Question about Hitachi 61SDX01B 61" Rear Projection Television
Cleaning tv screen
I have an Hitachi 61sdx01b rear projection tv. I need to clean the back side of the tv screen and probably clean the mirrors to. How do I remove the screen correctly.
  • 4 more comments
  • Anonymous Apr 17, 2008
    how do i clean the cob webs off the back side of my hitachi ultravision big screen panel
  • mikmas1234 Aug 30, 2008
    I need to learn the same cleaning procedure described above,
  • Anonymous Dec 09, 2008
    We have the same problem. For some reason there are small black looking cobwebs behind the screen and we want to clean it.
  • kschmitt12 Dec 09, 2008
    I need to clean cobwebs from behind my screen
  • JPWoods87 Dec 18, 2008
    I have a Hitachi 50EX10B.. I've taken the front off cover off to clean the back of the screen. It was very dusty.. How can I clean the front of the screen.. Is there a specific cleaner or can I just wipe it with a cloth with warm water??
  • sl64 Jan 11, 2009
    I have
Need to know how to clean a hitachi rear projection screen tv
Posted on Apr 05, 2008
There seems to be dust behind the screen panel i live on a gravel road is there a way to clean the screen or what do i do
What you have to do is remove the front screen assembly by removing the screws loacted at the bottom of the screen frame just under the frame lip. Lift the screen assembly up from the bottom to disengage the holder clips at the top and set the screen assembly to the side. On the inside of the screen, the part that faces the projection mirror assembly you can use some Windex and paper towels to clean the surface. On the outside do not use Windex as this will breakdown the protective finish used on the viewing side of the screen. To clean the viewing side, use a special cleaner also used to clean computer display screens. Re-install the screen assembly and you are done.
Jan 21, 2010 | Hitachi 61SDX01B 61" Rear Projection...
How do I get my TV open to clean color lights I have a Hitachi 42in projection tv
You can take the back cardboard cover off to get to the lenses on the picture tubes. Usually, if the picture is dull because it needs cleaning, the mirror should be cleaned. You can remove the top half of the back of the tv and the mirror will be mounted to the inside of it.
Jul 08, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 61sdx01b rear projection has no audio at all.
If no sound in all input, check the surround board. Is the audio distorted or on and off before? if so replace surround board :)
May 27, 2009 | Hitachi 61SDX01B 61" Rear Projection...
Screen broke on my Hitachi 61SDX01B, need replacement
Here's a link to order the original Hitachi screen assembly for this model (61SDX01B) from a major parts distributor:
Hitachi 61SDX01B Replacement Part Screen Assembly
Mar 19, 2009 | Hitachi 61SDX01B 61" Rear Projection...
Screen is dim and not very bright
You can safely clean the mirror and lenses, it can greatly increase your picture if its dirty. If you unplug your tv you can safely remove the back and gain access to the lenses. All it takes is a philips screwdriver. After you remove the back, you can remove the light barrier between the upper and lower half to free up some room. Take a dry scratch-free cloth and wipe the dust from the lenses. If they're grimy, use a little lens cleaner (liquids used sparingly here, electronics don't like liquids, be careful) You can look up into the top and see if the mirror is dirty. A flashlight shined on it will illuminate the dust/dirt if its there. If you don't smoke you likely won't need to clean the mirror, but it may need it. Use windex or similar for tough grime.. I can usually reach up to get the whole mirror but I've heard of using a swiffer mop to reach the top. Removing the screen is difficult but possible if needed to get inside. Don't touch the back of the screen but lightly with a rag to get cobwebs, etc.
Dec 09, 2008 | Hitachi 61SDX01B 61" Rear Projection...
Remove screen from Hitachi Ultravision
underneath screen remove screws holding screen in place ,it should then slide upward and off.
Dec 08, 2008 | Hitachi 61SDX01B 61" Rear Projection...
How do i remove the front screen to clean the mirror on the inside
usually you need to remove the speaker grille then you will notice a few screws in the lower screen frame remove thos screws then grab the screen frame and slide up wards to disengage the clips that hold the screen assembly on.
May 16, 2008 | Hitachi 61SDX01B 61" Rear Projection...
Hitachi 61sdx01b
If not I can get you into a Mit set of screens that can be cut down to your size. They are the finest grade available.
Mr Bob
www.imageperfection.com
Feb 13, 2008 | Hitachi 61SDX01B 61" Rear Projection...
Hitachi 61SDX01B 61" Rear Projection Television Logo
1,167 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
