Question about Motorola Mobility H500 Wireless Headset
Cingular Palm Treo Bluetooth Connection
My treo finds my h500 but does not connect to it. When I click OK, It says unsuccessfull connection try again. I followed all the steps my the book. I don't get a screen to enter a pass key. Can you help me?
  • Anonymous Nov 06, 2008
    Im having the same exact problem, did you find a way that it'll work?
When the device is found it will seek the bluetooth device and prompt you if you want to bond the device...on yes it will ask for a pincode ...0000 worked for me just now.
All the very best~
Posted on Mar 11, 2008
I am trying to connect my palm treo with my lg keybo 2 using bluetooh in order to transfer my phonebook. the keybo finds my treo but when prompted for the passkey at the pairing window it always fails. I...
LG has a couple bluetooth keyboards. do you have the model number?
by the way are you pairing the keyboard to the treo or the treo to the keyboard?
normally there are 4 zeros are the normal passkey numbers for the keyboard
Nov 29, 2009 | Cell Phones
Palm Treo 500 will not charge through mains supply, but ok through USB connection. Have tried 2 power supplies and multiple electical sockets
then i would say the connector inside your palm is broken and needs to be fixed by a technician unless if you can find a connector and work on it your self
I hope this was helpful
Oct 29, 2009 | Palm Treo 500 Centro
Cingular palm treo 750 buetooth problems
Buy a blutooth that is compatible. Research the Palm Treo website for the type you want then check EBay or similar for a better deal.
Aug 25, 2009 | Computers & Internet
Unable to Synchronize with Vista 64 bit
Treo 650 can't be synced to Vista 64 via the cable, but Bluetooth works OK. Details later (I hope).
Apr 28, 2009 | Palm Treo 650 Handheld
Email connection problems on Palm Treo 755
on your Internet explorer browser go to tools and then select internet options and then click on the connections tab, make sure that the never dial connection is selected.
Mar 17, 2009 | Palm Treo 755p Smartphone
My Treo 755p will recognizes my new jawbone but will not connect. It seems to skip the step where I am supposed to enter a password into to connect to the jawbone. Any ideas? Josh
Delete any other bluetooth devices paired to your phone. Then, for the Palm Treo 755p . . .
To pair the Palm Treo 755p handset with the Jawbone, perform the steps listed below:
  1. Set the Jawbone to Pairing Mode.
    • For the Original Jawbone, press and hold down the Noise Shield button for at least three seconds until the LED Indicator Light flashes red.
    • For the New Jawbone, press and hold down both the NoiseAssassin™ Button and the Talk Button for at least three seconds until the LED Indicator Light flashes red and white alternately.
  2. Press Applications and select Bluetooth.
  3. Select Bluetooth On.
  4. Select Setup Devices.
  5. Select Trusted Devices.
  6. Select Add Device. (The Discovery icon appears, indicating that the discovery process is active.)
  7. Select the Show pick list and select Nearby devices.
  8. Select Jawbone from the Discovery Results list, and then select OK.
  9. Enter the PIN "0000" (be sure you are entering four zeroes and not the letter "O".) and select OK.
  10. Select Done, and then select Done again to return to the Bluetooth screen.
Your phone should now be paired with the Jawbone.
Jan 26, 2009 | Palm Treo 755p Smartphone
I have a Mac laptop, a Palm Treo Wx and am now using a Motorola H700. I need to know how to sync my H700 with my Treo so I can dial via my headset and not need to use the actual cell phone. It has now...
Hi, i'm not sure what the Mac has to do with your Headset. You can register your blue tooth headset with any device that supports bluetooth. In fact, you can use your headset with multiple devices. Even your Mac can use bluetooth to connect to a headset (if you have bluetooth turned on, and not all Macs have factory bluetooth).
To 'register' your headset with the Treo is a two step process.
on the Treo, make sure bluetooth connectivity is turned on, then you should have a menu that allows you to find/enroll a new bluetooth device. Before you tell it to find a bluetooth device, turn on your headset. Now tell the Treo to search for devices. If it doesn't find your headset, then press and hold the button on the side and it will send out signals that your Treo will see. The Treo might give you a password code and ask you to confirm this is the device you want to synch to. Usually '0000', but in any case say yes, so long nobody else is around trying to do the same thing you are within 30'.
That should do it.
I don't think the Treo has voice recognition, which makes dialing on my Nokia a breeze, for true hands-free operation, nothing beats it.
Also note, the Treo has been know to have issues loosing bluetooth connectivity with the headset and not reconnecting with a re-boot.
so long you keep the two devices near each other, this shouldn't be a problem.
stephen
Jul 05, 2008 | Palm Treo 700w Smartphone
MY TREO 650 KEEPS TRYING TO HOTSYNC(and its not connected to computer)
Did it actually reset when you did a hard reset ..or does it stay powered up?
Dec 31, 2007 | Palm Treo 680 Smartphone
Receiving MMS on Treo 650
That soulution dont seem possible with Palm treo 650 running Palm OS
Dec 13, 2007 | Palm Treo 650 Handheld
Motorola Mobility H500 Wireless Headset Logo
50 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
