No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine
and then valves will be turned off and the error code will be displayed.
Or
If
the control has turned the water valves on and after 8 minutes the flow
meter has detected 10.5 gallons of water passing through it, but has
not detected the pressure switch trip, the valves will be turned off
and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
1. Make sure that both valves at the water source(s) are turned on all the way.
2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
3. Verify inlet valve operation
1. Verify Drain pump operation
2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
