Program i use to extract files - Computers & Internet
    Problem Solver:
  • 36 Answers
7zip will handle most formats.
http://www.7-zip.org/
Posted on Mar 05, 2008
How to Use WinRAR?
The WinRAR application will compress the files and save in the same folder or location as the original files. The WinRAR program can also extract compressed files with a RAR or ZIP format. Select the files that require extraction using the pointer. Right click on the selected file to display a drop down menu.
Materials Needed:- PC
- winrar archiver program
- file to compress
- compressed files
Step 1
Ensure that the computer you are going to use for compressing files has WinRAR program installed before proceeding with the compression of file.
Step 2
Select all the files to you want to compress by using the mouse and the CTRL button or the SHIFT button. The CTRL button is for selecting several files in the same folder or location. The SHIFT button is for selecting blocks of files.
Step 3
Right click on the selected files to display a drop down menu. Select the 'Add to Archive' option from the drop down list. This will display a WinRAR window menu.
Step 4
Input a name for the compressed files in the Archive name section in the General tab. Ensure that the name is not similar to any other compressed files in the save location.
Step 5
Select the file format of the compressed file after the deciding on the name. File formats can either be RAR or ZIP. There are also other options such as deleting of the original file after the compression, putting authenticity verifications, and putting a recovery record.
Step 6
Click the 'OK' button after completing all the required fields in the menu. The WinRAR application will compress the files and save in the same folder or location as the original files.
Step 7
Step 8
Right click on the selected file to display a drop down menu. Select the 'Extract files' option from the menu. This will display a window from the WinRAR program.
Step 9
Specify where the extracted files will be located in the 'Destination path' option of the General tab. Do not replace the destination path if the extracted files will also be placed in the same location as the compressed file.
Step 10
Click the 'OK' button after filling the required fields in the window. This will start the extraction process of the RAR or ZIP file.
Oct 19, 2016 | Computers & Internet
Tip
How to unzip a file using WinZip. # After you have downloaded your zip filed,...
how to unzip a file using WinZip. <br /> # After you have downloaded your zip filed, locate it by browsing to the file location. <br /># Right mouse click on the zipper folder icon and go to extract. You may also double click the file to open the program. <br /># Highlight the name of the file and click extract option. <br /># You will select a destination folder to extract to. <br /># Done, just browse your newly created folder and program files.
on Jan 14, 2011 | Computers & Internet
Tip
Cannot install a device driver by using its installation program in Windows...
ISSUE- You cannot install a device driver by using its installation program in Windows Vista
OVERVIEW-
When you try to install a device driver by using its installation program in Windows Vista, you are unsuccessful.
SYMPTOMS:
You may experience this issue if the following conditions are true:
• The driver uses an executable file-based installation program.
• The installation program was not designed for Windows Vista.
CAUSES:
Problems with executable file-based installation programs may occur if any one or more of the following conditions are true:
• The installation program is incompatible with Windows Vista.
• The driver is incompatible with Windows Vista.
• An issue occurs that is related to the user rights that are required to install the driver.
RESOLUTION:
To resolve this problem, run the driver installation program in compatibility mode. Or, use an account that has administrative credentials to run the driver installation program. You can also locate the .inf file for the driver, and then manually install the driver.
Important Before you use one of these methods, we recommend that you contact the device manufacturer or the driver manufacturer for more information about how to install the driver in Windows Vista.
To run the driver installation program in compatibility mode
Configure the driver installation program to run in Microsoft Windows XP Service Pack 2 compatibility mode. To do this, follow these steps:
1. Locate the executable file for the driver installation program.
2. Right-click the file and then click Properties.
3. In the PackageName Properties dialog box, click the Compatibility tab.
4. Click to select the Run this program in compatibility mode for check box, click Windows XP (Service Pack 2) in the Run this program in compatibility mode for list, and then click OK.
5. Double-click the executable file to start the installation program.
To run the driver installation program by using administrative credentials
Configure the driver installation program to run in the context of the Administrator account. To do this, follow these steps:
2. Right-click the file, and then click Run as administrator.
If you are prompted for an administrator password or confirmation, type your password or click Continue.
3. Follow the steps to install the driver.
To locate the .inf file and manually install the driver
Use Device Manager to install the driver. To do this, follow these steps.
Step 1: Locate the .inf file
Locate the .inf file that is included with the driver installation program. Generally, the .inf file is located in one of the following folders on the driver installation media:
• In the same folder as the Setup program.
• In a subfolder that is in the folder that contains the Setup program. Generally, the subfolder has a name such as Windows XP, Drivers, or WinXP.
If the driver files are packaged in a single executable file, you may be able to extract them or otherwise access them. To do this, use one of the following methods, as appropriate for your situation:
• Use a file compression program to extract the files.
If the driver files are packaged in a single executable file, you may be able to use a file compression tool such as WinZip or WinRAR to extract the contents of the driver package to a folder. The .inf file should be among the files that you extract.
• Use the Windows Compressed Folders feature to extract the files.
If you do not have the WinZip program or the WinRAR program, you may be able to extract the files by using the Windows Compressed Folders feature. To do this, change the file name extension from .exe to .zip. Then, use Windows Explorer to copy the files from the compressed folder.
• Extract the contents from the .cab file.
If there is no .inf file in the driver package, but there are one or more .cab files, you may be able to extract the contents of the .cab files.
Note This method is usually unsuccessful. Typically, these kinds of driver packages are created by using the InstallShield program. The InstallShield program uses a special .cab format that is not designed to be accessed by tools such as WinZip or WinRAR.
• Locate the files in the Temp folder.
If you still cannot access the installation files, try to locate extracted temporary files. Typically, files are extracted to a local Temp folder when you install a program. You may be able to view the contents of the driver package by examining the contents of the Temp folder. To do this, follow these steps:
1. Remove the contents of the Temp folder. By removing the contents of the Temp folder, you can more easily locate the temporary files that are created when you run the driver installation program. To remove the contents of the Temp folder, follow these steps:
a. Click Start and then click Computer.
b. Right-click the hard disk on which Windows Vista is installed, and then click Properties.
 In the Local Disk (DriveLetter) Properties dialog box, click the General tab, and then click Disk Cleanup.
 In the Disk Cleanup Options dialog box, click Files from all users on this computer.
 Under Files to delete, click to clear all the check boxes, click to select the Temporary files check box, and then click OK.
 When you are prompted to permanently delete the files, click Delete Files.
c. Use Windows Explorer to open the Temp folder. To do this, click Start
type %temp% in the Start Search box, and then press ENTER.
d. Start the driver installation program.
Note Some installation programs automatically delete the temporary files when the installation program exits. Therefore, leave the driver installation program running in the background.
e. Examine the contents of the Temp folder to locate the driver files.
Step 2: Manually install the driver
After you locate the .inf file for the driver that you want to install, manually install the new driver. To do this, follow these steps:
1. Click Start , right-click Computer, and then click Properties.
2. In the Tasks pane, click Device Manager.
3. In Device Manager, locate the device for which you want to install the driver.
Note To display hidden devices, click Show hidden devices on the View menu.
4. Right-click the device and then click Update Driver Software.
5. Click Browse my computer for driver software, click Let me pick from a list of device drivers on my computer, and then click Have Disk.
6. In the Install from Disk dialog box, click Browse, locate an .inf file for the device driver that you want to install, and then click Open.
7. Follow the steps in the Update Driver Software DeviceName dialog box to update the driver.
on May 10, 2010 | Computers & Internet
Free windows 7 product key
Download a program called Hirens Boot Disk from here. http://www.hirensbootcd.org/download/
Scroll to the bottom and download the ZIP. Extract the ZIP file and click on HBCD customizer. Then make sure Extract ISO is selected (not folder) and navigate to the ISO file. (It should appear straight away when you click browse)
Wait for the files to be extracted to the folder which it creates (c:/mybootcd)
Then once extracted to that folder, click on HBCD and then HBCD Menu.
A Box will appear click programs. Then down to Password/Keys, then Product Keys and try a couple of programs out.
If you know what you are doing I actually suggest you download hirens 15.1... search for this... hbcd-15.2-Restored-V1.1-dvd-proteus
It has a program called Remove Wat which is a very cheeky program indeed.
Alternatively, get your wallet out and buy a legit version of windows.
Sep 07, 2014 | Microsoft Computers & Internet
Extract protected rar files
To extracted protected a protected rar file, you can use Winrar.
Download and install Winrar and then open your rar file using the program. It'll ask you for your password. You must have the password to extract the file. If you don't know it, then you will not be able to extract the file. Once you've got the file open, just choose where you want to extract it to and you're done.
Hope that helps.
Mar 28, 2011 | HP Pavilion a1620n (882780664494) PC...
The printer is saying ink absorber full. Where do I find this and how to fix the problem.
Hi Good day!!! You need to reset your ink absorber pad
Things need: MP tools download it here: http://pcprinter.blogspot.com/2008/02/mptool-multi-resetter-for-canon-mp.html
1. Download the MP Tool software to your computer. The download file comes in a compressed ZIP file that must be extracted using a ZIP file-extraction program. Once you have downloaded the MP Tool zip file, double-click on the file to extract the "MPtool.exe" executable program.
2. Turn on your printer and double-click the "MPtool.exe" file.
3. Click on the "Reset Main" button listed under "Waste Ink Counter," in the MP Tool program screen.
4. Click on the "Reset Platen" button and exit the program to complete the process.
Thank you for using FixYa
Nov 12, 2010 | Canon PIXMA MP160 All-In-One InkJet...
What causes error code 6C10
Hi Good day!!!
Thing need: MP tools download it here: http://pcprinter.blogspot.com/2008/02/mptool-multi-resetter-for-canon-mp.html
Nov 11, 2010 | Canon PIXMA MP620 All-In-One InkJet...
Rar file extraction
Ive never needed a password for rar but make sure its the free version and you can also try tugzip its another zip program but combines rar winzip files into 1 program.
Jun 16, 2009 | HP Pavilion a1320n (882780261747) PC...
PHP Extract
you have download the file
exemple : php.rar *......
And You can now extract and edit you file
then upload the file in your ftp
Aug 05, 2008 | The PHP Group PHP
Computers & Internet Logo
24 people viewed this question
Alun Cox
David Payne
David Payne
