Question about LG enV VX9900 Cellular Phone
Front screen is blank
The small screen on the front, above the number pad, is blank like it isnt even on
When I press OK and open the phone it shows the menu.
I can make outgoing calls and everything functions as it should..... the screen is just blank
Tried different battery, turning off and on, charging, and messing with settings.
  • brittlebones Mar 20, 2008
    The same thing happened to me. Yesterday the front screen just stopped functioning. The phone works fine otherwise.
  • VickyK90 Mar 28, 2008
    I have this same problem right now and its not like i did anything to make it happen, like drop it in water, it just happened randomly. I got it for christmas from my mom but she didn't buy the insurance from verizon for it. would they still help me with it? It's only been like 2 months!
Some times phones just do this, they malfunction.. my chocolate did it many times. take it in to a verizon store they will give you a new one. Hope it all works out! =]
Posted on Mar 07, 2008
The front screen of my Nokia 2720 is just blank, how do I get to work
The micro ribbon wire may be damaged if its blank if the phone is old this may be the case opening and closing breaks the ribbon wire after time. If it is new return for replacement. also in menu, phone, display is where all adjustments are.
Apr 06, 2012 | Nokia 2720 Fold Cell Phone
My z310a Sony Ericcson's screen is blank.
i had the same problem, just wiggle the top half of the phone like you wanna break it (but don't break it) The problem is a loose wire between the two phone parts... wiggle it.... just a little bit
Mar 19, 2009 | Sony Z310a Cellular Phone
White screen!!
my lg's camera started to turn my phone off, i do tech work for a wireless company and when i was trouble shooting my own phone as a test i went to my camera and my screen went blank! i tryed every thing, but the master reset. because my screen is blank i need to know the number i will have to enter to get it reset from the key pad.
Sep 30, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Front screen
You need to change the flex ribbon. The phone will be ok
May 11, 2008 | Motorola Mobility i880 Cellular Phone
Phone works for about a minute then goes black and dies
The keyboard cable is worn or broken, take it to a service center for replacement. The keyboard cable has a small magnetic switch that detects when the phone cover is open or closed. If the keyboard isn't working and the internal screen is blank, the phone detects that the cover was closed.
May 02, 2008 | Motorola Mobility RAZR V3
How to cahnge the battery on a sentry safe
There is a small opening on the front number panel of safe. Use a small hex screwdriver or pin to insert into opening. It will open up the front panel (slide panel to right to take off) showing you 4 AA batteries. Just replace and close panel. Very simple to do. I wish the manual show me how. Instead of trying to figure it out for hours.
Dec 25, 2007 | Optics
Directions are off and the alert comes too late
This is the total reset process step by step i found it on
www.avicx1forums.com and it worked fine.
REMOVE DISK
HOLD RESET AND EJECT
RELEASE RESET BUT HOLD EJECT
SCREEN WILL GO BACK IN AND OUT-THEN SAYS PLEASE PRESS THE RESET BUTTON…DON’T
THEN WITH JOY PAD PRESS …
UP,RIGHT,UP,RIGHT,DOWN,RIGHT,DOWN,RIGHT…THEN OK (JOYPAD BUTTON INWARDS)
PASSWORD SCREEN WILL COME ON SCREEN BREIFLY
TEST MODE SCREEN APEARS-CLICK JOYSTICK TO RIGHT ONCE
SCROLL DOWN TO NUMBER 6-PROGRAM FORCED WRITE (OK)
FIND NUMBER 1 SYSTEM PROGRAM (INSERT DISK --CNDV 40/50/60?)
PRESS 1 SYSTEM PROGRAM (OK)
SELECT 2 DVD/CD ROM (OK)
SELECT LANGUAGE… (ENGLISH)
PRESS (VIEW –POS) BUTTON
SHOULD SEE SYSTEM PROGRAM GOING UP IN %
WHEN FINISHED PRESS (BACK)
FIND NUMBER 6 PROGRAM FORCED WRITE AGAIN (OK)
NUMBER 3 APPLICATION PROGRAM (OK)
SELECT 1 UK ENGLISH...THEN PRESS (VIEW – POS) BUTTON
SHOULD SEE SYSTEM GOING UP IN %
TEST MODE PAGE 1
SELECT 6 - CLEAR BACK UP MEMORY (OK)
SHOULD SAY FINISHED THEN ASKS FOR RESET BUTTON TO BE PRESSED
PRESS RESET ON FRONT OF UNIT
START SAT NAV AGAIN
ASKES FOR LANGUAGE PRESS NO (READ TEXT)
SYSTEM STARTS
BUTTONS
OK = JOYPAD INWARD
BACK = JOYPAD TO THE LEFT…NOTE THIS WILL BRING YOU BACK TO PREVIOUS PAGE
BACK = BAND BUTTON ….NOTE THIS WILL TAKE YOU BACK TO THE MAIN MENU
Aug 28, 2007 | Pioneer AVIC-N1 In-Dash DVD Multimedia AV...
LG VX8600 SCREEN WENT BLANK, PLZ HELP!!!
m8 sounds like your screen is faulty or your ribbon has been damaged in some way.to fix it you will need to open it and have a look at the ribbon if there is any damage vissible no matter how small it means ur ribbon is gone an you need a new 1.it could also be your screen if there isnt any damage on the ribbon then it could be the screen.it could be a combination of both. word of caution: if you try to open it yourself you could damage the ribbon.you wont notice it but its very easy to do.so be carefull. but if you want an expert to do it for try these guys http://www.mobilephoneservicecentre.co.uk/ good luck
Jun 18, 2007 | LG CHOCOLATE VX8500 Cellular Phone
Front screen went blank
Dear. most chances are that that the flate of ur phone is bad connect be cause of dropping. just open it and reattach the cable will ok. cable is from board to lcd and it may be bad connect on any side lcd or board first check it from board side if no t ok then from lcd side even no ok change a new cable.
Mar 26, 2007 | Motorola Mobility V265
LG enV VX9900 Cellular Phone Logo
181 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
