Question about Dell 1600n All-In-One Laser Printer
Dell 1600n printer
We need to replace the separation pad in the paper tray on the above printer.
What part is it called?
  • 105 Answers
Not sure what you mean. Can you describe the "separation pad" color, size, apparent feature, please...
Posted on Mar 27, 2008
Hp laserjet p3005dn printer taking 3 papers
Your problem description is not clear, but based on experience I bet that your printer is taking three sheets of paper at a time. The pickup roller in tray 2 and the separation pad in the tray are probably worn out. They are easy enough to replace. You can verify that printer works properly by printing from manual feed tray and if that works ok then above solution is likely your fix.
Apr 14, 2014 | HP LaserJet P3005 Printer
My dell mfp 1600n will not feed paper without jamming in the auto feeder...what is wrong?
if the problem is with the paper from tray, suspect the rubber tires on the pick rollers are bad. You can remove them and flip them inside out and reinstall
Dec 31, 2010 | Dell 1600n All-In-One Laser Printer
Frequent paper jams on a Dell 1600n AIO, sometimes doesn't grab the paper from the tray (not really a jam, just need to open and close tray), sometimes gets caught halfway through the path -- need to open...
This could be caused from the papers you use at times(weight). Call on a Dell representative to check it out for you if you bought it from a Dell shop.
Aug 19, 2009 | Dell 1600n All-In-One Laser Printer
My printer says I need paper. It has paper. Will not print or copy
Try to update the Firmware, or check the sensor of the feeder could be out of place and doesenot recognize the paper.
Jun 17, 2009 | Dell 1600n All-In-One Laser Printer
Feeder dosen't pick paper up from tray
Steps you should follow;
1. Clean roller with Isopropyl alcohol not water /soap.
2. goto or to order the needed parts.
Good Luck,
Rich Lilja
Apr 08, 2009 | Dell 1600n All-In-One Laser Printer
Dell Printer 1600n
Check your manual feed tray. The printer may have a print job in memory that's pointing there.
Aug 13, 2008 | Dell 1600n All-In-One Laser Printer
Document Jam in Dell 1600n
The Automatic Document Feed (ADF) has a white rubber pad that wears out. You can find it by opening the ADF cover and removing the roller bar. Under that is the white rubber pad. Pinch the sides together and the assembley comes out. Contact Dell for the replacement. You may also refer to the Dell 1600n Owners Manual for instructions.
Jun 14, 2008 | Dell 1600n All-In-One Laser Printer
Rear output slot
What do you mean? Do you actually want the paper to deliver out the back? Do you need the part that goes to the back so the paper delivers properly? Explain...
Call Dell Services. They will be able to help you purchase any part you need.
Mar 11, 2008 | Dell 1600n All-In-One Laser Printer
Printer Jamming with too much paper
This is a common problem with HP printers. I can't say that I have worked on a Dell printer but they probably use the same or similar mechanism to pull paper from the tray. The problem is a worn separator pad which costs about $5.00. The real cost will be in getting to it. It is not something for a novice to try. Better take your unit to a reliable repair shop.
Jun 22, 2006 | Dell Inkjet 720 Printer
Dell 1600n All-In-One Laser Printer Logo
63 people viewed this question
Top Dell Office Equipment & Supplies Experts
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
