RIM BlackBerry  Pearl  8100 Logo
Posted on Mar 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have owned my Pearl for about 4 years I stopped using it around 2 years ago due to the trackerball not working correctly. i have spradicly pluged it in to retrieve old numbers, pictures, see if there was info on it and it used to be fine even if a good 6 mths had passed it would still charge turn on and function just with the same trackerball issue. I recently got it back out and tried to charge it. 4 different chargers later i still can not even get it to aknowledge the charger by way of the red led. Any ideas? i thought battery straight away but that does not explaine when its plugged in to the mains via charger still no red ledd or any sighns of life?!?!? Anybody care to have a guess as to the fault?
Anonymous
Level 3:
  • Master 583 Answers
  • Posted on Mar 05, 2010
Anonymous
Master
Level 3:
Answers
583
Questions
0
Helped
226631
Points
1903
Your initial thought is probably the answer, the battery has internally short circuited due to age. In this case, the charger cannot produce enough energy to overpower the battery's consumption. While I do not recommend trying this, a tech center I worked at would "shock" a battery back to life by connecting it to a car charger for a few seconds to eek a few more weeks or months of use out of one. Again, I don't recommend this as a battery can explode and cause harm when treated this way.
Number pad is not working correctly
If that is newly installed OS try to check the driver of your laptop is correct. Another option, check your keyboard language settings on the COntrol panel.
Keurig coffee maker won't stop, end up with 4 cups all at once
Timer section and valves open due to incorrect assignments. Replace or repair.
How do I change the message... we set it a few years ago...can't find book
Oops, I posted the info for this on the VTech problem below sorry.
To change the message, first make sure your phone has the correct date, time, year, am or pm, etc.
Now, to Record Greeting - if you don't record your own greeting, a pre-recorded greeting message is used.
So, try this:
1. (Menu) press
2 (Go to Answering Device" with up/down arrow, press OK
3 (Go to "Record Greeting" with up/down arrow, press OK
4 After the handset beeps, speak clearly about 20 cm (8 inches) away from the
microphone.
5 To stop recording, press (OK)
6 (OFF)
Hope this helps.
I had a transmission flush done 2 weeks ago. 1 week later my \low traction light came on whenever I accelerated from a stop. Now 1 more week later my ABS and TSC lights are on. There is a little shudder as...
First, Iam not a fan of flushing a trans. Owned a trans shop years ago.
You may have caused some solenoid issues, with the clutch material and cooler sediment.
Work on the ABS,TSC issues. Wheel Speed Sensors may be going and just a coincidence, a couple weeks later.
Make sure the fluid is correct for your vehicle and at the correct level.
I pray you didn't go to one of the Quick Lube Franchises.
I got a Pearl Mp3 player about 2 years ago. I
Hello There
You Can Download Free MP3 From Youtube By This Site : video2mp3.net
If you didn't found Your Favorite Music In Youtube Try These Sites : Beemp3.com or 4shared.com
Indicators only work spradically
Hi Team,
found a good garage who diagnosed the problem was due to a failed relay; relay and stalk have since been replaced. The windscreen motor is a separate issue and also needs replacing soon. So I'm happy my elderly Merc is back on the road again.
Busy Bee
8helpful
3answers
Brinks safe
As I understand that safe has four numbers to the combo. 1) turn the dial to the right passing the first number 4 times stopping at that number the next time around. 2) Turn the dial to the left passing the second number 2 times and stopping on that number the next time around. 3)turn the dial to the right passing the third number 1 time and stop on that number the next time around. 4) Turn the dial to the left stopping on the last number. 5) Insert the key into the cylindrical lock and turn it to the right.
4helpful
6answers
Cannot Hear people talking unless on speakerphone
Pearl's speaker volume is generally pretty low, but quite OK for a reasonably quiet room. Make sure you press the 'P' key to turn on the speaker phone. You will get an icon in the display window which indicates it. Also, of course, make sure you turn the volume all the way using the keys on the side. Watch the volume slider icon to make sure it's all the way up.
Top RIM Computers & Internet Experts
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Alexander
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
