Question about Whirlpool Duet GHW9150P Front Load Washer
Dl error message on front loader
I have had zero problems with the front loading duet ht until now.  I had a power outage and when I tried to do wash after the power was restored I had this DL F error message.
  • 8,617 Answers
This is the info from the error code for your washer DL/F
Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked. It will try to unlock the
door 6 times before displaying the error.
Potential Causes
• Door Lock Mechanism broken.
• Check Door Lock/Switch Assembly for foreign objects
• Check Wire Harness connections to the Door Lock/Switch Assembly and Central
Control Unit (CCU)
• Door Lock/Switch Assembly Failure
Note: The Door Lock/Switch Assembly can be manually unlocked. See Section
Seven, TECH TIPS
Posted on Mar 05, 2008
Due to power outage can't get door open on Whirlpool Duet front loader washer. With wet towels inside, need to manually open door to get them out. Is there an easy solution?
On that type of washer the door lock is wired in series with the water level switch and if water remains in tub the door lock will not power up and unlock..what you can try is (if havent already done so) is select the drain/spin only cycle and when the water has drained the door should unlock
Aug 30, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I keeg getting the dreaded F11 anf DL code!
The following list of codes indicates an electronics communication problem with the washer:
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
PLACEHOLDER FOR ART
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, then call for service.
Take care
Jun 22, 2010 | Whirlpool GHW9400 Front Load Washer
Duet GHW9150P Front Load Washer: My whirlpool duet ht washer shows an L20 error mes...
L20 is not a valid error code.
Unplug for 40 minutes and re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet washer front load and its giving me a message of dl f. I can hear it trying to click but nothing happens.
This should indicate a door lock error and the clicking is the door trying to lock. The door is supposed to attempt to lock six times before the dl error is displayed. It is most likely caused by a faulty door lock switch. Hope this helped and best wishes.
Jul 31, 2009 | Whirlpool Duet GHW9150P Front Load Washer
An error signal "DL" - door lock signal keeps coming on
Check for loose wires from the door lock to the control board.If no loose wires,
Replace the door lock switch.
May 23, 2009 | LG WM2277H Front Load Washer
F dL symbol on Whirlpool duet HT
It is saying there is a problem with your door Lock. when you close the door does it hold like it use too? try to open and close the door if it doesn't really close properly then you will just need a door latch. If the machine gives you an f11 code then its the main computer board that can also give your the door lock error. I would check the door first though.
Jan 09, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool ht duet still getting F dl error
DL= Door Lock Error
A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check the wire harness connections to the Door Lock/Switch Assembly and
Central Control Unit (CCU)
if you have done all the abovet the CCU must be bad
Aug 28, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool Duet HT
its a door lock error a door lock error occurs if the door cannot be locked it will try to lock 6 times before displaying the error
Mar 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
630 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
