On 05+ Trail Blazer, the fuel filter is integral with the fuel pump inside of the fuel tank. It is a non-serviceable part. On 02-04s, the filter is on the drivers side frame rail at about the B-pillar. If your trail Blazer is a late 04 which means that it was build close to the 05 Trail Blazer, you may have a non serviceable fuel filter. Good luck and check under your Trail Blazer or look at your manufactured date sticker on the door which would help you indicate if your 04 is a early Trail Blazer and you'll have the fuel filter on the inside frame rail under the driver's door.
Testimonial: "Thanks for your info, appreciate it. SpotsDog"
SOURCE: Fuel filter location on 04 trail blazer?
Their on the frame rail, passenger side, midways. I just changed one on an envoy two weeks ago, which is basically the same type of vehicle.
SOURCE: where is the pcv valve on the 2005 chevy trail blazer
Dear hispeed3,
If you haven't bought the part yet and are planning on replacing it ...i'd go to the auto parts store and ask them for the part location. They are usually glad to do this. I know Advanced Auto Parts does this for me.
Are you having a problem with your 2005 Chevy Trail Blazer?
If so...I'm here for you!
jack
Please Rate This!
SOURCE: M y radio stopped working on my 2004 trail blazer
The 2004 Trailblazer has two fuse panels, one in the under hood and one under the middle row seats. The radio fuse is marked RADIO fuse # 41 and is a 15 amp fuse located in the rear fuse panel. To access the rear fuse panel flip the seat behind the driver to the upright position, under it you can see the fuse panel and a diagram should be on the under side of the cover.
Good luck and hope this helps.
SOURCE: 2004 TrailBlazer: what size tire fits a 2004 chevy trail blazer...
Typically it is a 255/65R/17 or 255/70R/17
