Question about Verge VFMMP3 10-Disc CD Changer
Cut cord The cord from the remote to the radio is cut can it be repaired or replaced?
  • Anonymous Jun 02, 2008
    the cord is cut
  • Anonymous Apr 25, 2009
    Circuit City is bankrupt and getting a replacement is impossible as far as I have found.
  • 24 Answers
If you are handy with a soldering gun it can be repaired. probably better off replacing it
Posted on Mar 07, 2008
I need a new channel changing Mike for a Realistic TRC 476. The cord for the Mike was cut and even though repairs were done the radio just scans through every channel very quickly and constantly.
You should check the new cable wiring connections. There is a resistor in that microphone that connects to the channel button circuit, it is (electrically) between switch 5 (up) and pin 3. If this not present then it may be causing your issue, IT is also possible that the diode for that circuit (located on the main board) got damaged when the cord was cut. diagram: http://www.cbtricks.com/radios/realistic/trc_476/476_print.htm
Oct 10, 2016 | Radio Communications
I accidently cut the electrical cord while using the black and Decker hedge trimmer TR116, now its not starting.
Did it cut it all the way through.? Have you repaired it? Has it been repaired adequately? Check it hasn't blown the fuse in the plug when it was cut, protecting the circuit.
May 14, 2016 | Garden
My son cut the power cord to the tv, how do I replace the cord? can I replace the whole cord from the back of the TV?
That cord in this model is usually a plug in--inside the set it either goes to a plug or is soldered in place.
Depending on how short it was cut it can be repaired--notice that here the cord has two sides---one will be smooth and the other has a white stripe or is rough----if spliced the splices must match the ones on what is left of the cord-----cord is polarized and should not be plugged in unless matched to set.
A fairly easy repair if done right--most people or any outside repair person can easily do this.
May 04, 2012 | Philips 60PP9202 60" Rear Projection...
Have cut through power cable on a brand new hedge trimmer .
open the cover and replace the cord buy a extention cord cut the end off it and use it as a new wire
Apr 06, 2012 | Garden
The lead on our machine is becoming frayed - is it possible to replace the lead and if so, how is it achieved? John Tuffley
If you are refering to the Electrical Power Cord? Yes, this can be easily replaced or repaired.
Depending upon where the cord is damaged, you can either cut it a little shorter and install a replacement electrical plug end (available at any electrical parts store (Lowes, Home Depot, Radio Shack, etc) for about $2.50.
Or if the cord is damaged near the vacuum, you can purchase another cord or even make up one yourself how ever long you want it within reason.
Jun 15, 2010 | Sebo Automatic X1 Bagged Upright Vacuum
Need replacement cable from sub woofer to TV. (25 pin?)
Any radio shack or best buy will have a new sub woofer cord, should not run you more than $ 15-20
Jun 07, 2010 | Denon SC-M201 Main / Stereo Speaker
Power Cord was damaged in transit. Replace or Repair? Replace-How
You can only try to repair the section where they cut short and re-unite each with its respective color tape and you put him ready
Feb 05, 2010 | Exercise & Fitness
Radio just hums.
Im having the same problem!!! Trying to figure out if my 6 year old cut the little cord that is attached, inside, next to the line in hole.
Jan 29, 2009 | Dual Electronics ihome iH9BR iH9 Alarm...
No power to radio in trk have 13.5 volts to radio 257 magnum
Ensure that the wiring is correct. Also make sure that the CB's AC is still functioning correctly. Charge your truck's batteries and test the CB on a fixed electrical output (indoor outlet). Also check to see if the power cord is the correct wattage output for the radio.
Hope this helps!
Gavin93
Aug 02, 2008 | Magnum 257 CB Radio
Cut Cord
Please specify. What did the cat chew the wire to?
Jun 20, 2017 | Logitech Premium Headset
Verge VFMMP3 10-Disc CD Changer Logo
66 people viewed this question
Top Verge Car Audio & Video Experts
Shehu Pro
Shehu Pro
FastHarley
FastHarley
Are you a Verge Car Audio and Video Expert? Answer questions, earn points and help others
