Quartet gbc 4220S Shredder Logo
Posted on Mar 06, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Maintenance What type of maintenance should be performed on this shreader?
A Miller
Level 3:
  • Master 8,404 Answers
  • Posted on Mar 06, 2010
A Miller
Master
Level 3:
Answers
8404
Questions
Helped
2051849
Points
24677
Oil periodically using special shredder oil. It goes on the paper as you shred it. Dont overload the shredder. Empty regularly. Dont wait for it to shut off due to being full. Check your owners manual for other particulars for this make and model.
Have a Staples Model SPL-727MM paper shreader that won't work. Probably jammed, but unable to open it. Found some screw holes in where the tray pulls out, but regilar screwdriver won't fit, too long. Does...
I am sure you have already solved it or moved on but johnd393's comment at https://www.fixya.com/support/t1766897-disassemble_mailmate_spl_727mm helped me.
To reach the screws in the tray drill 6 holes in the bottom plastic and use a really long screwdriver to access them.
I used a 12 inch uxcell #1 Phillips screwdriver, which also worked on the 2 long screw holes hidden under the feet. You could probably get away with 10 inch or a #2 Phillips but with #2 screwdrivers check the width of the shaft first as the screw holes under the feet were too small for the #2 I originally bought.
2answers
Shreader ge105 manual
There's a website that has all this information about all this and manuals everything totally free there are many actually but I personally like few .. let me know if u need help
thanks
It has toner but no print is coming out on paper
Please try to perform a maintenance cleaning as this is caused by a clogged nozzle.. this may also depend on the type of printer you are using.... by the way what type of printer are you using as the maintenance can be performed by either thru the driver (on your computer) or through the printer itself. the process is called HEAD cleaning.
do it for about 3x. note: head cleaning takes in ink and may cause the ink level to go down.
hope this helps ...
Have a Troy Bilt chipper/shreader model 47285. I
Taked the broken belt to the auto parts store for a replacement.
PS60C-2 Shredder: Fellowes P50CM paper shreader motor runs but cutte...
One of the drive gears has stripped its teeth, usually caused by overloading the machine. These are personal shredders and parts are not available in my experience.Sorry.
1helpful
MTD chipper shreader
Sounds like the carb is gummed up. Do a complete carb cleaning and see if it helps.
Drive gear for staples shredder Model# SPL-770M is worn
is it the drive gear or is it that the shreader is dull that makes the shreader sluggish?
2answers
Blade gone south (shreader)
www.gopresto.com you can order parts here!
Please rate this FREE response!
The shredder runs perfectley in the reverse direction, but does not run at all in the shredding direction
I have seen many shreaders that are caked with paper underneath the blades.
After you remove the power, turn the shreader upside down (if possible )and completely clean the area.
Make sure you use shreader oil after you clean it
FELLOWS PS 65C SHREADER
There is probably astripped or broken gear inside the gear box.
Top Quartet gbc Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Quartet gbc Office Equipment and Supply Expert? Answer questions, earn points and help others
