Question about Hotpoint WD62 Front Load Washer / Dryer
Hotpoint WD61 stops near start of wash cycle
Washer/Dryer had clogged pump (too much dog hair!). Fixed this, but it still doesnt work . It seems to have worked briefly (one cycle), then stopped working again (:
If I set it to a wash cycle, the drum fills part way, the dial moves round to point straight
down, then the machine stops. Silent, nothing happening, it seems.
If I set it to spin, it pumps out all the water, the drum doesn't turn.
It moves on to tumble, the heater and fan at the top come on. And the drum emptying
pump continues to operate. It seems to do this forever.
Is this a sensor failure? Which one?
Whatever I try to do, it gets to a point where it gets stuck
  • renderer Mar 08, 2008
    I got someone in to fix it.
    The problem was the brushes on the main motor. Swapped these out
    for new ones and it was up and running. Of course the brushes were
    18 quid ($36), and the call-out and labour were 45 quid ($90). But
    the guy was confident and fast.
    Thanks for the suggestion about the timer. The guy said the extra load
    on the motor from not draining probably did for the brushes.
  • 3 Answers
Replace brushes on motor it is really easy to do. Take top off washer and you can get to motor quite easily. Mine running like a dream now. cost me £8
Posted on Nov 17, 2008
    Problem Solver:
  • 8 Answers
All in the timer. but there may be nothing wrong. sometimes in the cycle there will be a gap between water full and agitate or between drain and spin depending on settings. try it again and let it go and if there is a gap of more than 5 minutes than it needs a timer. most machines timers are right around $75 and you can most likely replace it yourself. sears appliance parts is the place to buy it. you can order it and they will deliver it to your door. or if you can get the phone # most of the outlets have a parts dept. also they take parts back for full credit for any reason.
Posted on Mar 05, 2008
Washer not draining
Please be specific about the washer...
Dec 06, 2017 | Maytag MAV7501 Top Load Washer
Can hotpoint wd61 be used as just a dryer?
you got to have the drain installed and run a cycle with water in so the the washer has water in so that it can condense the steam and drain it out. hope this helped.
Sep 01, 2009 | Washing Machines
Hotpoint Aquarius wd440 washer/dryer wont pump out water HELP!
Try unplugging the unit and plug it back in. This may reset the controls.
Jun 02, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius Model WD61 Washer Dryer working but it's noisey
If you've just installed it for the first time ensure that transporting locks been removed (big screws under usualy yellow or white plastic covers at the back side of the machine)
Make sure that machine is standing flat on the floor with no swinging whe you try to move it, this can be achieved by adjusting four legs of the machine (one at each corner).
If neither of those helps than you need to identify when the noise appears what machine is doing at that moment. If the noise appears when it's draining, pumping water out, than your machine's pump is wearing out, or if it's noisy when spining (final spin) than bearing of the drum is wearing out.
Update me about your progress
Good Luck
May 19, 2009 | Hotpoint Aquarius WD63 Front Load...
Working but making noise when spinning.
  • Hi,
  • Try these:
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion....
Door Locked. Cannot open. Washine inside.
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Mar 16, 2009 | Hotpoint Aquarius WD63 Front Load...
Whirlpool washer-dryer has stopped washing
Remove the pump system like this off the Hotpoint wd640 . Remove any blockage inside and retry.
Nov 10, 2008 | Washing Machines
I have a hotpoint wd420p washer dryer and its stopped mid cycle. its full of water and i need to know whats wrong
To fix the problem I stripped down the pump and discovered it was jammed with a hair clip!!
Aug 02, 2008 | Hotpoint Washing Machines
Hotpoint WD62 Front Load Washer / Dryer Logo
365 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
