Question about Philips 42PFL5332D 42 in. LCD Television
Sound problem cant get sound through x box 360 using component connection
  • 476 Answers
The Red/Green/Blue component connection only carries video. You will also need to connect the separate Red/White audio connectors to the audio inputs on the TV adjacent to the component input.
The yellow composite connection is not needed.
Posted on Mar 07, 2008
I have a 19 " sansul cant get my ilive sound bar
I hope this helps. You have to connect your sound bar to your cable box/satellite tv receiver. If you are connecting with composite or component cables you connect the video cables (either the yellow or the green blue and red cables) between the television and the cable box /satellite tv receiver. Then you connect the red and white audio portion of the cable between the cable box/satellite tv receiver and the sound bar. You are going from the OUTPUT of the cable box/satellite tv receiver to the INPUT on the television and sound bar. You use the function/source/input button on the sound bar to choose the space you plugged the cables into on it or listen to the radio or listen to your IPOD and etc.
Jun 10, 2011 | Sansui HDLCD-1900 19 in. LCD Television
When I turn on my xbox 360 I get sound but only a
this seems like a component cable issue, are you connecting the system to an hdtv? if so check the component connections to make sure its connected to the proper ports.
May 21, 2010 | Microsoft Xbox 360 Console
How to connect an Xbox 360 to an RCA RTD205 System?
you can turn every thing into surrond sound. all your visual componants, i.e. x-box, cable, dvd player and so on. connect directly to your tv, right? if so go to your local eltronics store and get youself an optical cable, typically $50.00 or so depends on the length. Go home with that cable connect it to the optical out on your tv and optical in on your reciever, (stereo) and bam all componants are now linked to your surroun sound. Dont forget to post your satisfaction. Be sure you have optical in and out before you go buy this wire. For god sake do not kink this wire either or you will have to buy a new. There is glass inside of optical wires, that transmits the light that the sound travels on.
Feb 25, 2010 | RCA RTD205 System
Trouble with 360 and hdtv
The cable your refering too are called Component leads.
The red and white are for your audio and the remainder are the video. All you need to do is connect the component leads matching up all the colour in the correct ports then using your av/source button change the tv to component
You will still have to connect the red and white audio cable to the tv as well.
that should sort your xbox out.
Little Dish Fitter
Sep 18, 2009 | Proscan PS36700 36" TV
For some reason you can only have the component leads with optical cable, if you put hdmi cable in there is no connection for the opticle cable out.
Jun 10, 2009 | Microsoft Xbox 360 Console
No sound from my xbox 360
You cant have HDMI and the xomponent cables pluged in at the same time.
to get audio to your monitor you will need an xbox 360 audio adapter. You can find that here.
That comes with the HDMI and audio adapter.
You can probabaly find it seperate somewhere else.
I hope this helps.
Dec 29, 2008 | Microsoft Xbox 360 Console
Sound no picture
your cables are probaly broken go to for trouble shoting tips.
Jun 19, 2008 | Microsoft Xbox 360 Console
XBox 360 and Other Game Connections
How are you connecting the XBOX 360?
Component? HDMI?
Make sure all connections are plugged in snug.
If you use HDMI then audio should work without seperate cable.
For component make sure red and white cables are also plugged into right spot on back of TV.
Hope this helps!
Mar 24, 2008 | Sony KDE-37XS955 37 in. Plasma HDTV
Xbox connectivity problem
As dumb as this sounds here is the mistake Sony made. The receiver does not process sound from the HDMI, it will only pass through that data to you TV. So you will not be able to get sound from your 5.1 speaker setup if you only connect the HDMI, you have to use the matching audio input for that respective HDMI input. Make sense? So the HDMI DVD Input must have digital coax for sound, HDMI Video2 must have fiber optic for sound, and there is another fiber optic port for the Sat input. Yes thats right, if you have 2 HDMI HD components and each only has fiber optic(neither one has digital coax) you cant hook both up properly the way you would think. Sony made this receiver poorly, turning High Definition Multimedia Interface into High Definition Multimedia Except For Audio Interface.
Nov 18, 2007 | Sony STR-DG510 Receiver
Xbox 360 no audio
if you are using the component cables supplied with the unit, there should be two plugs that you don't use, if you have them all in then thats why theres no sound. double check the colour coded plugs as you may have connected the wrong one as there are 2 you dont need to use
Aug 16, 2007 | Microsoft Xbox 360 Console
Philips 42PFL5332D 42 in. LCD Television Logo
44 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
