Beko 324250WN 28" TV
Problem for Beko 324250WN 28" TV
Strange screen colours
By rengae on Mar 05, 2008
My tv picture has gone mainly blue in the centre of the screen, with an outer greeny red ring
Comments:
Mar 06, 2008
- It happened suddenly. I turned it on after it had been turned off at the mains for a couple of hours and it was like this. I rotated the tv through 90 degrees to know effect. I turned in off at the tv power switch for a couple of hours today but left it on at the mains and some normal colour had returned to the centre of the screen and the blue is now the outer ring
Mar 06, 2008
- Thanks for the help. Should I have the tv on or off whilst passing the magnet over it. I could only find a small magnet and tried it with tv on and the colour is almost normal as the magnet passes but returns to the blue although the blue is now at the sides of the screen as apposed to a circular ring.
Mar 06, 2008
- Thanks again. Found a bigger magnet and tried it out. Much more dramatic results. Picture not perfect but much improved. I have a large stereo speaker about 18" from the tv - could this have caused the problem in the first place even though the picture messed up only yesterday and they have been in this configuration for over a year?
Clarification Request
Posted by BFixed on Mar 06, 2008
Did this happen suddenly, or did it progressivly get worse over time?
Do the colors shift (slightly) if you turn the TV 90 degrees or move it to another location?
Same Problem
Feb 07, 2009
-   TV has the same circle in the middle, with wild yellow, green and pink colours. Have turned it off at the mains a few times, to no avail. Tried magnet trick, but colours just spread out to the sides. This started out of the blue a week ago (when the weather turned really cold), tv is only 4 years old? Help!-   Guest
Jan 21, 2009
-   my tv screen has over a period of time started seeping blue green at one side and red at the other. the tv has two inbuild speakers on the side of the screen. can anyone help me sort it as its not that old but out of warranty now
-   anita11s
Best Solution
posted on Mar 07, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Thanks again.
Solution #2
posted on Mar 06, 2008
Helpful)
BFixed
Rank: Guru
Rating: 86%, 97 votes
Your degaussing circuit is not fully 'demagnetizing' the picture tube.
You can manually degauss it using a strong magnet, but it's tricky.
With a tool made for demagnetizing you simply hold it close to the center of the picture tube and using a circular motion slowly spiral outward to the outer edge of the tube, pulling the magent further away from the tube at the same time. The same can be done using a strong magnet although the results may not be perfect. You can experiment with a magnet using wiping motions as you bring the magnet closer to and further away from the tube.
Comments:
Mar 06, 2008
- Yes, and Yes :)
Have it on while degausing, and definately yes to the speaker causing, or being part of the problem. The magnetic field from large speakers, fluorescent light ballasts, neon sign transformers etc. can cause the discoloration due to the magnetic interference. You may possibly be able to talk a local tv shop into borrowing a degausser if they have one. If you do get a degausser do not run it for more than the few seconds it takes to do the job as it will heatup and burn out.
Believe it or not, even the earths magnetic field can alter the tubes colors. Thats why I asked you to turn it 90 degrees, to get it out of phase with the natural mag. field of the earth.
Was this helpful?
Yes
No
Solution #3
posted on Jun 18, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
tried this and it worked but next day i put my tv on it was all mixed up
Popular Solutions for Beko 324250WN 28" TV
Questions and Unsolved Problems for Beko 324250WN 28" TV
Do you recommend Beko 324250WN 28" TV?
Answer
Answer
there is no power going into my beko wahsing machine i have tried changing fuse but still no luck
Answer
colour wheel. im getting blue in the center green arond that and red at the outside.is it the colour... (More)
Answer
my scart cable is not workng on my beko tv when i connect it,theres nothing on the screen from the... (More)
Answer
im beko tv worked fine now i cant turn it on the red light is on hear noice like its turning on but... (More)
Answer
This 15" tv normally comes on ok the first time you use it in the day, but if switched off and... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Beko 324250WN 28" TV:
Top Standard Television Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Standard Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
