Question about Hitachi 26LD6600 26 in. HD-Ready LCD Television
Hitachi 32LD6600 - When the TV has been on for abot 30 minutes the colours start to go blue/red and the picture is distorted,noting I do gets the picture to display as normal.
  • Anonymous May 29, 2008
    blues and greens turn fluorescent and screen flickers.No steps taken so far because i live in spain and i do not speak spanish.
Hi i have this tv and last night the screen went black i can hear sound ok but no picture just a black screen, Also i can see dark
outlines /shadows of whats on the tv, can you tell me please what has caused this
Posted on Apr 21, 2008
  • peat85 Jan 31, 2011
    Make your own "Problem-thred", then you might get more help. To me it sounds like your backlight has died.
My picture is messed up. Its kind of unclear with
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 04, 2010 | Hitachi 50GX30B 50". Rear Projection...
My hitachi tv's picture is distorted red and green like a 3-d pic
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Feb 08, 2010 | Hitachi 57F710 TV
My Toshiba 50H82 television takes about 30 minutes to clear up and during that process, it shakes.It becomes clear but still has wavy lines at the top of the screen which is about 6 inches.
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
*Screen Looks 3-D
*Colors wont align
Jan 10, 2010 | Toshiba 50H82 50" Rear Projection...
Hi I have a hitachi 50 inch projection tv and
there is no tube in a projection tv it will be the conversion chips if picture colours aer distorted
Dec 12, 2009 | Hitachi 51F59 51" HDTV Projection...
Problem with a colour display on Hisense tv
If your picures are all purple it means that the green colour is missing. TV colour is made up by mixing Red, Green & Blue. Removing Green leaving Red & Blue makes purple. Study the green colour circuit for a fault and confirm that the green gun inside the tube is working.
Aug 31, 2009 | Hitachi 60SBX78B 60" Rear Projection...
Ghosting or distortion on edges of screen
The most likely cause is shorted convergence chips and possibly a few pico fuses.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 26, 2009 | Hitachi 43F300 43" Rear Projection...
Distorted Picture
  • Screen looks 3D
Aug 02, 2008 | Toshiba 65HDX82 65" Rear Projection...
Hitachi 43FDX01B (convergence) problem
hi i have same prob iv bin told its a convergence chip an thay r £150 ! thay go bout evry 6 years an its comon .. any way there coming 2 fix mine 2day so ill let u know if it sorts it out my mail is mjoutlaw@hotmail.co.uk thanx
Jan 30, 2008 | Hitachi 51F500 51" Rear Projection...
Bad ghosting of all colours
*Screen Looks 3-D
*Colors wont align
Problem #2
Jan 09, 2008 | Samsung PCL545R 54" Rear Projection...
Convergence IC's must be changed to start repair..original...
STK392-110 sub to Hitachi upgrade STK394-160E.....PART #
CZ 01341...you need two....
Next, take a critical look at the B+ feed resistors near the IC's..
check for over-heat / damage......usually 2.2 ohm 2 watt......
Let me know....................T.
Jan 03, 2008 | Hitachi 43FDX01B TV
Hitachi 26LD6600 26 in. HD-Ready LCD Television Logo
539 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
