Question about Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card (683728017118)
Card inside the SAA7130
The connector piece inwhich the cable plugs screws onto the antenna cable tv "in" snapped off from the card. Is there anyway to order this card by itself? The part number is 3139 147 13421c#
FM1236/F hm
SV22 0329
made in Indonesia
Thanks for you help
Tony
    New Friend:
Fq1216me/
Posted on Jun 11, 2013
  • 91 Answers
You can simply insert it back into the card.
Posted on Mar 08, 2008
How to connect Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card (683728017118) to pc to get sound?
you need a cable 3,11 to 3,11 plug conector , buy it the price is like $3
concect to the audio port of the tv card behind and conect the other extremo to the pc sound card , and play it
May 31, 2014 | Philips SAA7130 TV Tuner/FM Radio/Video...
How to connect to pc to get sound?
you must put the speakers to green connector---or cable from green connector to line connector in the sound card and change in you computer device to line can you hear from there
I get only black and white picture
Dear Zak Nkosi.1) First Of All You Must Check Your TV Card That Properly Plug in Your PCI Slot. 2) Then The TV Card Drivers Is Mach Your Window Version And Properly Install, Some Driver Did Not Work In Every Type Of Windows,3) Must Check Your Antenna Cable That Properly Plug With TV Card, 4) Some Time The TV Player Is Not Work With The TV Card Driver, So Check With An Other TV Player,NOTE:Its Very Important That You Have Tested TV Card With Latest Drivers.
Nov 14, 2011 | Philips SAA7130 TV Tuner/FM Radio/Video...
I have a frontech pci tv tuner card with philips chipset SAA7130 installed on pc gives images but no sound?
Hello
The package contains an audio cable, connect the cable audio out from card to audio in of computer and connect the speakers at the same place where it is,
or you can directly get audio from tv card by connecting speakers to audio out connectors.
Hope this helps, if so do rate the solution
good luck
Dec 30, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
I have a SAA7130 Analog TV Card. I split the signal from a cable TV line to a Tv, where it works, to the cable connector on the card, which is in a PCI slot on my new COMPAQ Presario Model AY030AA#ABA...
Hi you should make sure the TV card is fitted properly into the slot and then reinstall the drivers for the TV card.
Please let me know if you any questions Thanks for asking
Jul 23, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
ENTER saa7130 tv capture card not working properly
You need to make a cable with both ends with 3.5 mm jack socket. Plug one jack socket in audio out from tv tuner and the other in the line in from your sound card and will work.Good luck
Apr 01, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
Broke the piece where the cable wire goes in...what's it called?
Unfortunately, that coax connector  is almost certainly crimped onto a cable inside.  You might want to pull off the back panel to see if that internal cable is screwed onto another jack on the chassis. If so, you can disconnect that end and substitute another cable, they come in several different lengths and are not critical. Any electronics store will have them.
If it isn't equipped with a connector inside, you will need to have someone unsolder the defective cable and install a new one.
Dec 21, 2008 | Philips Magnavox 51MP392H Rear Projection...
Philips SAA7130 TV Tuner/FM... Problem
(Have u got a small cable with both side 3.5mm pin like head ph cable cord if not buy it) NOW FoLLOW THE STEPS1)plug the cable between tv card jack(green slot) to line in jack (computer pink slot)2)plug ur spker to line out jack(green slot in computer)3) double click on small spker icon (left side to ur screen near clock)4) click options menu>Properties>chose audio out option 4m drop box(see image)
11_2_2011_5_27_42_am.jpg5)click rear pink in >okAnd all done have fun
Jun 26, 2008 | Philips SAA7130 TV Tuner/FM Radio/Video...
Wireles card
Most laptop's wireless networking card is underneath. They are normally accessible after removing a lid/panel held in place by a screw (or 2). It is easily identifiable since it will be the only plug-in card with 1 or 2 thin cables with snap on connectors which are for the antennas. They are held in place by snap lock on both sides. Gentling prying the lock on the sides further sideways will cause the WiFi card to partial snap out of its holder and can therefore be removed easily.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 24, 2008 | Computers & Internet
Sound not recorded
You need an 1/8" male jack plug (both ends) cable. One end plugs to audio out on TV card, the other end plugs to audio in on the sound card. Or is it the other way around. Anyway, thats what you need. I think Radio Shack sells them maybe BestBuy or Circuit City.
Jul 02, 2007 | Philips SAA7130 TV Tuner/FM Radio/Video...
Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card (683728017118) Logo
287 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
