Question about Dell 962 Photo All-In-One InkJet Printer
Dell No. 962 (All-In-One Printer)
I am not able to scan or copy anything on my Printer. I am able to print e-mails or anything from the hard drive with no problems. The color and black & white mode work just fine. But when I scan or copy something, it comes out all black. The scanned or copied material is barely visable through the black. I would appreciate any help. Thanks
  • dawn518 Mar 27, 2008
    I cannot scan anything, it continually says that the printer is busy
    Problem Solver:
  • 16 Answers
You need to go to your printer settings and make sure it is set as the default printer for everything. Make sure it is also set as your default scanner. you may also try lightening the image with the lighter/darker setting on the machine. if this continues, you may want to see if a section of the light is burnt out. this wiill cause darkness on scan & copies but not printing from the c drive. Make sure the machine is lighting up completely when is scans or copies. If part of the lighting is burnt out it will be a fix or replace situation.
Posted on Mar 19, 2008
I have used last 4 year canon 2900B printer. How to set 300 dpi printing resoluation
Canon PIXMA Manuals MG2900 series Resolution
Resolution The data in the image you have scanned is a collection of dots carrying information about brightness and color. The density of these dots is called "resolution", and resolution will determine the amount of detail your image contains. The unit of resolution is dots per inch (dpi). Dpi is the number of dots per inch (2.5 cm). The higher the resolution (value), the more detail in your image; the lower the resolution (value), the less detail.
How to Set the Resolution You can set the resolution in Resolution on the (Scanning from a Computer) tab of the Settings dialog.
Appropriate Resolution Settings Set the resolution according to the use of the scanned image.
Item Type Use Color Mode Appropriate Resolution Color photo Copying
(Printing) Color 300 dpi Creating a postcard Color 300 dpi Saving to a computer Color 300 dpi Using on a website or attaching to e-mail Color 150 dpi Black and white photo Saving to a computer Grayscale 300 dpi Using on a website or attaching to e-mail Grayscale 150 dpi Text document (document or magazine) Copying Color, Grayscale, or Black and White 300 dpi Attaching to e-mail Color, Grayscale, or Black and White 150 dpi Scanning text using OCR Color or Grayscale 300 dpi Important
  • If you double the resolution, the data size of the scanned image quadruples. If the file is too large, the processing speed will slow down significantly, and you will experience inconvenience such as lack of memory. Set the minimum required resolution according to the use of the image.
Note
  • When you will be printing the scanned image by enlarging it, scan by setting a higher resolution than the recommended one above.
Oct 07, 2014 | Canon LASER SHOT LBP-2900 Printer
The scan of color document gives a black and white product
there some reasons :
1- Are you sure to select the copying color not black and white ?
2- try to reset color ink cartridge ,
3- try to select clean print head
i hope that was help you
Mohamed Hejazi
Afaqnama -Libya
ipg@hplibya.com
Mar 21, 2013 | HP Officejet 4620 e-All-in-One Printer,...
My printer is not printing black ink, only in color. black ink cartridge is new. model #A940, service tag 5D53Z31, express service code, 11678555485. can you help?
Try this:
Go to Google Maps, select one and print it out. Does black work then? (On mine it does)
If you try to print an e-mail with both color and black fonts, are the black ones missing from the print? (On mine, the black letters are missing)
How about a scan which contains both color and black features? (Again, both black and color works for me)
And finally, if you scan an all-black font document after hitting "copy...black", you get nothing....but do the same thing after selecting "copy...color"...and it'll print the black.
I'm sorry I haven't found the answer as yet, but maybe if you try some of these little experiments I did this morning, then it'll catch someone's eye and we'll both have a solution (which may cost more than a new printer!
Jun 12, 2010 | Dell A940 All-In-One InkJet Printer
Having problems downloading drivers for Dell 962
I have a samsung notebook without a place to insert a disc and need to print files from my e-mail using a dell aio 962 printer how do I do this without using the software disc that came with the printer
Jan 26, 2010 | Dell 962 Photo All-In-One InkJet Printer
My Del 962 will not scan. The light does not come on and it does nothing. What should I do?
Hi,.... I'm having the same problem as sharon_mi334. My Dell AIO 962 does not copy, fax or scan...but prints. When attempted(copy, fax or scan), the output is a scanned image or a print out that's completely black. When I looked at the "scanner light unit/ copier camera" or what-ever it's called ... the gizmo that moves across under the glass plate,... I noticed there was NO light coming out of it as it should on any other copier, etc. Sooo,... is that the problem, ie: unable to copy the image? If so, can I fix that by replacing a bulb or a particular unit? Looking for some advice and thank you for your help and time.
medflight.
Dec 11, 2009 | Dell 962 Photo All-In-One InkJet Printer
Unable to cop
You can not use the copy feature if your printer is "printing". You can scan while other is printing simply because scanning is not using the printer's print heads. Therefore if you are printing, you can not copy at the same time.
Is your printer printing OK? So you should be able to copy as well. Press COPY button when the printer is ready. Basically, you have the Copy (Black) and Copy Color options. If you have 1 option only, pressing COPY makes you choose black or COlor using the keypad selector. Just choose any option and press OK or START.
Nov 20, 2009 | HP Officejet J5780 All-In-One InkJet...
Dell AOI printer 962 showing error 2200 when trying to scan or copy. I have tried disconnecting and re-installing but have been unable to fix it. Can anyone help ? Mac
go to printers find dell aio 962, right click propertys, check 1st it is set to the right port, usb, paralell which ever the printer uses and that bidirectional support is enabled.same prop. page click advanced and be sure start printing immediately is checked then ok and try printing then. if no prob here then you may have a bad driver, a bad cable or a bad printer.
Jul 26, 2009 | Dell Office Equipment & Supplies
Dell 962 prints fine - copies, scans and faxes are illegible
That is a sound approach you offer because, 1.) Cleaning the Carts. usually solves streaking, 2.) Cleaning the strip on the read glass fixes lines on the scanned images, 3.) You may have a saturation of ink inside the conveyance rollers that is soaking everything. You don't want to know how hard it is to get all the ink out of a wet printer. Replace it, save the hassle.
Jul 15, 2009 | Dell 924 All-in-One InkJet Printer
Dell 962 Photo All-In-One InkJet Printer Logo
202 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
