Question about GE WDSR2080D Top Load Washer
GE washer eill not drain or spin.
My washer model is WDSR208CDAWW. It is a GE top load washer and it will agitate but it will not drain the water out or spin. Please help.
  • 1 more comment
  • Anonymous Mar 24, 2008
    will not pump water out
  • wayne shearon Sep 23, 2008
    ge washing will not spin out
    GE top load will not spin out or drain everything else works
Water pump is bad or going bad replace water pump will fix this problem
Posted on Oct 23, 2008
    Problem Solver:
  • 8 Answers
If the unit is at least 4 or 5 years old, most likely the pump is clogged with the same hair.....that clogs vacuums. you probably can fix it yourself provided you can get to the pump without too much trouble. i'm not familiar with all the brands designs. maybe someone else on this sight can help. if this is not the problem than most likely some of the timers points are burned. if the unit is more than 10 years old and/or the unit has been used unusually alot there is the possibility that the transmission has problems, but that is pretty unlikely. hope this helps.
Posted on Mar 05, 2008
Washer fills with water and drains but will not agitate or spin out
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 26, 2010 | GE Profile WPRE6100G Top Load Washer
Kenmore Series 70 Washing Machine - won't drain water
WHAT IS WRONG WITH YOUR WASHING MACHINE?
small_11_21.jpg For a detailed Washing Machine illustration, click below.
redarrow.gif Top Load Maytag Style
redarrow.gif Top Load Whirlpool Style
redarrow.gif Top Load GE Style
redarrow.gif Front Load Maytag Style
redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Some problems that can occur with your top-loading washing machine are:
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
Hope this may help;
DON'T FORGET TO RATE:
Aug 10, 2008 | Washing Machines
GE top load Profile washer. Spin cycle not
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 11, 2010 | GE WVSR1060A Top Load Washer
I have a Kenmore top loading washer model #110 and won't agitate
First, see the Sears parts site for your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.23912100
Also see the Whirlpool (Kenmore) Service Manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
The first thing I'd try is using a different cycle. If the washer works as it should, the problem points to the timer.
I'd also check to make sure that when replacing the switch, the connections to the timer haven't come loose.
Since you've replaced the Lid Switch, the motor has power for the drain and spin cycles.
These washers use a reversing motor. The motor turns one way for agitating and reverses for the drain and spin.
Since you cannot hear anything when it is supposed to be agitating, the problem does point to the timer or motor.
Nov 14, 2009 | Kenmore 22422 Top Load Washer
GE Washer does not drain or spin
Inspect the drain hose for kinks
Test the timer control
Test the lid switch (some models)
Inspect the water pump
Inspect the drive belt (belt drive only)
Inspect the motor coupler
Jul 15, 2009 | GE WDSR2080D Top Load Washer
Washer filles with water can hear timmer then drains never spins
you have transmission problems. When your washer is empty and off you should be able to turnthe agitator by hand if you can't then the transmission is bad.
Apr 03, 2009 | GE WDSR2080D Top Load Washer
GE washer won't spin
you need to post your model number
Mar 31, 2009 | GE WDSR2080D Top Load Washer
Will agitate, but will not spin
hover gemini. mod.A6516-010 will agitate but will not spin.thanks .henry
Jan 01, 2008 | GE WDSR2080D Top Load Washer
GE WDSR2080D Top Load Washer Logo
129 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
