Question about Lexmark X5470 All-In-One InkJet Printer
Connection from modem to x5470 all-in-one
When I connect phone line from modem to all-i-one there is no dial tone so I can't stay online cause then there is no dial tone.
    Genius:
  • 3,587 Answers
Sounds like same issue as other item...let's handle one or the other, right?
Posted on Mar 10, 2008
Hp problem
Try to make a new connection shortcut and make sure your telephone line is properly connected on your modem. Also make sure that your password and username is correct. another thing is check that your system date is correct.. Hope this works ! ITTech7574
Aug 28, 2009 | HP Pavilion a6863w-b PC Bundle with 23"...
Fax problem
I want to make sure I understand this completely. You get no dial tone from the fax machine when hooked up to VOIP. In the past, was there an audible dial tone from the fax, or did it just dial silently and give you an error if there was no tone? When you said you got a dial tone by connecting a phone to the ext phone port of "the machine" did you mean the fax machine? If you get a dial tone by running a phone through the fax machine, then the line is good. I have used a fax machine over Sunrocket before they went defunct, which used the same technology base as Vonage - so it should work. If you used to get an audible dial tone when using the fax, and no longer do, and you are geting a dial tone on a regular phone that is connected to the ext. port of the fax machine, then the problem has to be in the fax machine itself, not the VOIP. If you can verify that, we can go from there.
Oct 08, 2007 | Brother MultiFunction Center MFC-440CN...
Tip
Troubleshooting for modem.
Problem:-
User's modem does not dial or does not connect.
Tip:-
Prove that computer is connected with phone line and check that phone line contains dial tone.Therefor check that connection is connect or not.
  • Connection may not be less than six feet (1.8 meter).
  • Check dial tone by plug in the phone in phone jack.
  • If user has many more services (such as call waiting,call messaging OR voice mail) then check that these all are cleared or not and check call waiting is disabled while using modem.
  • Disconnect any answering machine,fax machine or printer which are on line with modem.
  • Check that are you not using digital,rollover or PBX line?These type of lines not works with modem.
  • Try with another phone line. (For this, you have another phone number or another phone line).If user connected with another line then you need to complain in phone company.
  • Try to connect modem with low connection speed.
on Apr 13, 2010 | Computers & Internet
No Dial tone using Symantec Winfax Pro 10 on Windows 98
Check the physical connection of the phone line to the computer make sure that it is connected to phone line symbol of the Ethernet adapter. Then make sure that the driver of the adapter is installed properly on the computer or you can try to scan the hardware first before the re-installation of the driver using the adapter.
May 26, 2009 | Conexant chipset 56K V.92 PCI Data/Fax...
I am trying to use the fax facility on my epson600fw.my isp is aol .Problem no dial tone. What connections are necessary............via printer,modem & computer ?
Typically, a fax machine is connected directly to a telephone wall jack with a known working connection. Try plugging the fax machine directly into a wall jack first and pick up the handset on the fax machine if it has one. You should get a dial tone. Then try to fax something to someone you know.
The machine can also usually be routed through the modem in a computer by connecting the "line" cord on the modem to the wall jack and plugging the fax machine into the the "phone" jack on the modem. You may need to install the software that came with the fax machine to get this to work.
If you have no dial tone, check the wall jack with a known to be working single line phone. If there is a dial tone, it's something to do with fax machine, the computer modem or the connections.
Some fax machines can take advantage of internet faxing through a cable modem or DSL connection. Check your manual for the options available.
Apr 18, 2009 | Lexmark X5470 All-In-One InkJet Printer
Was able to get connected to the internet twice to day when i came back in to get on the computer it couldnt connect to the internet said no dial tone. this is a new dell computer with an external modem...
Generally this is an indication of a modem failure. If there have been any storms in your area, then the modem may have been zapped. The dial tone curcuit is normally the first casualty when a modem gets hit with more power than normal.
Provided that your telephone is functional on that line (Unplug modem, and connect a handset if this is a modem only line and see if the handset gets a dial tone, this is a good check to make sure the line is functional)
Apr 17, 2009 | Dell Inspiron 530 Desktop Computer
Modem problem
Disconnect the phone line from the modem and connect a normal phone to this phone line. Lift the handset and check it you have a dial tone and see if you can dial out.
If you don't get a dial tone then there is a fault with the phone line and it needs to be repaired before you can use your modem.
Apr 14, 2009 | Dell Latitude C640 Notebook
Trying to launch internet explorer.it gives me error 680.
680 - There is no dial tone.
All versions of Windows are affected by this error.
No dial tone: There are many possible causes of a No Dial Tone Error.
First, try testing the modem's ability to detect dial tone and to dial by using HyperTerminal with the direct to COM port connect method - see Using HyperTerminal. If you give your modem an AT&FX1 command, and then a dial command, dial-tone detection will be disabled; if you still do not get dial tone, the modem may not be installed correctly (especially if it is a PCI or soft-modem); or the cable from the modem to the phone-line jack may be bad or installed in the wrong connector on the modem - try another line cord, and make sure you are plugged in to the LINE - not phone - jack on the modem. Plug a regular phone into the phone jack on the modem and make sure it has dial tone. The modem may also be defective. Many new modems come with an electronic circuit instead of the traditional electro-mechanical relay used to take the modem off-hook. Some of these designs are proving less reliable; often, they will be 'stuck' in the off-hook position, so unplugging, the plugging in the phone cord may give dial-tone. If this is the case, the modem needs repair or replacement.
If the modem will blind dial (x1), but not detect dial-tone otherwise, the problem is likely to be in the proper selection of the Country in Windows->ControlPanel->Telephony or in improper installation of the modem or lack of support for your country in the driver you are using. Check to see if there are updated drivers for your modem.
If the modem dials properly with detection (x3) in HyperTerminal, but does not detect dial tone when using DUNs, the problem may be DUNs (check for upgrade or re-install) or the proper setup and modem selection for the DUNs connectoid.
For Embarq telephone service customers, this error can indicate that you have a message waiting in your voicemail. Embarq changes the dial-tone sound to a "fast" busy signal when a new message is present in your voicemail box. This "fast" busy signal can confuse the modem into thinking there is no-dial tone present on the line.
Jul 02, 2008 | Microsoft Windows XP Home Edition
Connection from modem to all-in-one printer
hmmm..so, what type modem you working with here?
Mar 05, 2008 | Lexmark X5470 All-In-One InkJet Printer
Error code 680 when I try to connect to my server
The error 680 means There is no dial tone. The modem is not detecting a dial tone There are many possible causes of a No Dial Tone Error. 1.Check cable is correctly inserted into back of modem and phone socket 2.Check properties of connection, make sure correct modem is being used 3.Disable "wait for dialtone before dialing" in My Computer > Dial Up Networking > Properties of Connectoid > Configure > Connection > remove checkmark under call preferences 4.Try removing fax machines or other devices connected to the line 5.Make sure no one is using the telephone when trying to connect
Jul 07, 2007 | Actiontec (GT701) Modem
Lexmark X5470 All-In-One InkJet Printer Logo
35 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
