I have a 32" Samsung HD plasma TV that has developed a high pitch background noise coming from the back/side of the TV that becomes worse the longer the set is on. Transformer ?? Only bought the TV on Jan. 13!
  • joborders Jan 17, 2009
    How do I tighten the Transformer? I have a 46 inch Samsung that sounds like a fricking chainsaw...lol Thanks!
I phoned the Samsung service people and am awaiting a return call for a home service visit. Thanks.
Posted on Mar 06, 2008
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Dec 13, 2015 | Televison & Video
High pitched noise coming from back of Viore LC32VH56A. Not speaker related.
A refurbished set!
Its a coil or transformer that is not tightly mounted or is vibrating hard enough to make the sound, If this is a refurbished set that is why it was returned and exchanged-----
Two ways to fix---locate which board is bad and correct the problem with Hot glue on the individual part making the noise OR just replace that board.
Dec 08, 2012 | Viore LCD32VH56A 32" HD LCD Television...
How do I stop the static noise from my vizio tv?
At high altitudes all plasma tvs will emit a high pitch noise.
There's nothing you can do about it besides move or get a new tv. Plasmas just do this.
Mar 07, 2011 | Vizio P4 46 in. HD-Ready Plasma Television
Replaced the lamp in Samsung hl-s5086w and now T.V. won`t turn on but has a high pitch noise coming from back of set.
The high pitch noise is the color wheel that needs replace the noise is coming from a bad bushing that goes to the color wheel and is a common problem.
Dec 13, 2010 | Samsung HL-S5086W 50" HDTV
Hd tv makes a hjgh pitched sound whats wrong
Hi, the high pitched sound is coming from the coils or transformers on the power supply.
you can isolate the noise by removing the back and with the set on press gently with a plastic handle/item on each coil till you stop the noise. , you will probably have to replace the coil or the whole power supply, but sometimes you can tilt it over or secure it with silicone and it will stop rimging.
please click a thumbs up it this helps solve your problem
Eric
Aug 19, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
Samsung LNT3253H is making a high-pitched noise
I had the same issue. The tech that came out today removed the transformer on the power supply board, "resealed" it, and replaced it (re-soldered the same part back on) -- the transformer apparently vibrates because it was not properly sealed. BTW, mine was about the fifteenth that he has performed this repair on within the past couple of months -- all 32" and 26" Samsungs. Now, it appears to be absolutely silent.
Mar 22, 2008 | Televison & Video
High Pitch Noise on 42" PLasma Gateway TV
how old is your plasma TV? try check the switch / volume of the sound settings.. Sometimes, when you always increase the volume, it will tend to alter the limit of sound and causing the sound to provide sound undesiredness. I suggest to check it with a liscensed technician.
Feb 05, 2008 | Gateway PLSM42TV 42 in. HD-Ready Plasma...
High pitch noise
Hello there, You have to specify where the noise is coming from. Is it coming from the speaker or from the back of the unit. SMPS power supply powering your unit create this kind of noise when some capacitor gone out of their value.
Good Luck.
Jan 26, 2008 | Samsung LW26A33W 26 in. HD-Ready LCD...
High-Pitch Noise
Problem with your TV audio processing unit. Damaged audio processing IC must be the coz. else audio amplifier IC must be faulty. Contact service centre authorised personnel
Nov 17, 2007 | Samsung TXN3245FP 32" TV
Weird noise over everything
According to the Samsung website: "The high pitched sound you hear is probably coming from the flyback transformer. The flyback transformer converts the relatively low voltage electricity that comes from the outlet in your home to the high voltage electricity needed to drive the cathode ray tube in your TV. It is not unusual for a flyback transformer to buzz softly when it operates. However, if the sound is loud and high pitched, it probably means the transformer is failing. To eliminate the sound, you will have to get your TV serviced."
Nov 08, 2007 | Samsung SlimFit TX-S2783 TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
