Question about Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark X1185 does not print in colors
Black prints fine. Color cartridge does not print. It is the second I buy. Tried switchin ports placing black in color port and color in black port. Color prints, but black does not. What else can it be? - burthole had a solution, but I could not understand the steps to clear the problem.
  • Reinaldo Egusquiza Mar 14, 2008
    I am running windows 98 SE - The soution seems to be for Windows 2000 and XP
    Genius:
  • 2,035 Answers
Please do not cartridge positions this may damage ur printer ,check if the cartridge has ink in it..
Windows 2000Lexmark X1185 does not print in colors - 1.gif / XP:
Go to Start, Settings, Printers1.gif. (Windows XP: Start, Control Panel, Printers and Faxes).
Right click on the printer icon and select Properties.
Click Printing Preferences.
Click on the Quality/Copies tab.
un check mark Print Color images1.gif in black and white.
Click Apply and then OK.
This start ur printer to printer to print in colour
Posted on Mar 14, 2008
  • Anand Kumar
    Anand Kumar Mar 15, 2008
    For 98:
    Start >control panel:Right click on the printer icon and select Properties.
    in black and white.
New print cartridge not printing
-detached the cartridge
-wipe the cartrdge well
-attached it back(make sure you put it in its proper way the black and color cartrged)
-unplug the switch and cable of the printer
-try print
Thank you
Nov 14, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Clogged print head
Please click on this link:
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:435:0:0&framed=&docid=ENUS18888&relevance=1
Even after cleaning you get the same results you need to contact lexmark and get the cartridge changed as the cart comes with 6 months warranty ...good luck...
Jul 16, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
My lexmark X1185 all in one printer will not print color.
did you make sure that you pulled all of the tape off the bottom of the cartridge. next recheck your settings. they will not return to normal themselfs
Jun 09, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Lexmark All in one printer
looks like you may need to replace the black cartridge.
usually when you open the cover of your printer, cartridge carrier will move to the center. that's where the cartridges are, you can open it buy pushing it down and release it.
you can also checked lexmark site for this
check out this link too.
x1185 and x1100 are most likely the same.
http://www.lexmark.com/publications/pdfs/x1100/eng/ug.pdf
Mar 26, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark X1185 won't Print Color
On your printer, there is a clean print head adjustment,it is in your menus on the printer itself, It should also be on your print driver in properties. I would try running that up to 5 times before proceding to anything else.
Check and be sure the cartridge expiration date is not exceded. The liquid ink cartridges have an expiration dates. Even though the cartridge is new, Do not rule out a bad or for some reason dryed out cartridge or blocked port at the bottom. If it is indeed brand new and you have the receipt, I honetsly would suspect the cartridge itself.
Ok now, we tried the print head cleaning, and a second cartridge.
Next, I would remove the cartridge, turn the printer off and lightly, very lightly dampn a dusfree cloth with some alcohol, and where the cartridge is located, clean those contacts. reinsert the cartridge and see what happens.
Lastly, you can unplug the printer, remove the cartridges, and place a paper towel under the area where the cardtidge latches in, and dribble in a soapy cleaner, like fantastic, because those inks will dry out in the ports and not allow the ink to flow properly, If you do that, wipe all the excess cleaner up and leave the printer off for an hour or two to allow any remaining liquid to evaporate. Don't use a lot, but trickle it in until you see the ink start to wash out and all the ink is removed.
Take your time, and go from easiest to more difficult. I think that is the process I presented.
Feb 18, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark X1185 printer will not print color......everything else works fine
the ink is clogged not the cartridge but were the ink feeds into the printer. there should be a cleaner tab in the printer preference tab if available
Jan 08, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Prints only in black and white
Windows 2000 / XP:
Go to Start, Settings, Printers. (Windows XP: Start, Control Panel, Printers and Faxes).
un check mark Print Color images in black and white.
Dec 21, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark JetPrinter X1185 All-In-One InkJet Logo
302 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
