Question about Cambridge Audio Azur 640P Amplifier
640p sound error
I'm finding that my 640p is cutting the volume and fidelity from the cd/tuner when its plugged into the system.
i have a technics sl1800, a naim hicap, naim pre and power amp which are installed correctly..(i think) the CD and tuner work ok yet when i plug in the 640p to the av outlet on the amp after 15 secs when the phono comes on line the sound drops.
any help would be gratefully received!
cheers
  • stiggy2 Mar 17, 2008
    Hi thanks for the info! human error was at fault here! this question can be closed...thanks for your help
  • Rob Galayda May 11, 2010
    ummmmmm...why would you be plugging the 640 to the AV OUTLET on the amp......
    Are you plugging the 640 into the mains for power? or are you plugging the output of the 640 into the output of the amp/ pre-amp.....
    I don't quite understand the question.
    If you were plugging the output of the 640 into an output of the pre-amp, it would be like 2 cars colliding head-on. The bigger car would "win"......thats why you plug the output of the 640 into an INPUT of your pre-amp....its like 2 cars following each other nicely down the motorway.
    More information is needed for me to help you...
    Thanks
    Rob
3 Suggested Answers
marsrover
  • 682 Answers
SOURCE: Sound Distortion
use sonic slide switch and make ground connection between your 640p and turntable.-check cables and test with another good cables.-shut down any light dimmer around you and test.
Posted on Jul 15, 2008
caroldon
  • 17130 Answers
SOURCE: Re: Technics HD51 home stereo system (amp, tuner,
The Amplifier must have a high impedance input for the turntable to be connected. Now most of the present day amplifiers do not have this input but only the regular aux input which is designed for a larger signal . But the turntable outputs is quite low and so it requires an amplification of high order. What you can do if you need to play the turntable is to have first a preamplifier with a high impedance which is available even inkit form and can be fitted on to your system. The preamp output can be shared into the input of the source selector maybe with a switch and you willl be able to fix two RCA sockets to accept the input of the phono. This will work fine provided the shielding is done well to avoid the high feedbacck to oascillate and cause noise, the premap must be housed in a shielded cabin. On the other hand you may have to buy a universal amplifier so that the phono input is present. Definetely nothing better than a designed input. So think and decide. hope I could help; Good day
Posted on Aug 10, 2010
My HD350 Technics audio set consistent of four Parts:ST tuner, SE amplifier, SL CD plager, RS cassetteplayer wicht are connected via a flat broad cable. It goes from tuner to cd to cassette. Now my cassete...
Please don't cut a cable, You won't be able to repair it. There must be a way to lose the cable without cutting. I forgot, but I will search around. When I find something I'll come back on this.
Jan 18, 2015 | Technics Audio Players & Recorders
Technics SA-DV290 Amp. Sound cuts out as volume is increased
hello it sound like the output ic may be in trouble you may have just dry joint on the ic which just resolder it . or there could be a capacitor leaking or they may have swelled up in which you will have to replace. it's best to do some visual checks first i'e look for any burnt parts any capacitor with bulging tops
regards
shaun
Apr 04, 2010 | Technics SC-DV290 System
TECHNICS SC-CH550 STEREO SYSTEM
Hi
I belive that you have a lot of dust how is gatherd behind the system in the amplifier and it is preventing it to cool down you need to blow it clean and make sure that you keep the system gets cool air
if the temp in the amplifier gets to high it shut down the system instand of burning it very clever solution from the manufacturer
you have a very good system good luck
Jan 04, 2009 | Technics SC-DV290 System
Sound Distortion
Jun 29, 2008 | Cambridge Audio Azur 640P Amplifier
Volume Control??
Unlike low-end hi-fi systems where you buy one box that does everything, the CD player you have is part of a component hi-fi system (i.e. you buy your CD player, tuner, amplifer etc. as separate items.) This is why there is no volume control. It needs to be connected to an amplifer. It's on the amp that you will find the volume control and where you connect the speakers. (When you connect it to your television, you are just using that amp in the TV instead.)
The CD player did originally ship with a remote control, but I don't know where you would be able to buy one on its own. You may find the the remote does allow you to alter the output level of the CD player, but you still need to connect it to a proper amp to get it to work.
Hope this helps,
Matt
Mar 27, 2008 | Technics SL-PD887 5-Disc CD Changer
Sound Cutting Out
We also had this same problem, make sure all speaker wires are correctly connected and have no breaks as any wire problems will cause amplifier to cut out. The system works fine now and also plays from the pc without any cut off. Hope this helps.
Feb 05, 2007 | Technics SCEH790 CD Shelf System
Cambridge Audio Azur 640P Amplifier Logo
59 people viewed this question
Top Cambridge Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Cambridge Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
