Question about Epson Stylus CX6600 All-In-One InkJet Printer
Epson dx9400f wireless connect to dell laptop with vista
The add printer function finds the printer but then asks for the disk - there are two disks - neither of them seem to work - updating printers doesn't bring up the dx9400f in the epson list
a friend has managed to get my laptop (not this new one) working with the printer but what should be easy IS NOT - help!?
  • Patrick Michaels
    Patrick Michaels May 11, 2010
    well..that's true..if you wish to have a E Housecall, send me a note (email in profile) and we may get you up and running soon.
I HAVE A ESPON CX6600 PRINTER AND A DELL LAPTOP HOW DO I CONNECT THEM BOTH TOGETHER SO WHEN I PRESS PRINT IT WILL PRINT FROM MY LAPTOP TO MY PRINTER
Posted on Jul 21, 2008
Wireless toshiba laptop not connecting
You didn't mention your model number for your printer. On your printer, go to settings and print your wireless specifications page. Your printer IP will be there.
You can also have your computer search for your printer!
Oct 15, 2013 | Epson Office Equipment & Supplies
Vista to Vista wireless, Can't share printer
So your third laptop which runs Vista cannot connect to the Printer and Dell machine?
There are some reasons for that. First check whether you have access to the Dell machine (whether you can reach it) Open a command prompt and do a ping to verify the connectivity. Example. ping 192.168.1.2 (The ip address should be the one of your dell machine. You can find it by running ipconfig in a command prompt on Dell machine.)
1. If you cannot reach it you have to check the network utility (wifi or any other method you use). Make sure that it function properly. 2. ping the router using router's ip address. If ping works you can reach up to their. So from there you can check the Lynksys management console to know why it blocks the machine entering the wlan. May be a addressing issue or authentication issue. If you cannot reach it however it might have problems with the connection as well. Make sure that you allow connections to the wlan on Toshiba Vista laptop if you use a antivirus solution with a firewall or any other firewall.
If you can reach the machine (or even if you cannot reach) you must check whether you have access to the workgroup (you have to join if you are not in the workgroup which you use) and you must enable file and print sharing. If you run the windows firewall that would block you in as well. Its better if you can check whether the print spooling service runs. Start -> Run Type in services.msc Hit enter. Check and enable the service.
If you can reach the Dell using a ping: Check whether the dell machine can access the laptop. Use my network places. It will ask you for the credentials. Provide them. If any error occurred try detecting the network. Add the machine properly to the workgroup. Enable access to the machines via file and print sharing in windows firewall. (go to the firewall go to Exceptions tab and select the File and Print sharing)
Check this Microsoft resource as well.
Please rate the answer and a testimonial (comment) if the solution helped you to solve the problem...Thanks for contacting Fixya
May 30, 2010 | Linksys WRT160N Wireless Router
Can't get epson Stylus nx400 to print from wireless laptops. printer connected to desktop with windows xp pro. both laptops use windows vista home premium.
As your printer is not wireless itself you need to shared the printer. To enable this goto Control Panel on your desktop, select printers, right click your printer and there should be an option for sharing. Enable sharing.
Now using your Vista laptops you should connect to your home network (in your case this is probably a wireless router, as long as your desktop is connected to this router too), goto Control Panel, printers, add printer, search for printer not connected to this copmputer (or network printer).
Hopefully the Vista laptops will then pick it up and install it correctly. You may be asked to install the correct driver for the vista machines. Windows should provide you with instructions on how to do this.
Hope this helps, www.PuterCare.com
Feb 20, 2010 | Epson Stylus NX400 InkJet Printer
I have a dell studio laptop 1735 model with a dell 305 wireless printer, worked grat for almost a year. may have a virus on my laptop had acorrupt file in the OS system windows vista. finally reloaded...
1. disconnect the parallel cable and uninstall the printer
2. check to see if you need to de fragment the hard drive.
3.. reinstall the drivers for the the printer from the OEM disk ( the disk that came with the printer.
4. Visit the manufacturers site for troubleshooting the wi-fi connection to the printer.
5. Hope this helps
6. Dell will usually assist with this issue.
Sep 28, 2009 | Dell Studio 1737 Laptop
I need to install online without disk my Epson cx9400fax allinone
Hi There, go to this website and download your Vista driver Here
1. http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=58773&infoType=Downloads
The driver you need to download is the one that says "Printer Driver V6.51"
Good Luck Let me Know
Then just install the software, and you should be able to print no problem....Cheers
May 25, 2009 | Epson Stylus CX7800 All-In-One InkJet...
Have misplaced the disk I need to add my printer to my new puter
Try add/remove hardware and when it asked for information you can go to the web or try the windows directory and the the directory inf (This is a system directory and you may have to display hidden files and folders) You could also download drivers from driverguide.com
Jan 22, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Add Printer
The Z22 does not appear on Lexmarks vista compatability list and so there is no specific vista driver.
There is a driver for Windows XP which you could try
http://downloads.lexmark.com/perl/downloads/downloads.cgi?ccs=227:1:0:0:0:0
Select Z22 as printer model and search
then choose windows XP from the list of operating systems
Nov 23, 2008 | Office Equipment & Supplies
Dx9400f wifi dosent work computer wont see printer after setup ive tryed contacting epson but they are no help, it is ok during setup untill you remove the lan cable then nothing. do you think it could be...
Hmm, not easy to say, are u using a laptop to connect your printer or are u using a ordinary pc connecting thrue a wireless router?
Give me some more info and i will try to help you.
Nic
Nov 19, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Epson Stylus CX6600 All-In-One InkJet Printer Logo
371 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
