Question about Gigabyte GA-K8VM800M Motherboard
SHARED VIDEO MEMORY
SIR,
I HAVE BEEN USING GIGABYTE FOR LAST 2 YEARS AND I HAVING A PROBLEM. I DON'T KNOW WHERE TO GO IN "BIOS" TO CHANGE MY SHARED VIDEO MEMORY, RIGHT NOW IT IS 64 MB AND I AM HAVING 512 MB RAM. I TRIED LOCAL TECHNICIAN'S HELP AND THEY WERE UNABLE TO DO SO. AND MY MOTHER BOARD MODEL NO IS
GA-K8VM800M
On the GA-K8VM800M, some bios options are hidden till you hit (either) control-F1 or alt-F1 - fairly annoying behaviour IMHO.
I'm not sure if the one you want is hidden or not.
Posted on May 31, 2008
    Sergeant:
  • 349 Answers
Go to this site http://www.gigabyte.com.tw/Support/Motherboard/Manual_Model.aspx?ProductID=1810 and download the manual, it should show you how to change the onboard video settings
good luck
Terry
Posted on Mar 06, 2008
My Dedicated Video Memory Is 64MB. How to i increase dedicated video memory.I Use gigabyte Motherboard
Hello here is the gigabyte homepage:
http://www.gigabyte.com/support-downloads/support-downloads.aspx
The manual can be found by, selecting the mainboard number.
The video memory can be changed in the bios settings, but can probably only be decreased to a lower setting.
I guess the 64 mb, is the max memory setting.
The solution is to add a better graphic card, on the mainboard for better performance.
A graphic card can be bought in a computer shop, or online.
You just have to know, what socket the mainboard has.
There is 2 different ones: AGP or PCI-E slot
Good luck
Mar 23, 2013 | Gigabyte Computers & Internet
Gigabyte G31
It is impossible to increase the performance of a built-in video card except increasing the video RAM. The more RAM you add the less main RAM will be allocated to the main memory. The reason is the video card uses Shared RAM.
To increase the video RAM go into the BIOS setup - video display - memory allocation.
The best way to improve is to install a video card in the AGP expansion slot, you may need to disable the on-board video in the BIOS.
Apr 06, 2012 | Gigabyte Intel G31 775 DDR2 )
I'm having a problem with HP DC7900 SFF. The Video Card shared memory is 1GB. according to there technical paper maximum should be 384MB only. I'm using winxp sp3 with 2GB memory. How can i change...
The amount of allocated shared video memory is configured in the BIOS configuration.
Go into the BIOS - video memory to change the amount of video RAM..
Jun 20, 2011 | HP Compaq DC7900 PC Desktop
Hi my name is sean and i have this exact board and i have 4 gigs installed ram and the bios is only detecting 3 gigs. I dont have a memory remapping featuer in the bios but the board does support 4 gigs...
Have a look at the BIOS settings, the built-in video card may be grabbing 1Gb for video RAM. The video card uses shared RAM (part of the main RAM module/s). You can change the video RAM allocation in the BIOS.
Oct 22, 2010 | ASUS P5GL-MX Motherboard
What is shared ram
Shared RAM this is a term use to tell the customer that the size of video will defend on the amount of RAM that the computer has, for example almost all laptop now is just using a shared RAM for the video card meaning if you have 1GIG or RAM and the video card can be set to 256MB so the 1GIG ram will be deducted with the 256MB that was allocated to the video RAM......
Nov 10, 2009 | Dell Studio 15 Laptop
Video memory sharing from ram
You can check your Bios settings to determine if sharing more memory is possible. You may wish to upgrade to more memory if you plan on sharing more with your GPU.
Nov 03, 2009 | Intel Motherboard
Dear Sir/Madam, i am using ASUS F-80Q laptop and the graphics is GMA x4500hd Gfx, it only shared 256mb memory, but i have seen about 1gb memory can this chip share (in fujitsu laptop)... there is no...
A BIOS firmware upgrade may allow the video RAM to be increased from 256Mb of RAM. Check the motherboard manufacturer's WEB site to see if this is possible.
Oct 06, 2009 | Asrock P4I45GV R5 Motherboard
REGARDING MEMORY
Sir you have to check in bios that nay mmory shared with grapihic also disabpel sahoadow memory.
Jun 09, 2009 | ASUS P5PE-VM Motherboard
ASUS P5VD2-MX SE video memory sharing
The message on the user's manual only indicates the possible maximum memory that can be shared with the video while in your bios you can see the actual shared memory. I think this could be case to do with the graphics card you are using i.e. is it onboard or an add on. In some cases too the manufactures of the motherboard are not the same manufactures of bios and therefore the manufacturer of the board has given it allowance to share up to 128mb while the bios manufacturer has given it up to 64mb. Remember many of the components on the board may come from different companies.
Aug 25, 2007 | ASUS P5VD2-MX SE Motherboard
TOTAL UPGRADE
>Can I upgrade the processor as well? Pentium 3 is compatible and what is the maximum MHz? Maximum CPU for GA-6BXE is Celeron-1400 (Tualatin core, with PowerLeap Adapter: http://www.powerleap.ca/Products/PL-370T.htm ...and patched bios by BIOS Patcher: http://forum.rom.by/topic5071.html&highlight=6BXE (last official BIOS don`t support Tualatin CPU-s) >A bigger HD will be compatible? With last F3a-version or patched bios - upto 128Gb. >The BIOS can aslo be upgraded? For max CPU / HDD - must be upgraded.
Sep 23, 2006 | Gigabyte Slot 1 GA-6BXE Motherboard
Gigabyte GA-K8VM800M Motherboard Logo
222 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
