Question about Canon PC981 Copier
1/2 Page Darker
Recently changed cartridge, then had a power outage while copying...now there is a darker area on the copies.....1/2 page.
  • Mzpattic Mar 07, 2008
    I reinstalled the old cartridge and there is nothing wrong with the copy. Does that mean I need to return the cartridge?
    I appreciate your help.
    Thank you,
    Patti
  • Canon Expert
  • 1,326 Answers
Did you put the old cartridge back in with the same out come? Also when the orginal is being scaned dose the scanning lamp turn off in the middle of a copy?
Posted on Mar 07, 2008
Our copier is copying in light shade. how to make it darker
To adjust the default lighter/darker setting
1. On the LaserJet 3015, press MENU/ENTER.
2. Use the < or the > button to select Copy setup, and then press MENU/ENTER.
3. Use the < or the > button to select Def. Light/Dark, and then press MENU/ENTER.
4. Use the < or the > button to adjust the setting. Move the slider to the left to make all of the
copies lighter than the original, or move the slider to the right to make all of the copies
darker than the original.
5. Press MENU/ENTER to save the selection.
Page 48 of the User Guide has instructions for adjusting the light/dark setting during a copy job.
Also see the Troubleshooting section of the User Guide for other possible reasons for light/faded copies.
If your copies continue to come out too light, you may need to clean the insert a new toner cartridge or change brands of toner. I tried several "generic" toner cartridges and refills, but my prints and copies were always faded or streaky. After going back to genuine HP cartridges, I haven't had any print quality problems.
Jul 21, 2011 | HP LaserJet 3015 All-In-One Printer
1) HOW DO I GET A DARKER "COPY" FROM MY LEXMARK 2500 PRINTER? I HAVE TRIED EVERYTHING, AND I AM WASTING TONS OF PAGES AND INK TRYING TO GET A DARKER PRINTOUT. 2) I ALSO CONTACTED LEXMARK ABOUT...
To get a "darker copy", load your document on the printer > launch Lexmark Imaging Studio on your computer > click Copy > select Document or Photo > click Start > from the Quality drop-down list, select the best copy quality > click Copy Now.
For your other concern, please contact Lexmark technical support for additional assistance.
Jun 18, 2011 | Lexmark X2500 All-In-One Printer
I have a Sharp AR M-165. If I try to do more than 20-30 continuous copies or prints I get a darkening of the top 40mm of the copied page which gets gradually darker and darker the more pages that are...
are u using a compatible toner or branded.this problem might be occurring due to toner .try to change the toner and developer .both at the same time because if u change the toner then the toner in developer module will get mixed with new one and u will have a problem
May 24, 2011 | Sharp Office Equipment & Supplies
Page has a dark bar along the length of the page copied and it gets darker the more copies you do
Defective toner cartridge. Try sliding out the cartridge, turn it over and slide open the cover/gate that covers the drum. The drum should be clean all the way across. If you see a toner band or anything that would be your proof. 9 times out of 10 this is going to be a bad toner cartridge.
Oct 09, 2010 | Canon PC-430 Color Copier
Xc830 copying dark ,down center of page
There are a series of mirrors on the carriage that moves back and forth under the original glass. When dust builds up on these mirrors it makes the copies darker. Since the dust is blown by the optics cooling fan it does not collect evenly which causes areas of the copy to be darker than the others. On this machine you just have to remove the original guide plate which is the plate with 4 screws in it and has the document size numbers on it. Once that is removed the glass can be lifted out. With the power turned off just gently pull out the scanner bar. The part that initially comes out has 1 mirror as well as a silver reflecting strip on it. Clean both. Now the assembly that follows the first assembly out has 2 mirrors on it. 1 facing downward and 1 facing upward. Clean these 2 mirrors. Re-nstall the glass and plate. Turn the machine on and let the scanner unit home itself. Once warmed up make a copy to test. Cleaning these surfaces will usually correct the problem. There are 2 more mirrors under the black box under the glass but those do not get as dirty and they are harder to get to.
Good Luck and Thank You for using Fixya.
Sep 08, 2010 | Xerox 8830 Copier
Bottom of the copies are darker than the top I
There may be spilled toner inside the copier, Free the drum and paper way of toner an ensure the toner container is not over full. do proper cleaning and the copier will be okay.
Jun 10, 2010 | Kyocera Mita KM-2050 Printer
Canon PC6re copier makes copies that are dark on the long edges
Just fyi, a Canon PC-6e is a copier that is about ten + years old of a model... The drum unit will make the copies better.... But, you most likely need to clean the optic's. Have you tried to make the copies lighter??? If I am correct, there is a small botton on the control pannel that will turn... It will make the copies light one way and darker the other way... Good Luck
Apr 20, 2009 | Canon PC170 Copier
Each succeeding copy gets darker and darker
When was the drum replace? Recently? Could it be time again?
Was it a remanufactured unit?
Regardless of all that, It sounds to me like the drum is failing.
Feb 27, 2009 | Brother MFC 4800 All-In-One Laser Printer
71 people viewed this question
old marine
old marine
