SOLUTION 1 - Verify if minimum system requirement is met.
SanDisk card readers support Windows Vista, Windows XP SP2 and Windows 2000 SP4.
For MAC users, see Troubleshooting USB device on MAC
SOLUTION 2 - Verify the reader's status under Device Manager.
STEP 1 - Connect the reader to the PC
NOTE: It is recommended that you plug your card reader to the back USB port on your PC to ensure that there is enough power from the USB port for the card reader to be detected properly.STEP 2 - Check under Device Manager1. Right-click
My Computer.
2. Select
Manage.
3. On the left pane, click
Device Manager.
NOTE: The card reader will appear in two places: Disk Drives and Universal Serial Bus controls as USB Mass Storage. If there is a yellow exclamation point (!) or question mark (?
) next to the device, try to refresh the drivers.
STEP 3 - Refresh the drivers1. Right-click the entry with the error mark, select
Uninstall.
2. On the top menu, click
Action, and then click
Scan for hardware changes.
STEP 4 - Verify if the reader is detected1. Double-click
My Computer.
2. Look for the card reader under
Devices with removable storage.
SOLUTION 3 - Try other USB ports.
A yellow exclamation point (!) under Device Manager usually means that the device is not receiving enough power. If the reader is not receiving ample amount of power from the USB port, it may not function properly.
SOLUTION 4 -
Change the drive lettersNOTE: The SDDR-89 reader should show 4 drive letters under My Computer
