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Paper size won't print
First customize the paper size in the Page Setup. Secondly when you send command for print, change the paper size to custom size from the Printer Properties and click print. On the other hand, you can select the paper size from the printer's menu itself after sending the print command. Please make sure that the right driver of the printer is installed on your computer.
Hope it will help and fix your problem.
May 22, 2017 | HP Photosmart 3210 Printer
System error in printer hp deskjet 3320
Normal 0 In XP go to Control Panel
Open System
Click the Advanced tab
Click Settings under Performance
Click the Data Execution Prevention tab
Make sure Turn on DEP for all programs is NOT checked, check Turn on DEP for essential Windows programs.
Apr 04, 2008 | HP DeskJet 3320 InkJet Printer
HP 7260 works fine with e-mails and documents. Does not print internet pages.
This sounds like an issue with your web browser. Which web browser are you using? Do you get any error message when you print? Also, when you print, make sure it is printing to the printer you think you have set up. The web browser will allow you to print to a different printer, then remember those settings.
You may also try this link in google:
http://www.google.com/search?hl=en&q=internet+explorer+cannot+print
Jan 01, 2008 | HP PhotoSmart 7260 InkJet Printer
HP DeskJet 3320 InkJet Printer Logo
57 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
