Doesnt fill up
Had repaired today by sears for spin cycle problem.replced several parts and left now machine dont fill..is there anything i could do
    Problem Solver:
  • 8 Answers
Check the water valves that supply cold and hot water to the unit.
Posted on Mar 05, 2008
My Bosch washing machine won't turn the bowl
Hi Justene,
i Think its control circuit has a problem.
or the fuse for motor drive circuit is damaged.
please check with electrician.
regards.
nuwan
Jan 13, 2014 | Bosch Washing Machines
VBXR1090B WASHER DOESNT SPIN BUT WILL PUT RINSE WATER INTO WASH TUB
if the machine basically stops after the wash cycle, but prior to the rinse/spin cycle and won't do anything, yet when you move the timer into the rinse cycle it will fill with water as per normal, and again when it hits spin it stops.. then you have a bad lid switch, the lid switch can be accessed by sliding a putty knife between the top and front of the unit about 2 or 3 inches in from the corners and pushing in, there are hidden spring releases there that will allow you to pull the top of the front panel out, then lift if off its supports on the bottom, the top of the unit that has the lid switch can be raised by removing several screws from the brackets of the top. the part number for the lid switch is WH12X1043 $16 - $29..
good luck, have fun.
Aug 04, 2010 | Hotpoint VBXR1090B Top Load Washer
Kenmore 300 washing machine does not leave rinse cycle
This sounds like a bad timer. If the machine is several years old, the timer could be in need of replacement.
If you are handy, you can replace this device yourself and you should be able to obtain the part from any local Sears parts store or from the internet.
If you are not familiar with this kind of work, it would be best to have a technician replace the timer.
Jan 05, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
I have a kenmore series 70 washer, top loading. It filled up with water and then stopped. I have tried other cycles, but nothing happens. The water won't drain and there are no noises. Nothing happens no...
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.24712300
Also see the Whirlpool Service manual for top load, direct drive washers including test procedures and a troubleshooting section.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
If you manually move the timer to the spin cycle and it drains and spins, the motor and transmission are OK.
If it won't do anything after filling, the problem points to the timer or motor.
It is relatively easily repaired but you'll have to decide if the cost is worth the repair.
Personally, I tend to fix rather than replace so I'm probably not the one to ask.
Oct 31, 2009 | Kenmore 24712 Top Load Washer
Sears Model 110.26964503 washer -No Spin and drain
It appears your motor or motor controller board has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 18, 2009 | Kenmore Elite 45986 Front Load Washer
Wash cycle doesnt spin, spin cycle spins, but doesnt release wate
It appears your timer has failed in this instance.
Jan 31, 2009 | Washing Machines
Kenmore 90 series
These are typical symptoms of a broken motor coupling. Believe it or not, this is a common problem and very inexpensive to repair (about $15 or less). If you wish to tackle this job on your own, the following link gives you step-by-step instructions:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
The link also gives you the part number and which website you can order it from. If you do not wish to order on line, use the part number provided and go to your nearest appliance parts retailer. This is a common part that most retailers carry. I would recommend a Sears parts store or Whirlpool (your washer is manufactured by Whirlpool). Let me know if you require additional assistance. I hope this helps you.
Aug 28, 2008 | Kenmore 22422 Top Load Washer
Water will not fill .spin cycle and rinse cycle works maytag front loader 1994
Honestly do you want to stick money in a 14 year old Washer?
It sounds like a timer issue, if you can get a timer it will probably cost $100 american, and then next month the pump goes out,
To all my friends and customers I do not recommend repairing anything that is going to cost more the half of the cost of a new washer. Has the washer been fixed once before, to me that is strike two. Sears.com has a nice website to look at washing machine and features of all manufactures. We just bought a new frig and took them up on free delivery after rebate. And No I dont work for Sears.
Jul 03, 2008 | Washing Machines
Brand new Kenmore Elite Oasis washer leaks when on sheets and towel cycle and may in other cycles. After repair man was out and just stared at the machine, we requested that Sears deliver another one to...
on going issue..water tend to overspray at inlet left front corner especially during spin with heavy materials tub ring was reengineered but same problem let me know if you find a fix know of several others same situation guess a jury rig mught fix it or a redesigned fill cup
May 04, 2008 | Washing Machines
Kenmore front loading HE3 makes knocking sounds during spin cycle
Ours started knocking several months ago and then progressed to a high pitched sound when in the spin cycle. I manually turned the drum and heard and felt a bearing roughness. I lifted the drum assembly and felt a fair amount of play, which I think the initial knocking noise came from. On the sears web site a new rear drum mount cost 293.00. Today we went and bought a LG model wm2455hw at Home depot, on sale until 2/20/08. I couldn't see paying to repair a machine that only lasted four years.
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
