My AKAI Tuner Quartz Synthesizer model no. AT-A301 went completely dead. This happened after being hooked up to the amplifier wrong. Once it was hooked up correctly the tuner kind of made a low humming sound when it was turned on. It worked for about six times, with a low hum and then it went comletely dead. It sort of seems like the power supply burnt up! Is there anything I can do to fix this tuner? JON
4 Suggested Answers
kerguney
  • 577 Answers
SOURCE: need downloadable users manual for
hi,
you can visit the following web site to download the manual you need..
Take care..
http://www.scribd.com/doc/38031058/Onkyo-Receiver-TX-906-TX-904-User-Guide
Pls remember to rate me afterward..Thanks
Posted on Jun 19, 2011
  • 165 Answers
SOURCE: tx-38/28 quartz synthesized tuner amplifier
hello surely there,s a problem in connection firs do this check your jbl even if they new with a baterry they pop up,now make sure you connect the monster wire into the outputs remember the wire is too thick make sure your getting contact in outputs...saludos
Posted on Nov 27, 2008
  • 4234 Answers
SOURCE: I am looking for the
I don't believe that these are available electronically without cost. If you can describe the problem you are trying to solve, I may be able to guide you through the repair.
Dan
Posted on May 25, 2011
Put my stero together turned it on.when I turn it up overload lite comes on theen it shuts off
Unplug the speakers from it and see if the unit powers up. If it does then a speaker has a short. IF it does not, unhook everything from it and check again. If it works then something is over driving the amp. If it does not work then something is wrong inside the unit in either the protection circuit or the drivers and finals.
Jan 29, 2016 | Panasonic Technics St-k50 Quartz...
I have a 1987 model kenwood home stereo system ihave a graphic equalizer ge 76 control amplifier kc206 synthesizer tuner kt76 power amp km206 how does the RCA connections hook up which ones go to...
First connect all sources like tuner, cassette player, Cd player into the proper RCA inputs of the control amp, then connect the output of the control amp into the input of the equalizer. Then connect the output of the equalizer into the input of the amplifier. This is how to get the best performance and proper outputs to all the right equipment. The speaker outputs of the amplifier would then go to the speakers.
Let me know if you need more help from me by addressing your post to me, or if you wish to communicate with another expert you can address your post to them I.E. @tech48 or @whoever
Thanks and good luck,
Dave
Sep 27, 2008 | Kenwood Audio Players & Recorders
Onkyo receiver
that means that your amp is taking its sweet time going completely down the tubes(so to speak)...had it for a while?
Apr 27, 2008 | Audio Players & Recorders
How do I connect this system together to get it to work?
The manual for the amplifier and all the other units are here. Use the search feature in the top right with just the model number 'AT-5210'. Getting the items in the right order helps. The turntable obviously goes on top. The Amplifier goes in the middle and all the other units connect to the amp.
Akai AM U61 Manual Stereo Integrated Amplifier HiFi Engine
Jan 14, 2016 | Audio Players & Recorders
How do i hook up speakers to my MCS 3873 integrated stereo amplifier and 3051 quartz synthesized stereo tuner?
have fun trying to find that,why dont you just hook them up by the labels on the equipment,out means from input means to
Jul 28, 2015 | Audio Players & Recorders
Hook up eq to reciever
Hi Michael, the EQ would be connected to the Tape2 Monitors input/output, Thanks, JT
Apr 19, 2015 | Onkyo Quartz Synthesized Tuner Amplifier...
Am antenna technics st-z550
Loop antenna is directional.
But you can extend the wires so as to find a good spot.
Jul 29, 2012 | Panasonic Technics St-z550 Quartz...
I am looking for the manuals for Technics SE-A808 Stereo Power Amplifier ST-K808 Quartz Synthesizer Stereo FM/AM Tuner/Preamp SH-R808 Infrared Wireless Remote Unit Kind Regards John
Dan
May 25, 2011 | Audio Players & Recorders
Picture goes in and out
This will require you opening the back cover of the television to test some component with the use of an ohmmeter.
This may be a slight drift - like someone is messing with the fine tuning
or such a substantial change in tuning frequency that the channels go by
as though you are surfing.
Possible causes depend on tuner type:
1. Quartz tuner (10 button direct access digital synthesizer) - For a
slight drift, a component is probably changing value, possibly the
crystal in the reference oscillator. For gross changes - flipping
through channels - it is more likely to be a digital control problem -
the microcontroller is misdirecting the synthesizer to change frequency.
2. Varactor tuner (buttons but not direct channel access) - If only a
single pushbutton selection is the problem, the the varactor tuning diode
for that button is probably changing capacitance. If all channels in
a band (Vl, Vh, U) are having a problem, it is more likely to be a
drifting D/A or faulty AFT (Automatic Fine Tuning) circuit or power supply.
3. Turret or switch tuner (Knobs) - A component like a capacitor is changing
value.
You will have to get in there with a heat gun or cold spray and track it down
the old fashioned way. At least, the problem is almost certainly localized
to the tuner box (and possibly the controller if applicable).
As noted, gradual slight changes in tuning are likely due to frequency
determining components drifting.
Uncontrolled channel surfing is probably a logic problem. For the
quartz tuner, this could still be marginal connections causing the
microprocessor to misdirect the synthesizer to change channels.
For the latter case, particularly, the cause may still be bad connections
resulting in loss of channel memory and/or erratic behavior.
Take care...
May 21, 2010 | Mitsubishi WS-55859 55" Rear Projection...
203 people viewed this question
 Grubhead
Grubhead
