Cd dvd drive lost or corrupted
I cannot get my cd Dvd drive to work and get the above message how do I reload same. I have a medion computer running windows Vista
  • 133 Answers
The problem is normally caused by viruses, u need to conect it tp a network and clean it from another station.
Posted on Mar 06, 2008
My cd writer cannot connect. THe message E:/ is not valid comes up. I have tried inputting a CD Rom and also a DVD+RW. No joy.Can you help? Maria
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Jan 30, 2011 | Medion (40002895) CD-RW/DVD-ROM (Combo)...
I have a Medion DVD-/CD- Writer and it does not allow me to play certain DVDs and does not allow me to drag and drop photos to burn on to CD or DVD. I have gone to the Medion website to download drivers...
click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Jan 11, 2011 | Medion (40002895) CD-RW/DVD-ROM (Combo)...
My dvd ram is not working. Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) this message coming. whats the solution
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
  • HKEY_LOCAL_MACHINE
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • {4D36E965-E325-11CE-BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Dec 21, 2010 | Computers & Internet
I have a dell dimension 8300 computer/ windows XP OS with a Samsung Sd 616e internal dvd Rom Drive. When I insert a dvd or CD nothing happens, except a whirring sound of continuous spinning. Also, when I...
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Dec 06, 2010 | Samsung SD 616E (729507925578) Internal...
Was working fine! hard drive was replaced and lost oringinal operating system and drivers! i installed another operating system and lost alot of factory drivers and stuff! since then dvd will not play
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Dec 06, 2010 | Toshiba SD M1612 Internal DVD Drive
My computer dropped my DVD/CD Drive and I need to know how to find it
The CD/DVD icon would be missing
* Your CD or DVD Drive does not read or write and is shown as disabled
* The media in your CD or DVD drive cannot be read
* The media cannot be written to by your CD or DVD drive
* You receive one of the following errors:
A class specific or device specific driver is missing or corrupt
A CD or DVD drive cannot be found or is not connected
The CD or DVD drive is experiencing a problem
that prevents it from working properly
The CD or DVD drive is not accessible via an assigned drive
letter
This happens due to a variety of reasons.
This can be fixed, by rectifying some registry entried
Microsoft has a free utility to automatically run, to get this fixed : access this at : -
http://support.microsoft.com/kb/982116
http://support.microsoft.com/gp/cd_dvd_drive_problems
Or try the rectifying the registry by following the steps in the link above.
Sep 20, 2010 | Computers & Internet
The DVD/CD drive on my Medion 8830 PC no longer burns
Have you changed or upgraded your OS recently?
Looks like the drivers are corrupt or out-dated.
Might go to your computer mfg support site or the Drive mfg support site and download the latest drivers.
Uninstall whatever drivers are loaded reboot and reinstall fresh copies.
Nov 21, 2009 | Computers & Internet
Trying to run a sound card's installation CD on my DVD drive but CD won't run (new CD from Ebuyer) Believe my DVD drive may be faulty. How do I check if drive working and if not any way of getting it to...
have you tried another DVD yet? you might jsut be good spending the $20 on a new drive.
you could also try running a regestry editor to fix corrupted registry as it is a likely cause of drives not working
also, updating drives is good
Aug 03, 2009 | Computers & Internet
Deleted/Corrupted CD-Rom driver
Go to the CD drive manufacturers website. Download the latest driver for you model # from the support section. After downloading install. Hopefully that will fix your problem. Please remember to rate my answer. Thanks.
Feb 07, 2009 | Intel Motherboard
Media Center Receiver Service has encountered a problem and needs to close.
If you delete the information in the Control Panel and restart your computer, it will look for the driver by itself.
May 25, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
