Question about Belkin BLKF5U201 USB Peripheral Swith,2x1,Multiple Computer,Charcoal Gray
Peripheral switch I have 2 computers to share 1 printer. There are 2 ports going into the switch. Port 1 works and port 2 does not. If I plug computer 1 in to port 1 and computer 2 in to port 2 only Computer1 can print!! If I plug Computer 2 into port 1 it will print!! So what do u think about port 2 ???????????????????????
  • Anonymous Aug 02, 2008
    I have the same problem. I just returned the switch and picked up a new one but it has the same problem. Must be me!
    As I said, it must be me. Maybe I figured it out (at least it works for me). On the icon tray you must right click on the switch icon, then click on switch. It will then recognize the computer it is to print from. Hope this helps someone else.
Install the software and and right click on the icon in the right lower side and switch.
Posted on Jun 14, 2008
  • 26 Answers
Port 2 is problem. same way test plug computer 1 in to port2. test . if print not works confirm that port 2 is only problem . replace the switch.
Posted on Mar 13, 2008
How can i install hp designjet 5500 PS on my com puter using network cable? My plotter (hp designjet 5500) do not have USB port instead it has netwok port from which one can install via the local network...
You are doing some mistake.
All peripherals will attach directly to the main server or main system.
Then from the main system you attach the network switch and share the peripherals with other
system.
you connect the printer, plotter, scanner etc to your computer directly through the aproprite cable /
port.
Apr 15, 2011 | HP DesignJet 5500PS InkJet Printer
Tip
How to connect the Printer to a network ?
Connecting the USB Printer to network
1) Right click on My computer
2) Click on Properties
3) Click on Computer Name
4) Click on Change (where it says "To rename this computer or Join a domain, Click Change")
5) Give Name to your Work Group
"Type the some Name in the BOX"
6) Click OK and Restart the Computer
** NOW THIS COMPUTER IS A PART OF WORK GROUP **
(settings on Main Computer where the Printer is installed)
7) Now we can share whatever you wana share
8) Open control Panel
9) Open Printer and Faxes right
10) Right click on the Printer Icon and click on Properties
11) Click on Sharing
12) Click on share this printer and *Name the Printer if you want share
13) Click on Apply now this Printer is in Network
Network the Second Computer
13) Go to each computer
1) Click on Start - control panel -
2) Click on Printers and Faxes
3) Click on Add a Printer
4) It will show Welcome to Add Printer Wizard
5) Click on Next
6) Select "A network printer, or a printer attached to another computer
7) Select browse for a Printer and HIT NEXT
8) It will show you the WORK GROUP and when you hit on it it will show you the Printer
9) Click on Next and OK
Its Done the Printer is Shared and you can take a print out.
Note : The Main Computer should On in order to take Print-out
Hope this will help you connecting your USB printer to the Home Network
or IF YOU HAVE THE NETWORK PRINTER check the following steps
Adding a new network printer
1) Click on Start
2) Click on Printer and Faxes
3) From the left side of the window - click on Add a Printer
4) It will Pop up a new Screen (Add Printer Wizard Window
5) Click on Next
6) Select Local Printer
and Uncheck Automatically Detect and install my plug and play printer
7) Click on Next
8) Click the DROP-DOWN menu next to Use the following port
and if the Printer Queue is listed,select it and click NEXT
***IF it is not listed in the Menu,
Choose Create a new port
from the Type of the Port list - select Standard TCP/IP Port. Click Next
In the Add Standard TCP/IP Printer Port Wizard window, click Next.
In the Printer Name or IP Address field,
- Type the queue name of your printer and the Port Name field will be automatically filled in
Click Next
Click Finish
IF Required Install the Printer Drivers using the Disk
9) If you are asked whether you want to keep an existing driver, select Replace existing driver, then click Next.
10) In the Printer name field, type the printer's queue name, model name, location and double-sided or single-sided. If this is the printer you will be using most often, select Yes to use this printer as your default printer; otherwise, select No. Click Next.
11) If you are asked whether you wish to share the printer, select Do not share this printer. Click Next.
12) When you are asked whether to print a test page, select No
13) Click Next.
14) Click Finish.
Note : You may have to wait a few seconds for the Add Printer Wizard window to disappear and it may appear frozen.
If you receive a message that a Microsoft digital signature was not found, click Yes to continue the installation.
TEST THE PRINT
To check if the printer is working correctly, go to Start > Printers and Faxes. Right-click on the newly created printer, select Properties and then click on the button for Print Test Page.
on Jan 22, 2010 | Office Equipment & Supplies
Can't get this thing to work.
Post equipment names and model numbers when you seek instructions. Here is one manual but it may not be for your equipment. You can go to manufacturer's sites and search for user manual by model number, generally. Or try googling for the model and model number and "user manual." https://www.iogear.com/support/manual/GCS632U_Manual.pdf
May 29, 2017 | Aluratek AUS0202 - 2-Port USB 2.0...
Computer cannot communicate with printer
either port or driver problem. you may have to make adjustments in BIOS under peripheral devices. default is auto, change to assign manually and assign a port for com 1, com 2, printer.
reboot
right click MY COMPUTER, PROPERTIES, HARDWARE, DEVICE MANAGER; scroll down to com 1 and com 2 ports (above printer port) make sure no yellow explanation marks which indicate a port conflict. NO PRINTER WILL PRINT.
go to mfr website and download driver for your printer
click MY COMPUTER, PROPERTIES, HARDWARE, DEVICE MGR;
scroll down to printer port; right click; PROPERTIES, click on change driver; browse over to where you download drivers; keep going down the tree until you get to DRIVERS (select the folder with your operating system) click on it to OPEN into dialogue box (in change driver wizard which is open) and hit enter; THE WIZARD WILL INSTALL THE CORRECT DRIVER FOR YOUR PRINTER.
HAPPY PRINTING.
Apr 03, 2009 | Lexmark X3470 All-In-One InkJet Printer
Use two computers with one printer
Printer Sharing (This is good for Windows 2000, XP and Vista)
Sharing will be very easy if your network is working.
You need to consider the computer where the printer connected as the "Host" and the other computer that wants to print to that printer as the "Client".
Before you do such sharing, you need to acquire each computer's IP address.
You can do it by accessing MSDOS Prompt and typing in ipconfig/all. Write down your IP addresses and the share name on a paper.
For your Host:
Install the driver, make sure that you can print on direct bi-directional connection (such as USB).
Go to Control Panel >Printers and Faxes* >Sharing >Share this printer >Type in your share name, good example is PRINTER (this is case sensitive).
For your Client:
Install the driver, make sure that you can print, same with the Host.
Go to Control Panel >Printers and Faxes* >Properties >Ports >Add Port >Add local port type in \\ (the IP Addressof the Host) \ (share name), click OK.
ex. \\192.168.1.3\PRINTER (watch your backslash, no spaces)
*Term used is "Printers" for Windows Vista and Windows 2000
Oct 23, 2008 | NetGear FS105 5x10/100 Mbps Networking...
2 0f 4 ports do not work
It sounds as though the ports on the cable/dsl router as bad. There really isn't anything you can do. It just happens. The typical shelf life of those routers is about 3-4 years. You could go out and buy another one or if you just need more ports go out and buy a little 5 port switch and plug it into one of the working ports and your comptuers into the 5 port switch.
MO
Jul 12, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Oki C5150 Not Communicating with Computer
lpt1 usually only works for parrallel printers unless a USB port has been mapped as lpt1.
Is this being installed on a Windows Vista computer?
Jun 19, 2008 | OKI C5100n Laser Printer
USB Peripheral Switch
do not use Front usb connection. try to use cpu backside USB port it wil work.
Feb 27, 2008 | Belkin BLKF5U201 USB Peripheral...
CAn't print on one PC
Are you sure it is not recognizing the switch?  Just a thought, but maybe the other computer has not loaded the usb drivers for the printer.  Have you connected the printer directly to the computer to see if you can isolate the problem?
Oct 11, 2007 | Aluratek AUS0202 - 2-Port USB 2.0...
How To Configure FM114P or FR114P for an Internet Connection and Printer Sharing
There are three steps: 1. Configuring the router for Internet access 2. Installing and configuring the print server 3. Adding the printer to the Windows configuration To Configure the Router for Internet Access 1. Connect the modem to the router's Internet port and your LAN computers to the router's LAN ports. 2. Shut down your LAN computers. (Power them off.) 3. Power off the router. 4. Power off the modem. 5. Power on the modem. 6. Power on the router. 7. Start the LAN computers. 8. Enter 192.168.0.1 in a Web browser's address. 9. Type username and password (by default admin and password). 10. Click Setup Wizard to configure the router's Internet access. To Install and Configure the Print Server 1. Install the Printer Server Driver program on a computer. 2. After installation, make sure to select the Run Print Port Setup now box. 3. Click Finish. Print Port Setup runs, showing you the firewall and the printer. 4. Click Port 1. 5. Click Add. A pop-up message says whether a port was created, then the Add Printer wizard starts. To Add a Printer With the Windows Add Printer Wizard 1. Continuing from the last section (or clicking Start > Settings > Printers > Add Printer), click Next. 2. Select Network Printer, and click Next. 3. Click Next again (leaving the port as LPT1). 4. Select the manufacturer and printer model of your printer. (If your printer does not appear, you need to get the CD or floppy that came with the printer, and use Have Disk to specify the file location. Note that it is looking for a file that ends with .inf.) 5. Click Next. 6. Change the printer name to something users on your LAN will recognize easily. 7. If prompted by the Add Printer Wizard about sharing: DO NOT enable sharing! Now test the printer. Other information about Windows configuration is available in Windows help in the article "To connect to a printer on a network".
Feb 19, 2006 | NetGear FR114P Router
Open Questions:
See all Belkin BLKF5U201 USB Peripheral Swith,2x1,Multiple Questions
Belkin BLKF5U201 USB Peripheral Swith,2x1,Multiple Computer,Charcoal Gray Logo
363 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
