Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
Cleaning uphoustry I cant figure out how to attach the hose to clean furniture
  • COOLGIRL Apr 04, 2008
    I CANT PUT TOGETHER
    Habit-Forming:
    New Friend:
  • 43 Answers
Gently wipe off a section of the leather upholstery, use another slightly damp washcloth to remove the soap, then buff with a dry washcloth. Repeat this process over the entire upholstered area. In between cleanings, vacuum leather upholstery thoroughly every two weeks and treat stains immediately.
Posted on Jan 20, 2016
I CANT FIRGUE OUT HOW TO PUT IT TOGETHER
Posted on Apr 04, 2008
Where do u attach the the hose to get suction for cleaning furniture?
Tried to track this down, but did not find anything specific. I did find a URL that shows the detachable hose with written instructions (very short) about attaching it to the unit. If you have the owners manual and go to the URL, you might be able to answer the question.
http://www.vacuumpartstore.com/mof59f59f59f.html
Paul
Oct 06, 2010 | Hoover SteamVac F5914-900 SpinScrub...
How to hook up tool to clean upholstery
Keep your upholstered furniture looking fresh by vacuuming it regularly with the upholstery tool attached to your vacuum's hose. Prevent the fabric from fading (or at least delay this) by keeping your furniture out of direct sunlight -- close blinds, shades or curtains when the sun shines most directly through windows closest to the upholstery. And remove stains by blotting them with a dry cleaning solvent. Before steam cleaning your upholstered furniture, read the piece's cleaning code label to determine whether or not it is safe to do so. Then rent or buy a steam cleaner (also called an extractor) and follow the directions below.
  1. Rent a steam cleaner or purchase one; buy steam cleaner solution.
  2. Step 2 Vacuum the upholstery on the furniture you wish to steam clean; use the upholstery attachment to most effectively **** up loose debris.
  3. Step 3 Test the steam-cleaner solution on the upholstery in an inconspicuous place to ensure the color won't be steamed out or drastically altered.
  4. Step 4 Attempt to remove any stains with a stain removal or dry cleaning solution. Follow the directions that come with the product you choose for the best results, and allow the stain remover to dry before you begin steam cleaning.
  5. Step 5 Remove cushions and, if necessary, arm covers.
  6. Step 6 Gently apply the steaming water and cleaning solution in straight lines across the upholstery one section at a time.
  7. Step 7 Use the cleaning extension on the steam cleaner to **** up as much water as possible. The dirt will come out with the water.
  8. Step 8 Clean one side each cushion (then allow it to dry) before cleaning the other side. If the cushions are permanently attached to the furniture, clean them last.
  9. Step 9 Allow the furniture to dry completely before repeating the steam-cleaning process or replacing the cushions.
Jun 19, 2010 | Hoover F7425-900 SteamVac V2 Widepath...
I have a dirt devil featherlite deluixe carpet shampooer and lost manual, how do i use to clean my furniture?
remove the "remove to attach hose" plate.. that is where the hose connects, plug the solution line into the little nipple below the tank on the right side. then you turn it on. Suction will be redirected to the hose, and the trigger on the hose sprays the solution.
Oct 28, 2009 | Vacuums
How do I attach upholstery parts?
Remove the main head and put on the air guard.
Take of the bag assembly and attach the hose.
Mix up the solution in the "Suds o gun".
Attach this to the end of the hose.
When you switch on, foam will dispense from the gun.
Gently sponge this into the furniture.
Please leave feedback
Feb 14, 2009 | Kirby G4 Bagged Upright Vacuum
How do I shampoo my upholstery
Instructions are HERE. Try shampooing on a part of a furniture that is not visible much... sometimes this may not work well.
Jan 30, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Hoover steam vac
  1. Remove your cleaning solution tank and set aside.
  2. Remove the lid to your recovery tank.
  3. Remove the front panel of the recovery tank by sliding it straight up.
  4. Slide the convertor half way down into the same slot. (Curved side down). The opening should be facing upward.
  5. Replace the recovery tank lid.
  6. Open the door marked stair/upholstery cleaning connection.
  7. Press the tube connector with the black tabs onto the projection inside the door.
  8. Replace you cleaning solution tank and you are ready to go.
Note: It's a good idea to turn your brushes off. Also, you may need to prime your hose by turning on your cleaner and holding the hand tool onto a flat surface for a few moments before use.
Aug 08, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
How to hook the parts for cleaning furniture
How to Clean Wooden furniture The tips below explain how to clean wooden furniture, but an essential part of everyday maintenance is to place protective mats or pads under them to prevent the wood from scratching - otherwise, your efforts will be in vain.
  • If you're wondering how to clean wooden furniture on the regular without much hassle, regardless of the wood finishing, you should get rid of the dust first.
  • Make sure to attach a dusting brush to your vacuum cleaner to remove the dust on your wooden furniture to avoid scratching it. If you do not have a dusting brush attachment, opt for a soft microfiber cloth instead.
  • Then apply a specialized wood cleaning product - always follow the instructions on the label, and choose your product to suit the finish on your furniture. Read on to find out which to use
House Office Carpet Residential Commercial Cleaning Geelong Commercial...
Jun 17, 2008 | Vacuums
How do I attach and use the shampooing attachment so I can clean my couch?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=11557&thid=579274
How do I attach and use the shampooing attachment...
Posted by rottylvr on May 08, 2008
I have a Kirby Vacuum and Carpet Cleaner that I know how to use, all except the attachment that I am not sure about. I am not sure if it is a vacuuming attachment or can I attach it and use it to clean my couch, I do not have the user guide for my vacuum as I got it from my son's ex girlfriend in lieu of money she owed me. It looks like it should be used for shampooing things like stairs and furniture, but for the life of me I cannot figure it out! Can you please help me? Tell me how to attach it if it is supposed to be used to clean stairs and furniture or tell me where I can find the user guide to look at and see how to use it......Oh by the way I have a 160 pound rottweiler that tries to live on my furniture and my couch is in desperate need of cleaning, this is my only day off and I have spent all day cleaning carpets due to my dog and would love to clean my couch before returning to work and putting my dog in the back yard now that it is warm enough for him to be outside all day.
Thanks,
Desperate to reclaim her couch
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. My suggestion is that you contact the Kirby Co in Cleveland listed below and they will instruct you either to down load a owner’s manual or they will mail one out to you, there might be a local Kirby dealer in your area that might have a manual as well. Also, there is a separate shampoo head that will be in the owner’s manual, you remove the vacuum head and bag assm and attach the shampoo head, make sure you use genuine Kirby shampoo for the carpet. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com/ Customer Service – United States & Canada 1-800-494-8586
Hours 8:00 am to 5:00 pm (EST) U.S. & Canada Fax # 1 (216) 529-6146
Mail To:
Consumer Relations
The Kirby Company
1920 West 114 Street
Cleveland, OH 44102
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 08, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Cleaning uphoustry
Furniture cleaning isn't a science: try out a few techniques before choosing the one that is right for your belongings. This step-by-step guide explains how to clean a sofa:
  1. Before using any upholstery cleaning products, vacuum the sofa or chair first to remove as much surface dirt and dust as possible. Be sure to use the correct attachments to avoid damage to the material - a soft brush attachment is ideal.
  1. Spot Clean. Using baby wipes or vinegar poured onto a strong microfiber cloth, apply to any obvious stains, wiping gently as you go. Remember to test the upholstery cleaning products on an inconspicuous area first.
  1. Overall Clean. Using soapy water and a microfibre cloth, gently wipe your sofa with the solution, allowing it to soak into the fabric and tackle the dirt beneath the surface. You only want to use a very small amount of water - don't saturate the material.
  1. Dry. Some people use a hairdryer to quickly dry a sofa, but allowing it to dry naturally is always the better option, if you have the time. To speed things up, open windows and allow the breeze to help with the drying process.
Apr 23, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Cleaning hose
http://geeksquad.fixya.com/ThreadView.aspx?prdid=41018&thid=428640
Cleaning hose
Posted by NNate on Mar 06, 2008
I can't get solution to come through my hose attachement to clean furniture
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover F5881-900 Vacuum. It sound to me that you may have a defective pump or switch, the sprayer or solution should not spray out unless you use the trigger. Question? How old is the machine – if it is less than one year this would be covered under the Hoover factory warranty and if it is more than one year than you may want to check the trouble shooting part of the owner’s manual or to call the Hoover tech support line @ the factory. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
Mar 06, 2008 | Hoover F5881-900 Vacuum
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
302 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
