Had it set on 5, food and drink started freezing, moved temp to 1 and everything thawed. Set it back to 3 and it was fine for awhile, then began to freeze again. Set it to one, kept it at one for about a month and yesterday things began to freeze again.
This is a common problem and it has to do with the electronic temperature sensor. Check with Sears to see if there is either a recall or a TSB (Technical Service Bulletin) for your model. They may try to get you to buy a new circuit board, but the solution is actually the temp sensor itself. (www.searspartsdirect.com) will give you the scematic as well as the part number. Just enter your model and press enter.
