Question about Samsung Televison & Video
Tv will not go into hdmi mode
All other menu seem to work but it will only on the INPUT selection TV
Samsung LCD - LNR268WX/XAA
Checked DVR box, Changed to different HDMI cable, Turned TV on and off several times, check cable connections
SOURCE: Mitsubishi WD 52525 & PS 3
First make sure your hdmi cable is connected from the PS3 to the TV. Then go to netcommand, review, and make sure "monlink" is checked, click next, and finish. Select "monlink" from your device manager and turn on your PS3. If the screen is blue, go to the next step. Connect the PS3 via regular a/v cables to the front panel "input-3". Create a net-command device for input-3 as well. Switch to the input-3 device you created and turn on your PS3. Choose display settings, and change the settings to HDMI. Then click change. You'll have 30 seconds to hit device manager, change the device to "monlink", and let the PS3 unit know the setting has worked. From there you can configure. Good luck!
Posted on Dec 28, 2006
  • 20 Answers
SOURCE: HDMI connection problem
On your TV set remote are you selecting the proper input; for example when you have different devices connected to the back of your tv set, dvd player, vcr, cable box etc; you have to tell the tv which device you want to use by selecting the right one on your tv remove input selection. Hope this was any help.
Posted on Sep 08, 2007
SOURCE: close caption
You need to turn on closed captions through the menu of your PVR. To have it on all the time, turn the box off, press menu on the front of the box, and scroll down to captions.
This should fix the problem
Posted on Mar 10, 2008
SOURCE: HDMI ON ILO 32HD
I use a Toshiba DVD Player SD-6100 and had the same problem when using a HDMI cable. The ILO TV kept saying no signal. I don't know how to make the PS3 change into sending the HDMI signal, I'm sure though that is is similar as to the dvd player simply changing it in a menu. All I had to do was use a component cable to access the dvd player menu and from there changed the video out signal to hdmi, thus sending a signal to the frikkin tv. It all works now.
The Ps3 should have a similar menu to select video signal output. Try accessing it using a previously working cable, then once changed, switch on the tv back to hdmi input and see if it worked.
Hope this helps
Cheers
CPL Avila
Posted on Nov 02, 2008
mistersony
  • 320 Answers
SOURCE: Periodic tv screen blackouts
The problem is your cable box. I know you said you replaced it, but I work on TV's everyday and, sorry to say this but cable box HDMI outputs have serious issues, like no or intermittent sound and video. I have seen customers exchange their cable boxes 5 and 6 times and still have the problem. Your best bet is to use the component outputs of your cable box, visually you will not see a picture difference between component and HDMI when using a cable box. Your other solution is to get satellite; I have NEVER seen an HDMI issue with a satellite box
Posted on Nov 26, 2008
I can't get the input to work. Neither the remote or the button on the side will get me to that menu where I can select HDMI. Worked fine yesterday.
The tv needs a hdmi signal to enable selection on screen. My guess is that there is something wrong with the hdmi cable or the output device (video player, cable box or such}
Dec 17, 2015 | Sanyo DP26640 LCD TV
HDMI input says "mode not compatible"
If your Playstation is putting out the signal in 1080p then try changing it to 1080i and see if that works. Not all TVs are compatible with 1080p.
Aug 02, 2012 | Samsung Lnt4042hx/xaa
Intermittant disruption of Picture and Sound on View TV/HDMI only
If i am not mistaken you can select the HDMI signal going out on the 663, this means you should select to have only pictures to go out as sound will have to be reproduced by the 663.
So HDMI output setup on the 663 should indicate image only, no sound.
Jan 23, 2009 | Yamaha RX-V663 Receiver
Connecting HD cable box to DVR too HDTV
When I hooked up my HD cable box using an HDMI cable, I had to go into the cable screen menus and select HDMI output. You may have to do something similar when using an S-video cable. Your DVD recorder doesn't seem to have an HDMI input, so you'll have to use the S-video or (worst case) composite video (red, white, yellow cords). Your cable box may also be scrambling the signal so that you can't record. That may be why you can record by bypassing the cable box.
Jun 22, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Samsung LTP326w
After few years of service with different TV providers I have problem with my TV. Last night my Samsung LTP326W just did the same think on HDMI connector and no mater what you do it will not turn HDMI video... it's connected to Verizon/Motorola DVR I called Verizon and they promptly replace DVR and HDMI cable but it didn't help at all, also sometimes when you power on/off I get message: The HD Content Protection of your display has been compromised Please use the YPBPR outputs for your HD connection...
When I switch to component cable it works just fine.
Feb 09, 2008 | Samsung LTP326WX/XAA 32 in. HD-Ready LCD...
TV only will play HD Channels
This must be the setup for your TV box. Contact the support for your TV box.
Normaly, the TV should auto select the proper operation mode.
Jerry G.
Dec 25, 2007 | Samsung LN-T4665F 46 in. LCD Television
No Digital Signal to TV
make sure you have Tv on that particular HDMI input .I believe video 6 or 7 .if you do check menu make sure that input is not blocked. or you might want to try the component outputs of cable box and connect that to a component input on tv to see if that is working,,i have seen these tv HDMI input board bad..lets hoe this is not the case..
Dec 16, 2007 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Screen goes blank
This set has a factory upgrade for HDMI problems like yours and it also fixes another problem for intermitent sound in the HDMI mode. This model is still under warranty. Call: 1-800-SAMSUNG To find a local servicer in your area.
Jul 02, 2007 | Samsung LN-T4665F 46 in. LCD Television
Televison & Video Logo
66 people viewed this question
Jerry Greenberg
Jerry Greenberg
