AUDIO Dear Expert: I own a GE Model No. 3-5375 Microcassette Tape Recorder. I purchased it about five years ago. It is a great device, yet it has a sound playback problem. The problem it has can be best described as during playback of a previously recorded tape, when I try to turn the volume to a higher acceptable volume for playback, after about after a one "increment" increase of two and a half allowable "increment" increase turns of the volume dial, the tape and its audio playback demonstrate interruptive "sound skipping" and distortion. It is necessary for me to obtain a louder volume playback because I want to transfer some tape recordings onto a CD-R by use of a computer tape recorder software. Otherwise, it would be helpful to eliminate the problem that is encountered when a higher volume level is more appropriate for audio playback for general use. Also, if a simple repair can be made to eliminate the audio playback problem, that will allow for higher quality recordings on the microcassette player because uniquely, when the volume control dial is adjusted during recording, such can provide for higher quality recording onto a microcassette tape. I can be successful with simple repairs with small electronic devices. I personally think that if I had a small can of silicon spray, that might eliminate the problem. By the way, I know where I can order one. I mention that because during audio playback, there is a noticeable causation of the problem with the volume dial as a higher volume is attempted. Yet, sometimes that may not be the complete solution. I will appreciate your forum feedback. Thank you, TEXASDUDE2008
  • ROBTHEDUDE Mar 09, 2008
    Hey Robotek
    Thank you for the helpful info. I found a retailer who
    sells crc2-26 lubicant. Good news is that before
    I purchased some I sort of experimented by simply
    removing the cover of the microcassette player.
    I readily found the problem.The plastic case and
    some of the (usually) required slide controls were
    causing for the volume dial to be pressed, causing
    for fluttering and distortion noise. The components
    are just too compact and also too tightly secured
    together.
    I corrected the problem though. By my simply
    being more careful with replacing the plastic cover
    helped tremendously. One other thing, even the
    weight of the internal circuit board will later cause
    for the small volume dial to become pressed. So
    now, I will playback tapes with the recorder placed
    upside down on a pad.
    I just thought that I would tell you the good news
    if you happen to check back to learn of my results.
    Thanks again for your good advice.
    Regards,
    TEXASDUDE
  • 1,512 Answers
Hey Tex
You are on the right track, sounds like a noisy volume control. Can often be repaired with a squirt of cleaner spray into the potentiometer assembly.But I suggest you use crc2-26 contact lubricant spray, not silicone spray which is a great materials lubricant, but not electrical. Worst case, the Vol Potentiometer, may have to be replaced. Go for the CRC first and see how it goes. Good Luck, happy FixYa
regards
Graeme
Posted on Mar 06, 2008
How to set up Panasonic videotape recorder
was this the one seen in the 1960 lost in space tv show meant to be in the future of the year 2000. Guess they never thought of devices being smaller or digital.
https://www.youtube.com/watch?v=VA_sd229TVM
https://www.youtube.com/watch?v=Quf6FeOnk-M
it is not a video recorder it is an audio device built in 1969
The first VCassetteR or VCR were sold by Sony in 1971.
betamax was 1975
vhs in early 1970
Aug 14, 2016 | Panasonic Vintage Rq-705 Reel To Reel Tape...
Cannot play a VHS tape. Push in and pops out.
The belt on the loader motor is slipping. This causes the tape to not completely position itself to allow the tape to load around the drum. The machine senses this and ejects the tape.
Feb 20, 2014 | Samsung DVD-VR375 DVD Recorder/VCR
The voice recording fades in some parts
- Possibly the recording head may need cleaning and demagnetizing.
- The tape itself could be damaged or even folded.
- It may be also because one or both backup pads are missing on the microcassette.
There should two pads behind the tape as shown below.
May 31, 2011 | Sony M475 Handheld Cassette Voice Recorder
I need to get a new external mic for it. Where
Hello if your unit has a 3.5 jack I recomen this two
http://www.tvps.com/Products/ECS-35-mm-Tie-Clip-Microphone---New__ECS-3-prd-5TCM.aspx orhttp://www.tvps.com/Products/ECS-35-mm-Conference-Microphone---New__ECS-3-prd-5CM.aspx
Dec 21, 2009 | GE 35383 Handheld Cassette Voice Recorder
20 year old Dictaphone Voice Processor Microcassette not working
Not sure if you're still having problems with this portable, but the first thing I would check is to make sure that you've put the batteries UNDER the battery clip in the battery compartment. Does the machine just make a 'beeping' noise when it tries to play, rew, or FF?
Apr 04, 2009 | Dictaphone 1243 Handheld Cassette Voice...
Lanier VW-260 recording speed
Should be a tape speed switch on that unit under the door.
May 23, 2008 | Lanier 260T Desktop Cassette Voice...
Dubbing vhs to dvd
Easy. Connect RCA lead from video/audio OUT on the VCR to video/audio IN on the DVD recorder. Set DVD recorder source to VIDEO then press play on the VCR and record on the DVD recorder.
Sep 09, 2007 | Aspire Digital AD-8091 DVD Recorder
161 people viewed this question
 Grubhead
Grubhead
