Question about GE JBP64 CleanDesign Electric Kitchen Range
Burner will not turn off
The rear left burner will not turn off, the only way to turn it off is to unplug the stove for about a hour and it will reset. After the stove is plugged back in, the red indicator light for hot stays on even though the burner is completely cold. Now the rear left burner will turn on when the front left burner is turned on. The stove is 4 years old and the Model # is JBP64W0B5WW, Serial # DF257417Q.
  • selle3119 Mar 08, 2009
    I have the same problem w/ Model # JBP69W0F3WW
  • 126 Answers
I would first check the infinite control switch (#WB24T10029) the part the knob slips onto. The next thing I'd check is the erc (#WB27T10231) control board. Hope that is helpful!
Posted on Jan 15, 2009
I have a kenmore stove model number 790,72403012 and 3 of the 4 burners are working. They all are getting a spark, but the front left won't fire up.
First, try to light the burner in question with a match. Just hold a match to the burner, then turn the gas on to low. If the burner doesn`t light, the problem is the gas supply to the burner. Next, lift the top cover and put the prop rod in the hole in the cover to support it. Hold a match to the left-front burner. Now, turn the control knob to "light". You should see the igniter spark and hear a snap. If this doesn`t happen, repeat this step with the left rear burner. If you hear the spark and snap.
If the igniter doesn`t work on the front left burner, but does on the rear left burner, the igniter does work. The problem is likely the control knob for the left front burner. The. Control knob includes the electrical switch the activates the igniter when you turn on that burner.
Jan 26, 2015 | Kenmore Kitchen Ranges
Fridgidaire stove clock not keeping correct time
Clock logic can not be changed replace the whole board
just lets you change the time will not let you slow it or speed up
Nov 14, 2013 | Frigidaire FGGF3054KF Gallery Series...
Sears Kenmore gas stove, the front left and the left and right rear burners turn on when the knob is turned to the lite position. The right front burner doesn't turn on when put lite position. N
If there is no clicking sound like you hear when you turn on the other burners than I'm going to say that either the electrode is bad or the spark switch, which is what you turn to turn on the burner to begin with. Both parts are cheap so it may be a good maintenance thing to change all of the burners. Make sure you have your model and go to www.repairclinic.com and order both parts, and if you don't need one send it back for a full refund even if you installed it. good luck
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 29, 2012 | Kitchen Ranges
Im having an issue with my stove model # WGP 34802 the rear left burner will not turn off and the light stays on all the time
unplug range..remove the back panel to view all them wires an switches ...remove the burner knob to see 2 mounting screws ..the switch is bad or a wire is burnt at the switch check all wires an connections ... if all look good.. replace the bad burner switch..let me know good luck../joe/
Aug 28, 2010 | Whirlpool Kitchen Ranges
Left rear stove top electric burner does not work. burner element good. no power from stove to plug in module that has front and rear burner. front burner works.
ok you have a fun one becuase the sockets could be bad you need to check for 220volts at the plug in for the serface burners if no power there then bad switch
Jun 02, 2010 | Jenn-Air JES9750 Electric Kitchen Range
JGC8536
If the front left also does not light normally, my best guess would be that the wires for the front left and right rear are crossed and the insulation may have fried. Besides that possibility, I have no clue.
Feb 14, 2010 | Jenn-Air JGR8850 Gas Kitchen Range
Ignitors keep firing by themselves after my aunt cleaned them 24 hours ago After she did the major cleaning of the stove I used the oven and it worked fine. I lit a burner (Probably front?) and the left...
Apparently there was a water spill around the burner control knob and in the burner itself; We ran the burner to create heat and then turned it off and let the water dry out and evaporate from the burner and igniter area.
May 26, 2008 | Kitchen Ranges
You have water left over from cleaning and it is shorting out the igniters at the knobs, not the burners. I guess the solution is to wait until it dries out unless you can open the top and maybe use a hair dryer.
Sep 21, 2007 | Frigidaire FGF326AS Gas Kitchen Range
GE JBP64 CleanDesign Electric Kitchen Range Logo
840 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
