Question about Philips 60P8342 60" Rear Projection Television
Mitsubishi WS-55907 projection - 6 yrs old.
Hi.....yesterday the color on my TV changed to yellow, brown and blue (with black and white too) I tried recycling and changed the convergence back to factory default - nothing worked. I called a service company and they said I would have to buy 3 color tubes @ $222. each plus a $250. service charge...so, over $900 to fix. What do you think.....should I just buy a new T.V or do you have some less expensive advice.....thanks....
I read for hours, all of the questions and answers everyone had submitted and finally I found an answer where someone suggested checking the video connections. Sure enough the red cable connection was not pushed all the way in. I did some fine tuning and the picture is back to normal.....beautiful......I'm so happy....thanks to whoever wrote that suggestion......
Posted on Mar 06, 2008
What I am trying to hook up is a Wii console using component cable but get black and white image on a Mitsubishi WS-65313 65 inch Television?
Follow the color code green for green, red for red, blue for blue, ignore the yellow wire, also be aware that there is an audio cable that is red also that wire goes into the Right channel audio and the white wire goes to the Left channel audio
May 26, 2014 | Mitsubishi WS-65313 65" Rear Projection...
YELLOW TINT ON SCREEN MITSUBISHI TV MODEL WS 55313
The WS is a picture tube type rear projection first produced as a 2003 model year set.
A few questions and then a offer if needed.
Did this happen suddenly or after a power loss?
By reboot do you mean the recessed reset button on the front of the set?
I will presume if you turn color off completely the screen is some other color than black and white?
the offer: have you tried the Option menu this set has hidden, I can explain if needed.
Dec 11, 2012 | Mitsubishi WD-52525 52" Rear Projection...
My TV color has yellow, blue and red shadows n the picture.
Enter Service mode.. Press Menu -0-1-5-7 in quick succession . From there select the convergence option. You should see 3 crosshairs -Red, Blue and Green. Green is fixed but Red and blue can be moved. Align both of them with green and see if the issue resolves. If not Try moving them around and see if the problem is cleared. If not you may have the inevitable convegence IC problem and the IC needs to be replaced. Let me know if that is the case and I will give you the procedure.
Jun 11, 2010 | Mitsubishi WS-55907 55" Rear Projection...
Wiring on a RCA RJ-45 wall jack
the RJ45 wallplate is not meant for ethernet. It's an 8P8C connector for a phone. Will it work as a network jack? Maybe. I wouldn't use it, but if you really want to try, wire it thusly:
1 Blue --- Orange/White
2 Orange --- Orange
3 Black --- Green/White
4 Red --- Blue
5 Green --- Blue/White
6 Yellow --- Green
7 Brown --- Brown/White
8 White --- Brown
I'd still recommend a CAT5 wallplate with a CAT5 jack.
Apr 11, 2009 | Computers & Internet
Bad color
Turn the color level all the way down and see if you have a good black and white picture. If your screen isnt black and white it should have a predominate tint to it. then turn the screen control for that color down to achieve the best black and white picture. then adjust your color level that should help.
Jun 13, 2008 | Mitsubishi WS-48311 48" Rear Projection...
Mitsubishi projection TV WS - 55413
any flashing LED's when running service mode or convergence signal?
Apr 27, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi rear projection
On every input?? RF (coax),yellow(composite),S-Video and
component (red,green,blue)??
Verify model # please......T.
Oct 21, 2007 | Mitsubishi WS-55859 55" Rear Projection...
Philips 60P8342 60" Rear Projection Television Logo
82 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
